  3. Motoare benzină
  • boddo
  • Masina: Corsa 2007 Z22SE
  • Cont inregistrat: 21 Mai 2011
Salutare baieti,
De aproximativ 24 de ore sunt posesorul unui opel corsa d din 2007, motor 1.2 benzina.
Masina a mers perfect la proba si in cursul zilei de astazi pana cand am luat o gropa pe la 40-50 la ora in oras.. imediat mi s-a aprins check engine.. a palpait cateva secunde , s-a stins, si a aparut martorul cu service . Motorul nu mai trage cum trebuie iar la relanti tremura .. daca opresc motorul si il pornesc parca trage mai bine dar tot tremura.. dupa 2-3 minute iar se aprind respectivii martori luminosti si aceeasi poveste..
Ce sa aiba?
  • adinan_superstar
  • Mesaje scrise: 261
  • Masina: Astra 2003 z18xe
  • Cont inregistrat: 21 Jan 2010
controleaza mufele ,posibil sa fie ceva sarit
  • boddo
am facut diagnoza si mi-au iesit codurile p0300 si p0301 .. acum astept sa verifice injector, bujii, bobina.. :-s
  • Milly
  • Mesaje scrise: 24
  • Cont inregistrat: 04 Jun 2011
boddo a scris:am facut diagnoza si mi-au iesit codurile p0300 si p0301 .. acum astept sa verifice injector, bujii, bobina.. :-s
P0301 Code - Cylinder #1 Misfire
A code P0301 may mean that one or more of the following has happened:
Faulty spark plug or wire
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Faulty catalytic converter(s)
Running out of fuel
Poor compression
Defective computer
P0300 Diagnostic Code - Random Misfire
A code P0300 may mean that one or more of the following has happened:
Faulty spark plugs or wires
Faulty coil (pack)
Faulty fuel injector(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
Verifica si EGR-ul si vezi cum se prezinta. Daca tot il dai jos ii poti face si o curatare, gasesti pe forum un topic foarte bun despre cum sa cureti egr-ul al domnului dancuciureanu.
  • boddo
am rezolvat problema.. Cum?
schimbat motor 😐 .. problema s-a dovedit a fi de la axa cu came.. care nu a avut o ungere suficienta si s-a gripat.. am cumparat un motor cu 30.000 km de la dezmembrari decat sa dau 1600-1800 ron pe axe ..
App am de vanzare un motor de 20.000 km ... pistoane, supape, injectoare in stare perfecta.. la care trebuie schimbate doar axele cu came.. il vand si pe piese.. ( precizez ca nu are "accesorii" .. gen: bobina, electromotor, alternator..
  3. Motoare benzină
