  2. Discuții generale
  • rudisoft
  • Mesaje scrise: 336
  • Masina: Corsa 1997 X12SZ
  • Cont inregistrat: 15 Oct 2010
Unul din momentele cele mai frumoase (și neașteptate) ale vizitei în Italia...
Am lãsat colegii sã facã shopping în voie, și am pornit în explorare:
La un moment dat:
Exemplarele din imagini:
FERRARI CALIFORNIA DTC
Size and weight: Length: 4562mm Width: 1909mm Height: 1322mm Wheelbase:2670mm Front track: 1630mm Rear track: 1605mm, 812mm Kerb Weight: 1780kg; WeightDry weight:16,300kg; luggage compartmentcapacity: 340l; tank capacity: 78l Engine: Type: V8 - 90°,direct injection Bore and stroke:94x77, 4mm Unit displacement: 537cm3; Total displacement 4297cm3; Report Compression: 12,2:1; Maximum power: 338KW(460 HP)at7750rpm.; Maximum torque: 485 Nm(49 kgm) at5000rpm.; Specific Power: 107hp/lTransmission GearboxDTCdualclutch, electronic controls, electronic differential(F1 Trac);
Tyres: Front: 245/40 ZR 19 "Rear: 285/40 ZR 19" front 245/40ZR20 "Rear 245/40 ZR 20" Rear 285/40 ZR 20 ".
Performance: Maximum speed: 310 km / h, 0-100 km / h: less than 4.0 s. ; Change DTC F1; 0-400 m: 12.2 s , 0000-1000 m: 22.1 s Fuel consumption: Combined 13.1 l/100 km, CO2 emissions combined 306.6 g / km
FERRARI F430 F1 e F430 SPIDER F1
Size and weight: Length: 4512 mm Width: 1923 mm Height: 1234 mm Wheelbase: 2600 mm Front track: 1669 mm Rear track: 1616 mm Front overhang: 1100 mm Rear overhang: 812 mm Weight running order: 1520 Kg Dry Weight: 1420 kg; luggage compartment capacity: 250 l tank capacity: 95 l Weight distribution: 43% front. 53% post. Engine: Type: V8 - 90 °; Bore and Stroke: 92x81 mm Unit displacement: 538.5 cm3; Total displacement: 4308, cm3, Compression ratio: 11,3:1; Maximum power: 360.3 kW (490 Hp) at 8500 rpm. ; Maximum torque: 465 Nm (47.4 kgm) at 5250 rpm.; Specific Power: 114 hp / l; Dry weight / power: 2.9 kg / hp Transmission Manual or F1, electronic controls, electronic differential (E-Diff), Stability and Traction Control Tyres: Front: 225/35 ZR 19 "Rear: 285/35 ZR 19 ";
Performance: Maximum speed over 310 km / h, 0-100 km / h: 4.1 s. , Manual Transmission, 0-400 mph: 12.10 sec; 0000-1000 m: 21.85 s. ; Change F1; 0-400 m: 12.05 s. , 0000-1000 m: 21.80 s. Fuel consumption: Combined 18.3 l/100 km, CO2 emissions combined 420 g / km
LAMBORGHINI MURCIELAGO ROADSTER E-GEAR
Engine: 12 cylinder V (60 °) Displacement: 6192 cc Power: 426 kW (580CV) Max speed: 320 km / h; Homologation: Euro 4; Torque: 500Nm. Dimensions and weights: Goalkeeper: 2, Seats: 2;
Body: spider roadster; Length: 458cm, Width: 206 cm Height: 114 cm Wheelbase: 267 cm; Trunk Volume: 140 -0 dc min / max; Capacity Tank: 100 liters Weight: 1665 kg; carbon frame Gearbox: Manual 6-E-GEAR, Drive: Permanent
Performance: Acceleration 0 / 100 km / h: 3.8 seconds, top speed 330 km / h Consumption: 100 km urban cycle: 32.6 liters, Extra-100 Km: 15.1 liters; Mixed Route 100 Km: 21.5 liters
NOBLE M400
Engine: V6-cylinder biturbo FORD handmade with preparation Roush, Displacement: 3000 cc Power: 425CV; Max Speed: 300 km / h; Homologation: Euro 4; Torque: 305Nm 2,000 rpm MECHANICAL AND FRAME: coupe body made of composite GRP; multi tubular space frame steel rolls with integrated brake system with 4 hard drive without ventilation 330mm ABS Weight: Kg, 1050, length 4089mm, width 1885mm, height 1143mm
TRANSMISSION: automatic 6-speed GETRAG; Drive: rear differential Quaife
PERFORMANCE: Acceleration 0 / 100 km / h: 3.5 seconds, top speed 300 km / h Equipment: sports exhaust, leather sports steering wheel MOMO, Sparco alcantara race seats, adjustable trim Dynamics, full rolls, 4 point belts, adjustable steering wheel, instrument pressure turbo, starter button, carbon fiber rear spoiler; AIM instrumentation for data collection;
Info: http://www.dydrent.it/
Pe afiș scria "începând de la 95EUR", dar am înțeles cã e nevoie de câteva sute bune pentru o experiențã cât de cât...
  • GTS-MAN
  • Mesaje scrise: 305
  • Masina: Vectra 2004 2.2 DTI
  • Cont inregistrat: 03 Dec 2009
Fabulos ! 😃 Pe undeva imi aduce aminte de parcarea Hotel Rex din Mamaia in plin sezon estival...
  • acsic
  • Mesaje scrise: 669
  • Cont inregistrat: 23 Aug 2010
Doamne bijuterii :X
  • ManiaK18
  • Mesaje scrise: 19
  • Masina: Omega 1993
  • Cont inregistrat: 30 Jul 2011
Dar citeste si consumul 😊))
  • micky2010
  • Mesaje scrise: 506
  • Masina: Corsa 1998 Z12XE
  • Cont inregistrat: 12 Apr 2010
Ai uitat sa adaugi Gallardo
  • rudisoft
micky2010 a scris:Ai uitat sa adaugi Gallardo
Doar cele din poze erau. Cel portocaliu e Murcielago Roadster, cred cã la el te refereai.
În rest:
roșu - California
negru - F430
alb - M400
