- deleted-7256
- 9 mesaje
- din 30 Jun 2007
deleted-7256
- Mesaje scrise: 9
- Cont inregistrat: 30 Jun 2007
- Cristi_C
- 728 mesaje
- din 11 Jan 2006
- Vectra 2003 z18xe + z12xe
- Timisoara
Cristi_C
- Mesaje scrise: 728
- Masina: Vectra 2003 z18xe + z12xe
- Cont inregistrat: 11 Jan 2006
00380: https://www.clubopel.com/vie...p;highlight=p0380
Alalalt nu il gasesc. Oricum folosesti search inainte.
- DIAGNOSTICMAN
- 29 mesaje
- din 02 Jul 2007
- Cluj
DIAGNOSTICMAN
- Mesaje scrise: 29
- Cont inregistrat: 02 Jul 2007
- body_18_is
- 216 mesaje
- din 14 Sep 2008
- Astra 2001 z16xe
body_18_is
- Mesaje scrise: 216
- Masina: Astra 2001 z16xe
- Cont inregistrat: 14 Sep 2008
- DIAGNOSTICMAN
- 29 mesaje
- din 02 Jul 2007
- Cluj
DIAGNOSTICMAN
- Mesaje scrise: 29
- body_18_is
- 216 mesaje
- din 14 Sep 2008
- Astra 2001 z16xe
body_18_is
- DIAGNOSTICMAN
- 29 mesaje
- din 02 Jul 2007
- Cluj
DIAGNOSTICMAN
- Mesaje scrise: 29
strykatu
- Mesaje scrise: 3
- Masina: Astra 2000 Y17dt
- Cont inregistrat: 01 Jun 2009
Acum o saptamana ,dupa 250km mi s-a oprit in mers,dimineata motorul fiind rece a pornit la cheie, dar dupa 10km mi s-a oprit iarasi in timp ce stateam la semafor. Am pus testerul pe ea si mi-a aparut :
P0380
P1625
P1630
Dupa ce am sters erorile ,fara sa mai dau la automat, mi-a aparut numai P1625 si nu mai porneste deloc.
Ce credeti ca are si cam la ce costuri sa ma astept?
Mersi mult
- DIAGNOSTICMAN
- 29 mesaje
- din 02 Jul 2007
- Cluj
DIAGNOSTICMAN
- Mesaje scrise: 29
- cangri
- 5,405 mesaje
- din 24 Sep 2010
cangri
- Mesaje scrise: 5,405
Description
PCM Flash Checksum (TCM) Conditions
Cause
Key on, then the TCM detected that its flash memory had failed
P0380 - GM Type Powertrain - Ignition System or Misfire - ISO/SAE Controlled
Description
Glow Plug Performance Conditions
Cause
Glow Plugs commanded on, then the PCM detected the voltage at the plugs was less than 4.0v, or with Glow Plugs commanded off, then the PCM detected that the voltage at the plugs was more than 4 Ov, or with the Glow Plugs commanded on, the PCM detected more than a 2v difference between the system and plug voltage
P1630 - GM Type Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled
Description
System Voltage Error Conditions
Cause
Engine running, then the PCM detected the system voltage was under 9v or over 17v, either condition met for over 10 seconds.
- DIAGNOSTICMAN
- 29 mesaje
- din 02 Jul 2007
- Cluj
DIAGNOSTICMAN
- Mesaje scrise: 29
- cangri
- 5,405 mesaje
- din 24 Sep 2010
cangri
- DIAGNOSTICMAN
- 29 mesaje
- din 02 Jul 2007
- Cluj
DIAGNOSTICMAN
- Mesaje scrise: 29
Visse- Suspendat
- 1,464 mesaje
- din 06 Jun 2005
Visse- Mesaje scrise: 1,464
- Cont inregistrat: 06 Jun 2005
P0380 Glow Plug Circ Error Circ A
P1625 PCM Sys Reset
Stie cineva semnificatia lor ? sau ce ar trebui sa fak ?
Regula de bun simt , completeaza campurile referitoare la masina ta , asta ca sa poti fi ajutat altfel risti sa ramai si mai in ceata .
keritogen
- Mesaje scrise: 8
- Masina: Astra 2004 z17dtl
- Cont inregistrat: 21 Jul 2013
- DIAGNOSTICMAN
- 29 mesaje
- din 02 Jul 2007
- Cluj
DIAGNOSTICMAN
- Mesaje scrise: 29
keritogen
- Mesaje scrise: 8
- DIAGNOSTICMAN
- 29 mesaje
- din 02 Jul 2007
- Cluj
DIAGNOSTICMAN
- Mesaje scrise: 29
