- bogdan iab
- 13 mesaje
- din 09 Mai 2009
- Astra 2004 cdti
- Suceava
bogdan iab
- Mesaje scrise: 13
- Masina: Astra 2004 cdti
- Cont inregistrat: 09 Mai 2009
filcea
- Mesaje scrise: 62
- Masina: Astra 2003 Z17DTL
- Cont inregistrat: 28 Jul 2007
- lupu_sandu
- 593 mesaje
- din 25 Aug 2007
lupu_sandu
- Mesaje scrise: 593
- Cont inregistrat: 25 Aug 2007
- bogdan iab
- 13 mesaje
- din 09 Mai 2009
- Astra 2004 cdti
- Suceava
bogdan iab
- Mesaje scrise: 13
- bogdan iab
- 13 mesaje
- din 09 Mai 2009
- Astra 2004 cdti
- Suceava
bogdan iab
- Mesaje scrise: 13
- lupu_sandu
- 593 mesaje
- din 25 Aug 2007
lupu_sandu
- bogdan iab
- 13 mesaje
- din 09 Mai 2009
- Astra 2004 cdti
- Suceava
bogdan iab
- Mesaje scrise: 13
- ionutxxl
- 1,255 mesaje
- din 04 Apr 2008
- Vectra 2004 y20dth
- Suceava
ionutxxl
- Mesaje scrise: 1,255
- Masina: Vectra 2004 y20dth
- Cont inregistrat: 04 Apr 2008
Injectoarele au fost verificate? Debitmetrul ce valoare are la ralanti?
EGR-ul este / a fost curatat?
Date and time>,12/05/2006. 20:39
Workshop information:
Ursu
Selected model>,2004,Astra-G,Engine,Z 17 DTL
Control Unit:
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
Measuring blocks information:
Battery Voltage,13.5 V
Ignition Status,On 12V
APP Sensor 1 (Accelerator Pedal Position),0 %
APP Sensor 1 (Accelerator Pedal Position),0.98 V
APP Sensor 2 (Accelerator Pedal Position),0 %
APP Sensor 2 (Accelerator Pedal Position),0.49 V
Barometric Pressure,97 kPa
Barometric Pressure,3.84 V
Boost Pressure Command,96 kPa
Boost Pressure,98 kPa
Boost Pressure,1.83 V
Mass Air Flow Sensor,367 mg/strk
Mass Air Flow Sensor,2.07 V
Intake Air Temperature,29 °C
Intake Air Temperature,2.49 V
Coolant Temperature,93 °C
Coolant Temperature,0.78 V
Desired Common Rail Fuel Pressure,24.00 MPa
Common Rail Fuel Pressure,24.42 MPa
Common Rail Fuel Pressure,1.02 V
Rail Pressure Control Valve Pulse Ratio,344 %
Engine Speed,850 RPM
Desired Injection Quantity,5.2 mm3
Actual Injection Quantity,5.2 mm3
Injection Pulse,1.1 ms
Pilot Injection Time,0.7 ms
Brake Switch 1,Inactive
Brake Switch 2,Inactive
Clutch Switch,Inactive
Throttle Position Switch,Active
Pulse Ratio Throttle Control Solenoid Valve,13 %
Pulse Ratio Boost Pressure Solenoid Valve,95.0 %
Swirl Plate Position Switch,Inactive
Swirl Level Control Solenoid Valve Pulse Ratio,90.0 %
EGR Position Feedback (Exhaust Gas Recirculation),0.4 %
EGR Position Feedback (Exhaust Gas Recirculation),0.86 V
EGR Pulse Ratio (Exhaust Gas Recirculation),90 %
Capacitor Voltage 1,797.0 V
A/C Information Switch (Air Conditioning),Inactive
A/C Relay (Air Conditioning),Inactive
A/C Pressure (Air Conditioning),620 kPa
Fan Relay 1,Inactive
Fan Relay 2,Inactive
Glow Time Relay,Inactive
Diagnosis Glow Time Relay,Active
Glow Time Telltale,Off
Service Vehicle Soon (SVS) Indicator,Off
Malfunction Indicator (MI),Off
Cruise Control Tip Switch,Not Programmed
Vehicle Speed,0 km/h
Immobiliser Function Programmed,Yes
Security Wait Time,Inactive
- bogdan iab
- 13 mesaje
- din 09 Mai 2009
- Astra 2004 cdti
- Suceava
bogdan iab
- Mesaje scrise: 13
