  2. Îngrijire și întreținere
  • andreius
  • Cont inregistrat: 07 Jan 2005
Buna
As dori sa spal si eu motorul la opel astra g 1,7 dti. Ce are trebui sa fac sau la ce ar trebui sa am grija cand merg la spalatorie? Ca am auzit ca e posibil sa nu mai porneasca dupa spalare. Se poate intampla ceva naspa la spalarea motorului? la spalatorii am citit ceva afise de genul ca nu isi asuma responsabilitatea la spalarea motorului. ar putea fi probleme?
  • lucian
  • Mesaje scrise: 368
  • Masina: Astra 2005 Z17DTL
  • Cont inregistrat: 29 Apr 2005
SA STII CA SI EU AM AUZIT DIN DOUA SURSE DIFERITE CXA ARE CEVA ELECTRONICE SI DACA SE ARD AI PUS-O
CHIAR NU STIU DACA SA SPAL SI EU MOTORUL
  • @dyS
  • Mesaje scrise: 747
  • Masina: Astra 1995 C14NZ
  • Cont inregistrat: 27 Jun 2005
La o spalatorie care se respecta nu ar trebui sa existe probleme:) Eu am spalat o (dupa ce au pregatit o, invelind cele expuse riscului) si pot spune ca motorul a iesit curat si fara probleme; l am spalat pt prima oara si pot spune ca am avut ceva emotii, insa masina a pornit la sfert d cheie Smile oricum, intrebati inainte daca cei in masura sa spele masina va protejeaza cele necesare de la motor printr o invelire prealabila in pungi etc etc
  • zafirul
  • Mesaje scrise: 1,443
  • Masina: Zafira 2001 Z18XE
  • Cont inregistrat: 22 Apr 2004
Ia vedeti:
Engine compartment
Areas of the engine compartment that are painted in the same colour as the vehicle must be looked after like any other painted surface.
It is advisable to wash the engine compartment before and after winter and preserve it with wax.
Cover alternator and brake fluid reservoir with plastic sheets before washing the engine.
When washing the engine with a steam-jet cleaner, do not direct the steam jet at components of the anti-lock brake system, air conditioning system, climate control system or the belt drive and its components.
Protective wax that has been applied is also removed during the engine wash. For this reason, have the engine, brake system components in the engine compartment, axle components with steering, body parts and cavities thoroughly preserved with protective wax after the wash.
An engine wash can be performed in the spring in order to remove dirt that has adhered to the engine compartment, which may also have a high salt content.
Check protective wax layer and make good if necessary.
Do not use high-pressure jet cleaners on wheels and tyres.
  • Cali...nV6
  • Mesaje scrise: 519
  • Cont inregistrat: 24 Apr 2004
Eu nu am curajul sa spal motorul la spalatorie. De obicei il "spal" manual cu o carpa umeda.
  • NiceGuy
  • Mesaje scrise: 92
  • Masina: Astra 2001 Y17DT
  • Cont inregistrat: 10 Dec 2004
Sal yo l-am spalat pe al meu cu carpa inmuiata in apa cu putzin dero si a esit boboc si nu am avut probleme la pornire.
P.S. Nu era foarte murdar
  • eu
  • 712 mesaje
  • din 15 Jun 2004
  • Astra 2006 Z16XEP
  • Bucuresti
  • eu
  • Mesaje scrise: 712
  • Masina: Astra 2006 Z16XEP
  • Cont inregistrat: 15 Jun 2004
Si eu prefer sa fac operatiunea asta singur cu o carpa umeda si eventual spuma pentru spalat motoare, dar in acest caz sterg foarte bine apoi furtunele.
Intr-adevar il sterg mai des, ca sa nu apuce sa se imbibe.
  • jonny
  • 483 mesaje
  • din 23 Apr 2005
  • Astra 2001 Z16SE
  • Cluj-Napoca, Romania
  • jonny
  • Mesaje scrise: 483
  • Masina: Astra 2001 Z16SE
  • Cont inregistrat: 23 Apr 2005
si prin locurile mai putin accesibile cum faceti? ca am incercat si eu si nu a iesit mare lucru Sad
  • eu
  • 712 mesaje
  • din 15 Jun 2004
  • Astra 2006 Z16XEP
  • Bucuresti
  • eu
Folosesc o perie subtire, dar cu maner din plastic maleabil. Ajunge cam pe oriunde, sau cel putin pe unde ma intereseaza.
  • JURISTU '
  • Mesaje scrise: 237
  • Masina: Vectra 2001 Z18XE
  • Cont inregistrat: 31 Mar 2005
Pentru spatiile mai greu accesibile se poate folosi cu succes peria aceea de sticle cu care bunica curata borcane ,sticle etc.Are "minerul ' ala de sirma si intra OK peste tot.L-am fixat intr-o bormasina(atentie la centrare!!) si la turatie foarte mica am intrat in toate colturile.In fine,mie imi place sa fie motorul foarte curat. Smile Smile
  • arthurro
  • Mesaje scrise: 832
  • Masina: Omega 1996 X20XEV
  • Cont inregistrat: 15 Aug 2004
eu l-am dus la spalatorie. L-am spalat si a pornit la sfert nu au fost probleme dar dupa ce em iesit pe sosea in 2 min mi s-a aprins check engine si indiferent ce am facut tot nu s-a stins toata ziua. ( a doua zi nu s-a mai aprins dar nici nu voi mai merge sa spal motorul la spalatorie ) Aia s-au chinuit sa acopere capacul delco dar la omega motorizare x20xev este foarte ascuns inspre bord si nu au reusit prea bine. banuiesc ca din cauza asta
  • Silex
  • Mesaje scrise: 152
  • Cont inregistrat: 22 Mar 2005
Eu am fost sambata la o spalatorie (pentru cei din Cluj, e pe Marinescu chiar unde se imparte strada in 2) si mi l-o curatat foarte bine. S-o uitat tipu un pic la motor sa vada nush ce, nu l-o acoperit cu nimic, o dat cu solutie, o lasat un pic, o dat cu spuma, o mai lasat un pic, dupa care jet pana o iesit luna. I-am dat cheie cand o terminat de spalat si o mers brici, fara nici o problema.
Motoru meu era prea jegos ca sa ma chinui sa-l fac eu singur, dar acum sunt mandrul posesor al unu Opela Astra G cu motorul curat. Cool
  • rapiduletul
  • Mesaje scrise: 141
  • Masina: Vectra 2000
  • Cont inregistrat: 12 Jun 2005
Si eu am spalat motorul la spalatorie, fara sa ma gandesc la eventuale probleme dupa, nu a fost acoperit sau protejat nimic si a pornit imediat. Am avut insa probleme dupa ce am ramas impotmolit acum o luna la pescuit.Am fost scos cu un tractor, am trecut prin niste balti cam de juma' de metru, tractorul a facut valuri, si am avut martorul luminos de la aer conditionat (cel galben in forma de rezervor cu o roata dintata in interior) aprins.Am fost la tester si mi-a spus ca am 7 erori si ca ar trebui schimbate toate ventilatoarele.Mi-a resetat si de atunci nu am mai avut probleme.Se pare ca motorul de Astra este destul de sensibil la apa (mie imi ajunsesera valurile pana peste faruri).
  • MadDawg
  • Mesaje scrise: 101
  • Masina: Corsa 2001
  • Cont inregistrat: 08 Feb 2005
Eu spal motorul periodic. Sa va spun cam care este mersul la o spalatorie care se respecta:
1. Protejeaja locurile sensibile.
2. Stropesc motorul cu o solutie degresanta.
3. Spala motorul cu apa fierbinte.
4. Te pun sa pornesti motorul cam 5 min pentru a evita formarea condensului (cauza ca se aprinde Check Engine).
5. Gata. Motorul e curat. Very Happy
  • livcro
  • Mesaje scrise: 4,574
HELP..AM SPALAT MOTORUL
dupa ce am plecat de la spalatorie nu a fost nici o problema..dar a doua zi, cand sa plec de pe loc cu motorul rece...a inceput sa sughita...da rau de tot...i-am dat 2-3 sprituri si si-a mai revenit...m-am chinuit cu el cateva sute de metri cu sughituri si apoi nu am mai avut probleme
Urmatoarea zi (azi)..aceeasi problema
Ma gandesc ca a acumulat o picatura -doua de apa undeva in alimetarea cu en el....masina are aprindere electronica din fabrica (care a fost protejata la spalare si nu s-a udat decat f putin in zona de contact cu motorul...
Ce as putea sa fac? Ce sa demontez si sa sterg?
HELP!
  • edy2172
  • Mesaje scrise: 283
  • Masina: Astra 2002 1,7dti
ptr.livcro...mai mult ca sigur s-a facut condens in capacul delcou .....si acolo trebuie sa desfaci si sa usuci partea din interiorul delcoului......eu am spalat motorul si n-am avut probleme ...... a pornit la sfert si am lasat pornit 5 minute tocmai sa se incalzeasca motorul si sa evapore apa care ar putea face condens .....
  • livcro
multam mult edy...da cica n-am delco...la tine cum se desface..e sistem cu ceva clapete sau e prins cu suruburi?
cica am pornire electronica...o fi avand si asta mecanism din ala rotitor?
HELP
la mine sunt 2-3 suruburi cu cap de imbus steluta si mi-e teama ca dak le desfac o sa dau de comp electrice-electronice...
sa desfac si sa sterg p'acolo ce oi gasi?
  • JURISTU '
NU desfa nimic.Am patit si eu asta anul trecut si am rezolvat-o in 5 minute: trage masina linga o priza de 22 V ,ia un uscator de par si incalzeste cu el bine de tot (pina arde metalul la mina ) capacul de delcou,fisele si in principiu partea de lectronica .In principal DELCOUL.
Daca nu porneste in 5 minute,platesc eu reparatia !!!!!!!! Laughing
  • JURISTU '
Rectific : 220 V
  • roBERT
  • Mesaje scrise: 1,724
  • Masina: Astra 2002 Z20LET
  • Cont inregistrat: 08 Mai 2004
Aviz pentru cei amatori sa spele motorul...
baron a scris: Se pare totusi ca a fost o problema de natura electrica (in urma spalarii motorului) si ca in urma curatirii mufelor si indepartarii apei totul s-a rezolvat.
Recomand ca in perioada care urmeaza dupa ce aceasta operatiune sa aveti in vedere si posibilitatea aparitiei unor probleme
