burtik4u
- Mesaje scrise: 58
- Masina: Vectra 1999 x16szr
- Cont inregistrat: 10 Jul 2009
am o problema.. de cateva zile mi se aprinde becul check engine dar doar cand este cald motorul.. dupa ce se raceste, cand pornesc motorul se stinge..
am pus masina la un prieten pe tester si imi apare asa
OP-COM 080805 - PC based diagnostic tool
OP-COM - KW2000 Communication Window> 1996|Vectra-B|Engine|X 16 SZR
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L000036T5061106
RepairShopCodeOrTesterSerialNumber: S001004931
ProgrammingDate: 19961011
systemSupplierECUHardwareNumber: 16202270
vehicleManufacturerECUHardwareNumber 16202299 GG
systemSupplierECUSoftwareNumber: BZKS
systemSupplierECUSoftwareVersionNumber: 0006
exhaustRegulationOrTypeApprovalNumber: D96001
systemNameOrEngineType: X16SZR
Identifier: 0101
Total number of fault codes: 2
P1640 - Quad Driver Module (QDM)
(00) - Not present
P0325 - Knock Signal Circuit
(00) - Not present
imi puteti da o idee ce ar fi?
Ultima modificare facuta de burtik4u la Joi 20 Aug, 2009 10:06 pm
Keyword #1: EF
Keyword #2: 8F
Identifier: 0101
(00) - Not present
(00) - Not present
burtik4u
- Mesaje scrise: 58
- popescu iulian
- 1,400 mesaje
- din 19 Jun 2006
- Antara 2012 A22DMH
- Timisoara
popescu iulian
- Mesaje scrise: 1,400
- Masina: Antara 2012 A22DMH
- Cont inregistrat: 19 Jun 2006
burtik4u
- Mesaje scrise: 58
dusan28
- Mesaje scrise: 1
- Masina: Corsa 2006 z13dt
- Cont inregistrat: 22 Mar 2017
burtik4u a scris:am o problema.. de cateva zile mi se aprinde becul check engine dar doar cand este cald motorul.. dupa ce se raceste, cand pornesc motorul se stinge..
Keyword #1: EF
Keyword #2: 8F
Identifier: 0101
(00) - Not present
(00) - Not present
Keyword #1: EF
Keyword #2: 8F
Identifier: 0101
(00) - Not present
(00) - Not present
Pana la urma ai aflat care e problema ? Si eu am simptome asemanatoare doar ca eu nu am ajuns sa ii fac un test
