  3. Vectra C/Signum
  • danx2003
  • Mesaje scrise: 13
  • Masina: Vectra 2007 z30dt
  • Cont inregistrat: 14 Mai 2010
opel vectra c 3.0 cdti nu porneste + cod eroare P0093-52
Am un opel vectra c 3.0 cdti, fabricatie 2007, s-a facut update la software de catre reprezentanta, tot ok.
De ceva timp imi aparea eroarea P0093-52 "Common rail pressure is too low", motorul pornea la a 2-3-a cheie dupa care nu a mai pornit deloc. In service la rucom au pornit-o cu spray ul dupa ce au schimbat filtrul de motorina, ceea ce m-a enervat. Deasemenea in mers cand motorul este rece masina tremura, ca si cand nu ar mai avea combustibil sau nu s-ar alimenta.
As dori o parere, unde pot face curatarea pompei injectoarelor etc daca se poatre in craiova, si care ar fi cauzele?
Din ceea ce am studiat, probleme poate fi la pompa de inalta cu SCV sau ceva valve de la common rail.
  • tonytm
  • Mesaje scrise: 4,479
3.0 CDTI-ul mai are probleme cu pompa de motorina.
  • danx2003
  • Mesaje scrise: 13
Pai asta am vazut si la altii pompa de inalte probleme cu suction valve.
Cine ma poate ajuta cu o verificare in Craiova?
  • tonytm
Field Remedy: 1957
Subject: Engine Y30DT, High Pressure Pump - Lack of power during acceleration
Models: Engines: Option:
Vectra-C 2003...2007,Signum 2003...2007 Y30DT| Z30DT,Y30DT| Z30DT
Complaint: Engine lack of power during acceleration. During investigation with TECH2 a pressure drop between actual rail pressure and desired rail pressure is visible.
Cause: Blocked suction control valve (SCV) within the high pressure pump.
Production: Modified production process (earlier changing of manufacturing tools, improved cleanliness) implemented at supplier. Countermeasures were implemented with engine number 69692 (01.09.2006).
Remedy:
Before carrying out Technical Service Bulletin 1957 update ECU with modified software as of TIS 2000-DVD, version 76 (a modified software regarding high pressure diagnosis was implemented, improved DTC: P0093 detection).
If the DTC still occurs refer to the following snapshots in datalist 2 "NOK I". The snapshot shows an increased fuel flow restriction within the fuel feed circuit.
1: desired fuel pressure 2: actuel fuel pressure
We recommend to disconnect the fuel lines from the tank to the filter, blow them by compressed air (in disconnected condition) and finally to replace the fuel filter assembly.
The snapshot in datalist 2 "NOK II" shows a constant drop of actual fuel pressure and identified the suction control valves (SCV) failure.
In case of an identified suction control valves (SCV) failure replace both suction control valves (SCV) of the high pressure pump as discribed below.
Important: - During the complete procedure it is obligated to work in a clean environment. - Prevent contamination at SCV area. Small contaminations, which cannot be seen by eye, can cause major problems on engine performance. Particle size of 0,3 mm, can be already critical! - Do not use gloves. - Do not use SCV in case it has been dropped. - Make sure that pressure in the system is released before loosening the pressure connection pipe between pump and rail. - Disconnect battery after failure checking procedure. Wait for a few minutes before starting SCV replacement procedure in order to prevent any system action.
Dupa cum vezi, problema cu pompa de inalta duce la lipsa de putere, vibratii si mers in suturi la aprox 1500 RPM. Asa facea si la tine?
  • danx2003
  • Mesaje scrise: 13
Am facut urmatorul test:
am desfacut cele 2 furtunase de retur
pe returul de la pompa atunci cand dau la cheie vine foarte multa motorinaiar pe cel de la commmon rail deloc
la ECU am masurat cu op-com in timpul cat dau la cheie: Desired common rail pressure care tre sa fie 33MPA
si actuala presiune care era de 0.50 MPA cu variatii intre 0,20 si 0,60 MPA adica nu face presiune deloc in common rail
am vazut pe net la altii exact remediul de l-ai propus tu mai sus adica ca ar fi SCV (suction contorl valve)
Deasemenea poate fi valva din capatul common rail?
  • tonytm
Te referi la regulatorul de presiune?
a constant drop of actual fuel pressure Daca asa e si la tine e clar. SCV-urile
Regulatorul de presiune moare la 1.7 CDTI
  • danx2003
  • Mesaje scrise: 13
Pai la mine nici macar nu mai porneste motorul nu am de unde sa vad "constant drop" . Econstant drop atunci cad da la electromotor, adica cad dau la cheie presiunea din rampa nu se ridica la presiunea dorita pentru a putea porni motorul.
Nu stiu in schimb unde e localizat valava de presiune din capul common rail. e una cu niste fire la un cap iar in celalt cap al common rail e retulrul, asa cum am spus atunci cand dau la cheie nu iese motorina pe acel retur, iese numai pe returul de la pompa de inalta presiune.
  • tonytm
Trebuie desfacuta pompa. Se va vedea atunci daca sunt blocate valvele.
  • crystinel_oo
  • Mesaje scrise: 82
  • Masina: Vectra 2007 Z19DT
  • Cont inregistrat: 25 Dec 2009
sal eu sunt tot din cr, la ei la opel la reprez poti incerca iar dc nu este un baiat care lucreaza la opel la reprez il cheama sorin si este unul dintre ce-i mai buni de acolo.... este f priceput ar trebui sa vb cu el, 0766.654.852 e nr meu de tel poate te pun in legatura cu el
  • danx2003
  • Mesaje scrise: 13
Il cunosc pe sorin am vb cu el, ii cunosc si pe baietii de la opel.
Problema la simptomele pe care le-am descris pare sa fie SCV , probleme prezentat si in acel remediu. Cauza si mai multe informatii am vazut pe siteul: http://www.oknation.net/blo...009/03/11/entry-3 😭
folositi http://translate.google.com pentru a intelege ceva.
  • danx2003
  • Mesaje scrise: 13
Mi-am facut timp in sfarsit sa repar masina. Am reusit sa schimb cele 2 valve de reglare presiune de pe pompa de inalte, fara sa o dau jos. Deasemenea am schimbat si senzorul de presiune de pe common rail. Am curatat toata instalatia. Tot e in regula.
Intra-devar probleme a fost Field Remedy: 1957
Cum verificati un asemnea motor daca nu porneste: 1. Verificati sa vedeti daca motorul trage aer cand dati la cheie. 2. Verificati codurile de eroare. 3. Cand dati la cheie verificati presiunea in rampa dorita si cea actuala cu ajutorul opcom. 4. Verificati distributia curea lant etc. Curatati instalatia de alimentare/rezervorul. 5. Cand dati la cheie deconectati retururile de la pompa si cel din capatul common rail si vedeti pe care scoate motorina. Puteti deasemnea desface un injector sa vedeti daca da motorina, dar nu are sens.
  • tonytm
Felicitari!
Costuri?
  • danx2003
  • Mesaje scrise: 13
valvele de pe pompa 960 ron iar senzorul , ca sa fiu sigur ca e ok, l-am schimbat 1000 ron. A meritat. Am resetat calculatorul totul merge f normal. Motorul nu mai are un zgomot ciudat, nu mai are ezitari la accelerare, etc. Trebuie neaparat facut si un update de software pt ca altfel poate reveni problema, din cauza ca motorina euro 5 are alte proprietati, produce alta detonatie, iar ECU tre sa stie de aceste lucruri prin update.
  • Cipa
  • 6 mesaje
  • din 10 Oct 2010
  • Vectra 2008 Z30DT
  • Bucuresti
  • Cipa
  • Masina: Vectra 2008 Z30DT
  • Cont inregistrat: 10 Oct 2010
exact acelasi lucru l-am patit si eu cu aceeasi masina. dupa ce mi-au facut cei de la service update la soft,nu a mai facut nici o figura. sincer nu stiu cu ce a ajutat acel update dar...clar e ca totul e ok acum
  • ghibirdic.sorin
  • Mesaje scrise: 289
  • Masina: Vectra 2007 Z30DT
  • Cont inregistrat: 26 Oct 2011
probleme cu un Z30DT 2007 automat
suierat in turatie atat in sarcina cat si pe liber
multumesc pt sfaturi
  • danx2003
  • Mesaje scrise: 13
Fa o scanare pentru coduri de eroare in ECU cu un opcom la cineva. E posibil de la turbo sa fie. Are putere motorul sau nu cand accelerezi? transmisia schimba treptele bine cand o treci pe manual? Ai vreu bec martor aprins in bord?
  • ghibirdic.sorin
Buna ziua, am si eu o problema cu un z30dt . Am schimbat distributia, masina porneste ok merge ok dar imi creste temperatura la apa . Mai exact daca merg normal in trafic nu are obsolut nimic sta acu la 90 fix exact cum statea si inainte de a schimba distributia. Problema este cand merg mai turat si anume dupa 80 90 km/h in acceleratie creste apa la 95 100 si acolo ramane... Precizez ca potneste termocupla...am fost la service unde am schimbat distributia ai ma rog patronu m-a luat tare ca domne e grnutura de chiuloasa. Masina are 102.000 km si pana sa schimb distributia nu a existat aceasta problema. Stand de vorb cu mecanicu care mi a lucrat la masina mi a spus ca ar putea fi pompa de apa, care este noua hepu. Ca pompa la turatie nu face circuitu cum trebuie. Nu stiu ce sa fac ca astia la service o tin pe a lor ca sa schimbe garnitura de chiuloasa. Nu as vrea sa i las sa imi desfaca motoru. Eu nu cred ca are cev garnitura, cred ca nu au fcut ei ceva bine ... Vreu niste sfaturi
  • skipero
  • Mesaje scrise: 458
  • Cont inregistrat: 13 Feb 2011
Intreaba-i daca suporta ei costurile daca nu este din cauza garniturei de chiulasa. Daca sunt seriosi isi asuma responsabilitati, daca nu mergi linistit in alt service mai serios.
  • ghibirdic.sorin
Problema nu este asta, iti dai seama ca nu le dau un leu, ideea este ca nu as vrea sa mi desfaca motoru... As vrea sa mi spuna cineva daca poate fi pompa sau nu... Oricum asta cu garnitura a fost ceva de genu nu e domne vina noastra, e motoru tau... Dar asa subit, pana sa schimb distributia nu se ridica apa nici la 230km/h iar acum imi e frica sa mai bag picioru . Nivelu la ulei e ok, nivelu la apa ok...
  • skipero
Mergi la seful de service si vb cu el si-i zici ca daca nu-ti schimba pompa moca, care are probabil un defect de fabricatie, chemi opc-ul. Daca nu vrea fa-le reclamatie.
  3. Vectra C/Signum
