  • bibistrocel
  • Masina: Astra 2005 Z16XEP
  • Cont inregistrat: 27 Oct 2015
Salut. Am un opel astra H GTC din 2005 , 1.6 benzina si am ceva probleme. Acum ceva timp mi s-a aprins martorul motor si a ramas aprins. Initial am crezut ca e de la EGR. Consumul pare sa fi crescut, a devenit mai puturoasa. De asemenea dimineata la rece pornirea e grea...doar prima oara. Dupa verificari am constatat ca dimineata, inainte de pornire bateria are 12.5V- poate fi de asta cauza pornirii grele? Am intrat cu OP-COM si au rezultat urmatoarele erori, pe care le-am sters; martorul a disparut din bord. De asemenea ma gandesc ca unele din erori au aparut datorita faptului ca am tot scos mufe si sigurante pentru a verifica o alata problema de o am si anume cea cu luminile de la placuta de inmatriculare.
Steering Column Module
B3925 - Wrong Environment Identifier Received IPC (Instrument)
(00) - Not present
U2113 - CAN-Bus No Communication with SDM (Sensing & Diagnostic Module, Airbag)
(00) - Not present
U2116 - CAN-Bus No Communication with IPC (Instrument)
(00) - Not present
U2141 - CAN-Bus No Communication with REC (Rear Electrical Centre)
(00) - Not present
Instrument Control Unit
P0460 - Fuel Level Sensor Circuit Range/Performance
(71) - Not present
B0670 - Airbag Telltale Circuit Malfunction
(00) - Not present
B1375 - Switched System Voltage (Ignition ON) Not Plausible with CAN Signal
(04) - Not present
U2113 - CAN-Bus No Communication with SDM (Airbag)
(00) - Not present
(00) - Not present
B3265 - Trunk Release Switch Stuck
(61) - Not present
B3445 - Rear Left Brake Light Circuit Malfunction
(00) - Not present
B3803 - Windows Comfort Closing Circuit Malfunction
(00) - Present
B3878 - Rear Right Brake Light Circuit Malfunction
(00) - Not present
B3881 - Left Tail Light Circuit Malfunction
(00) - Not present
B3882 - Right Tail Light Circuit Malfunction
(00) - Not present
B3883 - Licence Plate Light Circuit Malfunction
(00) - Present
B3884 - Centre Brake Light Circuit Open or High Voltage
(05) - Not present
(00) - Not present
(00) - Not present
Airbag
(00) - Not present
(00) - Not present
(00) - Not present
Underhood Electrical Centre
(00) - Not present
U2141 - ?
(00) - Not present
Engine|Z 16 XEP
P0171 - Fuel Trim System Lean
(52) - Present
P0650 - IPC Message range/Performance (Instrument)
(70) - Not present
U2103 - CAN-Bus Node no Communication
(00) - Not present
  • jE
  • Mesaje scrise: 8,413
din ce vad singura prezenta si relevanta e P0171
Incepe sa citesti de aici: http://www.obd-codes.com/p0171
in rest, da o stergere la erori, si sa vedem care reapar...
  • rhydin
  • Mesaje scrise: 1,369
Este un cod foarte ciudat care cu siguranta da batai de cap.
Cauzele pot fi multiple. M-am confruntat si eu cu el, insa nu prea i-am dat de capat.
Inainte sa fac segmentarea se aprindea cam pe la 1500km. Dupa segmentare sa aprins odata, am mai strans suruburile de la clapeta si de atunci nu am mai avut probleme, Dupa 5000km sa aprins iarasi, ultima data sambata prin Craiova.
Desi facusem inca 200km de atunci in mers normal, martorul nu sa stins decat cu opcom-ul.
Acum ma gandesc sa desfac admisia (acum am si zgomotul celebru de diesel) si dupa ce siliconez sa las macar 2 zile la uscat siliconul, randul trecut nu prea am asteptat decat.... sa zic 2 ore.
Daca nu reusesc nici asa, blindez EGR-ul un timp (apropo cat costa anularea lui din soft?)
  • Georgius
  • Mesaje scrise: 380
  • Cont inregistrat: 12 Sep 2015
Ati rezolvat problema cu B0670-00, B1375-04 si U2201-00 ? Ma confrunt si eu cu aceste erori. Simptone:
- sta dezaburirea pornita tot timpul, l
- ledul de la airbag sta aprins doar pe jumatate ( parca nu are masa) iar la tinerea apasata a butonului de dezaburire( nu ramane stins niciunul din ele) se stinge de tot cel de airbag ( desi dezaburirea nu)
Care sa fie problema. Am tot dat search prin diverse parti, dar nimic sa rezolve.
  • Mesaje scrise: 7,047
B0670 Airbag Telltale Circuit Malfunction
U2201 CAN-Bus No Communication with EHU (Entertainment Head Unit)
B1375 Switched System Voltage (Ignition ON) Not Plausible with CAN Signal
Cred ca ai probleme cu CIM-ul si posibil cu ceasurile.
Incearca sa faci proba cu alt CIM si vezi daca se rezolva.
