- iulius
- 1,798 mesaje
- din 09 Jun 2004
- Insignia 2019
iulius
- Mesaje scrise: 1,798
- Masina: Insignia 2019
Se pare ca sunt mai multe tipuri :
1.cu pornire din telecomanda
2.cu pornire de la un ceas programator
3. cu pornire automata (cazul meu) .
este normal sa iasa un abur pret de citeva minute de se uita lumea la mine ca mi-a luat foc masina?
- naniacostin
- 1,265 mesaje
- din 01 Mar 2007
- Astra 2000 x20dtl
naniacostin
- Mesaje scrise: 1,265
- Masina: Astra 2000 x20dtl
- Cont inregistrat: 01 Mar 2007
- iulius
- 1,798 mesaje
- din 09 Jun 2004
- Insignia 2019
iulius
aici avem un caz particular Omega Diesel 2,2 DTH cu sistem automat de pornire (daca era manual nu mai intrebam ca stiam cum sa-l programam) montat pe o masina de lux, dar daca te uiti la masina zici ca este un Trabant din ala cu toba in fata asa scoate fum (pret de citeva minute) nu cred ca neamtul a facut asa ceva la Opelul de top din acea vreme. daca stie cineva cum porneste si se opreste asta, bine, daca nu ...asta este. daca la masinile lor chiar cu programator dar DIESEL acesta scoate mult fum?ca un fel de abur si destul de suparator.
Asta scrie in TIS
General Description (Webasto System)
Use of the Water-Heating Unit
Note: The water-heating unit serves, combined with the vehicle's own heating system
to heat the interior of the vehicle
to defrost the vehicle windows
to preheat water-cooled engines
The water-heating unit works independently of the vehicle engine and is connected to the cooling system, the fuel system and to the electrical system of the vehicle.
Caution
Before switching on or preprogramming the heating mode, set the heating lever of the vehicle - if present on the vehicle - to "HOT" (maximum position) and the fan to "slow mode" (low power consumption). If vehicles have automatic heating, before switching off the ignition, turn the heating lever to "MAX" and the flap position required to "OPEN".
Note: It is essential to read the operating instructions before using the heating unit for the first time. The equipment must be installed in accordance with the installation instructions.
The heating unit may not be installed in the passenger area of vehicles.
Installations which have not been approved will result in the cancellation of the General Design Approval for the heating unit and therefore of the General Operating Permit for the vehicle. The same applies to repairs which are not undertaken correctly or not using original spares.
Heating units, which state diesel or petrol as the fuel on the type plate, may not be operated with VME (vegetable methyl ester).
The overview of components is to be found in the respective description of the individual vehicle types.
daca citim pagina de defecte vedem ca fumul alb nu prea este in regula. dar nu am nicio eroare.
- shaftt24
- 813 mesaje
- din 18 Dec 2007
- Omega 2001 2200
- Timis
shaftt24
- Mesaje scrise: 813
- Masina: Omega 2001 2200
- Cont inregistrat: 18 Dec 2007
- comnic5
- 193 mesaje
- din 27 Jul 2006
- Omega 2001 y22dth
- Spania
comnic5
- Mesaje scrise: 193
- Masina: Omega 2001 y22dth
- Cont inregistrat: 27 Jul 2006
renascut
- Mesaje scrise: 1
- Masina: Zafira 2001 2,0 dti
- Cont inregistrat: 11 Feb 2008
- antonescu mihai
- 24 mesaje
- din 05 Jul 2008
- Vectra 2000 x20dth
antonescu mihai
- Mesaje scrise: 24
- Masina: Vectra 2000 x20dth
- Cont inregistrat: 05 Jul 2008
- MIMul
- 532 mesaje
- din 12 Jul 2008
- Astra 2003 z16xep
MIMul
- Mesaje scrise: 532
- Masina: Astra 2003 z16xep
- Cont inregistrat: 12 Jul 2008
Sa nu iti faci griji pentru fumul alb(pana porneste),pentru ca asa se intampla la toate care sunt pe motorina.
Incearca sa mergi cu ea la vreun service Opel.
Daca porneste si se opreste dupa cateva minute(3-4 min) e posibil sa fie ceva infundat la ea(de ex. evacuarea).
Exista Webasto si pe motoarele pe benzina(Omega) nu?
- shaftt24
- 813 mesaje
- din 18 Dec 2007
- Omega 2001 2200
- Timis
shaftt24
- MIMul
- 532 mesaje
- din 12 Jul 2008
- Astra 2003 z16xep
MIMul
- deleted-11331
- 741 mesaje
- din 03 Nov 2007
deleted-11331
- Mesaje scrise: 741
- Cont inregistrat: 03 Nov 2007
- Peterr
- 408 mesaje
- din 09 Jun 2008
- Astra 2010 Z18XER
- Cluj
Peterr
- Mesaje scrise: 408
- Masina: Astra 2010 Z18XER
- Cont inregistrat: 09 Jun 2008
- MIMul
- 532 mesaje
- din 12 Jul 2008
- Astra 2003 z16xep
MIMul
- shaftt24
- 813 mesaje
- din 18 Dec 2007
- Omega 2001 2200
- Timis
shaftt24
- shaftt24
- 813 mesaje
- din 18 Dec 2007
- Omega 2001 2200
- Timis
shaftt24
ca sa demontez tre sa dau jos bara fata,pt ca dupa cum m-am uitat nu prea aveam acces la el!am vazut ca e o mufa de curent bagata atat!si dupa cate am inteles are si o bujie in interior!
a mai desfacut cineva sirocol?
remus81
- Mesaje scrise: 77
- Masina: Vectra 2006 Z19DT
- Cont inregistrat: 11 Jul 2009
- Gabello
- 1,148 mesaje
- din 11 Mai 2009
- Astra 2001 y1,7dti
- Giurgiu
Gabello
- Mesaje scrise: 1,148
- Masina: Astra 2001 y1,7dti
- Cont inregistrat: 11 Mai 2009
- comnic5
- 193 mesaje
- din 27 Jul 2006
- Omega 2001 y22dth
- Spania
comnic5
- Gabello
- 1,148 mesaje
- din 11 Mai 2009
- Giurgiu
Gabello
- Gabello
- 1,148 mesaje
- din 11 Mai 2009
- Giurgiu
Gabello
