  2. Discuții generale
  3. Opel vs ...
  • RONY RO
  • Mesaje scrise: 23
  • Cont inregistrat: 12 Jan 2010
Am asistat la niste liniute intre o Corsa 1,2 din 2003 si un Twingo 1,2-16v-75 Cp din 2001.Twingo a castigat de fiecare data.Nu vazusem indeaproape un Twingo niciodata.Este o masina foarte revolutionata pentru perioada ei.M-a surprins placut aceasta masina.Are un sistem de rabatare special al banchetelor care transforma masina intr-un pat imens si perfect de 2 persoane.Mai are un bord total diferit si se pare din ce am vazut ca sunt foarte fiabile,iar trapa acea imensa este bestiala.
  • livcro
  • Mesaje scrise: 4,593
Nu se pot compara...corsa o poti compara cu Renault Clio ca si dimensiuni, pt ca la greutate e chiar mai grea decat clio...corsa C cu motor de 1.2 se invarte pe la 1010 kg..clio...nu are 1 tona.
Twingo e motor cu putina masina..a testat nevasta; e mai mic si decat lupo; daca la o femeie de 48 kg i s-a parut stramt...ca nu are loc in el...
twingo
Make Renault
Model Twingo
Production Year 1993
Country
Designer
Production Number
Model Code
Model Family
Chassis and Dimensions
Chassis Type 4/5S HBK
Number of Doors 3
Wheelbase 2347 mm (92.4 in)
Front Track 1416 mm (55.7 in)
Rear Track 1374 mm (54.1 in)
Length 3433 mm (135.2 in)
Width 1630 mm (64.2 in)
Height 1423 mm (56 in)
Ground Clearance
Length / Wheelbase Ratio 1.46
Weight 812 kg (1788.5 lb)
corsa
Make Opel
Model Corsa 1.2 16v
Production Year 2000
Country
Designer
Production Number
Model Code Z12XE
Model Family
Number of Doors 3
Wheelbase 2491 mm (98.1 in)
Front Track 1429 mm (56.3 in)
Rear Track 1420 mm (55.9 in)
Length 3817 mm (150.3 in)
Width 1646 mm (64.8 in)
Height 1440 mm (56.7 in)
Ground Clearance
Length / Wheelbase Ratio 1.53
Weight 1010 kg (2224.7 lb)
Clio
General Information
Make Renault
Model Clio 1.2 RL/RN
Production Year 1991
Country
Designer
Production Number
Model Code
Model Family
Number of Doors 3
Wheelbase 2472 mm (97.3 in)
Front Track 1362 mm (53.6 in)
Rear Track 1336 mm (52.6 in)
Length 3709 mm (146 in)
Width 1625 mm (64 in)
Height 1395 mm (54.9 in)
Ground Clearance
Weight 825 kg (1817.2 lb)
  • Stefan_BC
  • Mesaje scrise: 2,648
  • Masina: Zafira 2008 Z19DT
fa un chestionar ,parerea mea,oricum merg pe corsa
  • RONY RO
  • Mesaje scrise: 23
Twingo este o masina putin cunoscuta in Romania dar foarte populara in vest.
  • tpdarius
  • Mesaje scrise: 11
  • Masina: Corsa 2001
  • Cont inregistrat: 10 Mar 2010
...dupa cum spunea si Stefan_BC,,,optiunea mea este corsa,arata mult mai bine si se conduce multumitor!
  • RONY RO
  • Mesaje scrise: 23
Aspectul este discutabil.Nu toata lumea are aceleasi gusturi.
  • emr
  • Mesaje scrise: 8
  • Cont inregistrat: 16 Mar 2010
deign-ul la twingo lasa de dorit, mi se pare una dintre cele mai urate masini
  • RONY RO
  • Mesaje scrise: 23
Atunci Agila,Astra Caravan cum mai sunt?Nici Corsa de altfel nu exceleaza la capitolul frumusete.Dar in sfarsit fiecare cu gusturile lui. 😢
  • sabau18
  • Mesaje scrise: 352
  • Masina: Astra 2000
  • Cont inregistrat: 29 Aug 2009
mie mai mult imi place corsa decat twingo
  • RONY RO
  • Mesaje scrise: 23
In vest Twingo a avut un succes nebun.A fost fabricata din 1993 pana in 2008 fara nici o modificare a caroseriei.Acum a fost restilizata dar se pare ca nu mai are acelasi succes.
  • gobelu
  • Mesaje scrise: 975
  • Masina: Astra 2002 z16xe
  • Cont inregistrat: 01 Jan 2009
Mai...twingo asta e ca un tablou de Picasso.
Si mie mi s-a parut urata de tot la inceput,chiar hidoasa dar pe masura ce trecea timpul a inceput sa-mi placa din ce in ce mai mult.
Trapa face toti banii.Cheltuieli de intretinere minime.
  • dodo_13
  • Mesaje scrise: 4,544
  • Masina: Astra 2008 Z19DTH
Clio e in acceasi clasa cu Corsa, Twingo e mai mic. Am condus un Twingo vreo 3 zile prin Italia, e distractie totala. Si acum ma uit dupa ele pe strada cand le vad.
  • Slash
  • Mesaje scrise: 1,057
  • Cont inregistrat: 10 Jul 2008
da, de acord ca e o distractie totala, e o caricatura de masina !
  • dodo_13
Eu vorbesc serios, e foarte distractiv de condus. Sasiul e foarte reusit, la curbe foarte stranse nu derapeaza ci se ridica roata din spate interior, iar directia e foarte naturala, foarte putin asistata. La design nu poti sa ai pretentii, asta e pretul.
  • Slash
Eu nu ma refeream doar la design, e tipic Renault, nu ma atrage.
Cred ca am avut experiente total diferite pe tema asta.
Mai bine mergi cu ocazia decat sa iesi cu ea din oras.
Si exact cum ai zis si tu, comparatia Corsa vs Twingo nu e reala/corecta, sunt clase diferite.
  • ovydyu90
  • Mesaje scrise: 152
  • Cont inregistrat: 16 Apr 2010
Mi se pare foarte urat twingo,niciodata nu mi-a placut,e foarte ciudata...nici macar un bord normal nu are. Nu-mi place deloc. Corsa e mult,mult mai ok.
  • gxg_tm
  • Mesaje scrise: 1,174
  • Masina: Agila 2002 ARY
  • Cont inregistrat: 07 Jan 2008
Mie Twingo cu motorul de 1.4 mi s-a parut la fel de " natural " ca vechea Dacia 1310 . Cand m-am urcat in ea si am dat o tura pe bulevard mi-am adus aminte instant de batrana Dacie pe care o avusem acum cativa ani buni . Recunosc ca Twingo-ul testat nu era intretinut, pe cand fosta Dacie era la zi cu toate 😃 .
Iar de bordul Twingo-ului ce sa mai zici ... e masina pt fete ! 😃
Corsa este un pic peste Twingo , senzatia de masina fiind un pic mai accentuata 😂 .
  • RONY RO
  • Mesaje scrise: 23
Nu a existat Twingo cu motor de 1400.Multora le place sa se bage in seama aiurea si sunt paraleli cu subiectul. 😠
  • alin_tana
  • Mesaje scrise: 260
  • Masina: Vectra 2002
  • Cont inregistrat: 15 Nov 2009
twingo ca aspect nu ma impresioneaza ,dar daca dai o tura cu masina atunci iti dai seama ca trage destul de bine pt cat e de mica... si ca motorizare este cea ce 1.2 60 cp si1.2 75 cp si acum este noul twingo rs cu motor de 1.6 la 130 cp , si pe motorina 1.5 astea le cunosc eu....
  • danywhy
  • Mesaje scrise: 471
  • Masina: Vectra 2003 Z18XE
  • Cont inregistrat: 16 Oct 2009
Masina fuge , e spatioasa ( unii vor ca o masina mica , de oras, sa fie vapor inauntru 😂 ) iar trapa aia face toti banii , e senzatie.
In schimb e urata ca dracu'.
  3. Opel vs ...
