- octavianvarzaru
- 193 mesaje
- din 01 Jul 2009
- Astra 2005 Z17DTL
octavianvarzaru
- Mesaje scrise: 193
- Masina: Astra 2005 Z17DTL
- Cont inregistrat: 01 Jul 2009
Mentionez ca valorile sunt luate cu motorul la relanti. Motorul este un Z17DTL din 2005.
Va multmesc anticipat tuturor pentru raspunsurile ce urmeaza sa le primesc.
Measuring blocks information:
Battery Voltage 13.6 V
Ignition Status On 12V
APP Sensor 1 (Accelerator Pedal Position) 0%
APP Sensor 1 (Accelerator Pedal Position) 0.98 V
APP Sensor 2 (Accelerator Pedal Position) 0%
APP Sensor 2 (Accelerator Pedal Position) 0.49 V
Barometric Pressure 101 kPa
Barometric Pressure 3.99 V
Boost Pressure Command 100 kPa
Boost Pressure 97 kPa
Boost Pressure 1.83 V
Mass Air Flow Sensor 184 mg/strk
Mass Air Flow Sensor 1.37 V
Intake Air Temperature 24 °C
Intake Air Temperature 2.69 V
Coolant Temperature 58 °C
Coolant Temperature 1.74 V
Desired Common Rail Fuel Pressure 24.00 MPa
Common Rail Fuel Pressure 23.76 MPa
Common Rail Fuel Pressure 1.03 V
Rail Pressure Control Valve Pulse Ratio 349%
Engine Speed 849 RPM
Desired Injection Quantity 6.2 mm3
Actual Injection Quantity 6.2 mm3
Injection Pulse 1.3 ms
Pilot Injection Time 0.7 ms
Brake Switch 1 Inactive
Brake Switch 2 Active
Clutch Switch Inactive
Throttle Position Switch Active
Pulse Ratio Throttle Control Solenoid Valve 78%
Pulse Ratio Boost Pressure Solenoid Valve 95.0 %
Swirl Plate Position Switch Active
Swirl Level Control Solenoid Valve Pulse Ratio 90.0 %
EGR Position Feedback (Exhaust Gas Recirculation) 100.0 %
EGR Position Feedback (Exhaust Gas Recirculation) 3.67 V
EGR Pulse Ratio (Exhaust Gas Recirculation) 14%
Capacitor Voltage 1 826.4 V
A/C Information Switch (Air Conditioning) Inactive
A/C Relay (Air Conditioning) Inactive
A/C Pressure (Air Conditioning) 875 kPa
Fan Relay 1 Inactive
Fan Relay 2 Inactive
Glow Time Relay Inactive
Diagnosis Glow Time Relay Active
Glow Time Telltale Off
Service Vehicle Soon (SVS) Indicator Off
Malfunction Indicator (MI) Off
Cruise Control Tip Switch Not Programmed
Vehicle Speed 0 km/h
Immobiliser Function Programmed Yes
Security Wait Time Inactive
- petrila ioan
- 36 mesaje
- din 14 Nov 2008
- Zafira 2002 y20dth
petrila ioan
- Mesaje scrise: 36
- Masina: Zafira 2002 y20dth
- Cont inregistrat: 14 Nov 2008
- octavianvarzaru
- 193 mesaje
- din 01 Jul 2009
- Astra 2005 Z17DTL
octavianvarzaru
- misaastraG
- 5 mesaje
- din 06 Mar 2013
- Astra 2001 Y17DT
- Suceava
misaastraG
- Mesaje scrise: 5
- Masina: Astra 2001 Y17DT
- Cont inregistrat: 06 Mar 2013
Imi poate spune cineva daca pentru un G din 2001, 17 Dti este corecta valoarea de 5,1% in toate regimurile de functionare a motorului pentru "Pulse Ratio Boost Pressure Solenoid Valve" ? (si ce rol are aceasta valva).
Am facut o diagnoza pentru ca imi scoate fum daca merg cu acceleratia constanta - dupa ce accelerez nu mai scoate, parca s-ar desfunda. Mecanicul imi zice sa merg mai sportiv, dar prin oras nu pot sa merg numai super accelerat caci risc vreun accident!
Pana sa-mi faca aceasta figura la deal, de exemplu, daca mergeam cu acceleratia in aceeasi pozitie, la un moment dat simteam cum se accelereaza singura masina, in schimb acum, in aceleasi conditii, incepe sa nu mai traga si scoate fum negru - daca o calc in schimb - se duce ! Care o fi cauza ?
- alex_paval
- 619 mesaje
- din 22 Aug 2009
- Signum 2005 Z19DTH
- Bacau
alex_paval
- Mesaje scrise: 619
- Masina: Signum 2005 Z19DTH
- Cont inregistrat: 22 Aug 2009
- misaastraG
- 5 mesaje
- din 06 Mar 2013
- Astra 2001 Y17DT
- Suceava
misaastraG
- Mesaje scrise: 5
- misaastraG
- 5 mesaje
- din 06 Mar 2013
- Astra 2001 Y17DT
- Suceava
misaastraG
- Mesaje scrise: 5
Se pare ca acolo e problema!
Valva lucreaza, caci am curatat-o si nu era foarte murdara, vaccum este, deci de vina se pare ca este sistemul de comanda (o tine prea mult deschisa si cand nu trebuie).
Voi incerca sa schimb elementul de comanda (cu unul verificat) si revin cu precizari.
O zi buna !
P.S. (De un Autodata cum m-as putea lipi si eu?)
