- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
- Mesaje scrise: 765
- Cont inregistrat: 28 Sep 2006
- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
- Mesaje scrise: 885
- Masina: Omega 2001 Y22DTH
- Cont inregistrat: 13 Mar 2007
- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
Eu caut in TIS aceasta informatie...totusi nu gasesc! Eu am si tensiunea scazuta, maxim 14 V fara cons si 13,3 cu cons la relanti si ma gandesc sa nu aiba vreo legatura.
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
B-001 DIAGNOSTIC TROUBLE CODE
P1590 Engine Running Signal Low Input
Short to ground or interruption in circuit to control unit terminal 39
Concerned Terminals:
1, 2, 39
Work Order Description
Ignition OFF
Disconnect wiring harness connector from:
Diagnostic tester
Ignition ON
Engine running at idle speed, operating temperature
Increase engine speed to 3000 rpm
Measure voltage between the following terminals:
Battery Voltage (Positive Terminal)
Ground
nominal value 13.5 ... 14.5 V
daca nu corespund datele de mai sus atunci este defect alternatorul G2
daca sunt adevarate atunci
Ignition OFF
K70 Control Unit - Diesel
(Wiring Harness Connector 81P )
Ignition ON
Connect test lamp ( 55 W ) and multimeter in parallel and measure voltage between the following terminals:
Wiring harness connector (wiring harness side) terminal 39 (81P)
Ground
Nominal Value greater than 11 V
daca nu corespund cele de mai sus atunci:
High transition resistance between:
S1 Switch - Starter
Wiring harness connector (wiring harness side) terminal 15
iar de sunt adevarate si corespund
Wiring harness connector (wiring harness side) terminal 1 (81P), 2 (81P)
nominal value: greater than 11 V
daca nici astea nu sunt adevarate atunci :
G1 Battery
Wiring harness connector (wiring harness side) terminal 31
dar daca sunt adevarate
Defective component:
k70 ar fi pompa de injectie sau calculatorul pompei.. mi-e si frica sa aflu exact 😢(
- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
Foarte interesant ce zice la punctul 10) despre rezistenta conductorului/cablului
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
Acum,, pe electric revenind, firele ce ies din alternator sunt 3 si masa pe carcasa. Privim ce pleaca de la G2:
- cel alb-albastru BUWH care duce la instrumente, deci este martorul de baterie;
- cel verde-alb GNWH care duce la siguranta 15 de 20 A;
- cel ROSU RD de + care duce la electromotor M, iar de acolo spre baterie G1 prin fir negru BK la borna de +.
Maine voi uni furtunasele de vid ale solenoidului cu testerul live si voi face poze la firele ce pleaca din alternator. Voi face si o masurare a rezistentei pe siguranta F15...
Cat despre masurarea rezistentei conductorilor iata ce spune TIS:
Vremea a fost cam neprielnica si de aceea nu am reusit azi 😊
- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
p.s. maiandrei ti-a spus sa unesti in cu out ca asa apare la vectra c cand se da eroarea asta
apare de siguranta F15 sau de solenoid valve circuit, dar ma indoiesc ca ar avea vreo legatura cu omega 😊
- deleted-11331
- 740 mesaje
- din 03 Nov 2007
deleted-11331
- Mesaje scrise: 740
- Cont inregistrat: 03 Nov 2007
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
- in schema electrica a EDC avem y28-spin level regulation solenoid valve si y29 boost pressure regulation solenoid valve;
- din tis reiese ca y29 este supranumit si charge pressure regulator solenoid valve, din boost in charge;
- nu inteleg care este y28 si ce face? tis nu imi da detalii si nici schita/poza, ci doar conectorul; sa fie 728 cea de care zice maiandrei?
- i-am trimis poza cu traseul de vacuum si am dedus ca de fapt exista doua recipiente de vid: unul (11) este rezervor si tine de traseul supapelor climei si altul(9) care este vas (vessel) si tine de traseul supapelor din compartimentul motor; banuiesc ca ajuta atunci cand apesi pedala de acceleratie creeand vidul necesar obtinerii boost-ului la turbo? cam asa a inteles ci maiandrei, caruia ii multumesc de timpul acordat 😊
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
- maiandrei
- 4,710 mesaje
- din 20 Dec 2004
- Insignia 2018 B20DTH
maiandrei
- Mesaje scrise: 4,710
- avem (si cei cu Y20DTH) un rezervor de vacuum accesibil tot timpul, care atenueaza scaderile datorate deschiderii diverselor valve;
- aveti (cei cu Y22DTx) inca un rezervor de vacuum accesibil doar la comanda acelei electrovalve. Inregistrand parametrii pe tester se pot determina momentele in care este necesar acest rezervor.
- deleted-11331
- 740 mesaje
- din 03 Nov 2007
deleted-11331
p.s. becul al baterie se aprinde la contact?
