- alexdinca93
- 19 mesaje
- din 26 Dec 2011
- Astra 2008
- Valcea
alexdinca93
- Mesaje scrise: 19
- Masina: Astra 2008
- Cont inregistrat: 26 Dec 2011
Imi apar urmatoarele coduri la testul cu pedale :
1)ECN 068304 (am inteles ca echivaleaza cu P0683)
2)ECN 161450 (P1614)
3)ECN 224408 (P2244)
4)ECN 013001 (P0130)
5)ECN 011005 (P0110)
6)ECN 162502 (P1625)
7)ECN 050079 (P0500)
Am gasit si semnificatia lor, insa imi este destul de greu sa o descifrez:
1)P0680 Reserve for future Glow plug #10
2)P1614 Loss of RIM Serial Data
3)nu am gasit. Doar DTC B2243 Memory Set Switch Failed
4)P0130 Oxy Sensor Circ (bank1, Sensor
5)DTC C0110 Pump Motor Circuit Malfunction
6)P1625 PCM Sys Reset
7)DTC P0500 Vehicle Speed Sensor (VSS) Circuit
- Blebeanu Lorin
- 1,076 mesaje
- din 04 Aug 2010
- Astra 2005 Z17DTH
Blebeanu Lorin
- Mesaje scrise: 1,076
- Masina: Astra 2005 Z17DTH
- Cont inregistrat: 04 Aug 2010
Referitor la codurile care ti-au aparut tie, la Z 13 DTH eu am gasit urmatoarele:
- ECN 0110- Intake Air Temperature: Sensor Circuit Malfunction sau Low/ High Imput
- ECN 0130- O2 Sensor Circuit: High/ Low Voltage sau Malfunction sau Range/ Performance
- ECN 0683- Glow Plug Circuit: Low Voltage sau Open
- ECN 1614- Wrong Transponder Key Immobiliser sau Immobiliser No Or Wrong Signal Immobiliser
- ECN 1625- Main Relay Output VoltageLow/ High
- ECN 2244- O2 Sensor Reference Cell Circuit Malfunction
Papilica
- Mesaje scrise: 7
- Masina: Astra 2007
- Cont inregistrat: 23 Nov 2015
- dr_agosh82
- 76 mesaje
- din 02 Sep 2011
- Astra 2008 Z17DTJ
dr_agosh82
- Mesaje scrise: 76
- Masina: Astra 2008 Z17DTJ
- Cont inregistrat: 02 Sep 2011
Papilica
- Mesaje scrise: 7
- svasile
- 1,693 mesaje
- din 14 Oct 2014
- Astra 2006 Z13DTH
- Covasna
svasile
- Mesaje scrise: 1,693
- Masina: Astra 2006 Z13DTH
- Cont inregistrat: 14 Oct 2014
- P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)- se refera la sonda lambda.
-P0110 Intake Air Temperature Sensor Circuit Malfunction - senzorul MAP de pe galeria de admisie(incearca sa-l cureti)
-P1625 Main Relay Output Voltage High- ceva legat de comunicarea pe can buz(curata mufele de la CIM, senzor ABS, UEC, REC, cu spray de contact
-P0001 Fuel Metering Solenoid Valve Circuit Open - probleme regulator pompa
- P1614 - Wrong Transponder Key - nu recunoaste cheia -probleme CIM.
-P2244 O2 Sensor Reference Cell Circuit Malfunction- sonda lambda
Papilica
- Mesaje scrise: 7
- jgyprime
- 9,953 mesaje
- din 22 Dec 2010
- Vectra 2005 Z19DT
jgyprime
- Mesaje scrise: 9,953
- Masina: Vectra 2005 Z19DT
Papilica
- Mesaje scrise: 7
