viarma
- Mesaje scrise: 5
- Cont inregistrat: 21 Nov 2008
am facut eu un test agrafa si mia dat vreo 9 erori.
le voi scrie aici si daca ma poate ajuta cineva sa pornesc masina asta va sunt recunoscator,
ERORI:IN ORDINEA IN CARE MI LE DA:85;61;56;52;17;29;19;34;24 incepe cu 12 si se termina cu 12.
MULTUMESC ANTICIPAT
- thrill
- 859 mesaje
- din 29 Jul 2008
- Vectra 2003 z18xe
thrill
- Mesaje scrise: 859
- Masina: Vectra 2003 z18xe
- Cont inregistrat: 29 Jul 2008
85 Immobiliser Wrong signal
61 Fuel tank vent valve (FTVV) Low voltage
56 Air control soleniod Low voltage
52 Secondary air pump relay Low voltage
29 Fuel pump relay Low voltage
19 Crank Angle Sensor (CAS) Incorrect RPM signal
34 Manifold Absolute Pressure (MAP) sensor Low voltage
24 Vehicle Speed Sensor (VSS) No speed signal or low voltage
- CATA26BCN
- 680 mesaje
- din 25 Sep 2007
- Astra 2002 Y17DT
CATA26BCN
- Mesaje scrise: 680
- Masina: Astra 2002 Y17DT
- Cont inregistrat: 25 Sep 2007
viarma
- Mesaje scrise: 5
AI VREO IDEE CUM ANULEZ CIPURILR;?
MERSI PENTRU RASPUNS....
- drivergabriel
- 2 mesaje
- din 02 Jul 2008
- Signum 2003
drivergabriel
- Mesaje scrise: 2
- Masina: Signum 2003
- Cont inregistrat: 02 Jul 2008
Se poate pune imoo off...
viarma
- Mesaje scrise: 5
- drivergabriel
- 2 mesaje
- din 02 Jul 2008
- Signum 2003
drivergabriel
- Mesaje scrise: 2
