- livcro
- 4,574 mesaje
- din 22 Jul 2005
- Grandland X 2018 D20DT
- SIBIU-RM. VALCEA
livcro
- Mesaje scrise: 4,574
http://www.happylightshow.de/
http://www.happylightshow.d...id=68&lang=en
Foarte interesant, conectezi un modul in mufa de diagnoza si atat. Uite ce stie sa faca:
Happylightshow 219 for Opel(Vauxhall,Holden,Saturn) Astra H & Zafira B
Daytime Running Lights
Front Fog Lights or Parking Lights can be used as daytime running lights
Diesel Filter
Car shows "df" while diesel filter is regenerating
CHIRP function
Horn sound if car gets locked/unlocked
SPEED LOCK
The car will be closed when faster then 15km/h. Possible options: on / off
Alarm-system-simulation
The LED is blinking, if the car is closed. possible options: on / off
OPC SCAN
The tachometer pointers run till maximum and back (not the fuel pointer)
not always exact synchronously (technical reasons)
"LEAVING HOME" + "COMING HOME"
Lock and unlock the car will activate front and back lights
possible options front lights:
- off
- head lights + side lights
- head lights + side lights + side indicators
- fog lights + side lights
- fog lights + side lights + side indicators
- just side lights
- head lights + fog lights + side lights + side indicators
possible options back lights:
- off
- reverse lights + plate lights
- rear lights + plate lights
- reverse lights + rear lights + plate lights
Time:
10s to 90s
TEMPERATURE-DISPLAY
The temperature will be shown on the small screen below the tachometer (for the kilometers)
You can choose:
- off
- temp. will be shown till 80° + warning at 105°
- temp. will be shown when you push a certain button + warning at 105°
- just a warning at 105°
Car-computer-function
Display functions:
- consumption / 100km
- actual consumption
- actual speed
HAPPYLIGHTSHOW
You can activate different light-shows
(the outer lights shine alternately)
Activation:
The Happylightshow is very easy to install, because it's only being put on the diagnostic link connector (DLC)! Please download the "setup procedure description" and the "mounting guidelines description" as *.pdf file under "description". To download the right file, you have to take a look on the back side of your Happylightshow. You find there a number with your Software Version.
Demp:
1) http://www.youtube.com/watc...p;feature=related
2) http://www.youtube.com/watch?v=LLzV0USSXoE
INTREBARE: Gasim si pe la noi module din astea? Cam la ce preturi?
Diesel Filter
CHIRP function
SPEED LOCK
OPC SCAN
- off
- just side lights
- off
Time:
10s to 90s
TEMPERATURE-DISPLAY
You can choose:
- off
Display functions:
- actual speed
HAPPYLIGHTSHOW
Activation:
Demp:
- Edwin
- 5,989 mesaje
- din 27 Nov 2008
- Zafira 2006 z19dt
- Bistrita-Nasaud
Edwin
- Mesaje scrise: 5,989
- Masina: Zafira 2006 z19dt
