Technical Service Bulletin
Ref. Number 09-FR-49
TIS/TSB Ref. Number E0002540
Group A-10
Release Date 04/09/2009
Door Sill - Water Accumulation
Vehicles:
Insignia 2009-Onwards
Insignia Sports Tourer 2009-Onwards
All Engines
Complaint:
Water accumulates in sill area of front and rear doors.
Cause:
Poor fit of sealing clips allows water entry.
Production
Modified weatherstrip in production as of VIN WOLGM67C191115427.
Remedy:
In case of customer complaint apply additional drain holes (diameter 5 mm) into weatherstrip
Check in door below window glass if the weatherstrip clips are tight. If the weatherstrip clips are loose or can be pulled out easily, replace the clips.
Ultima modificare făcută de Lucifer_The la Mar 04 Jan, 2011 12:00 am
