- gabriel88_vl
- 152 mesaje
- din 21 Sep 2008
- Agila 2004 z12xe
- Valcea
gabriel88_vl
- Mesaje scrise: 152
- Masina: Agila 2004 z12xe
- Cont inregistrat: 21 Sep 2008
- deleted-3101
- 355 mesaje
- din 01 Sep 2006
deleted-3101
- Mesaje scrise: 355
- Cont inregistrat: 01 Sep 2006
High-end, high-performance motor oil with
Aral Synth-Technology.
• Saves fuel and prevents the environment
• Most reliable lubrication even at high
temperatures
• Very good protection against wear
• Very fast lubrication of entire engine at
cold starts
Performance reserves are maintained, especially
under demanding driving conditions, even when
used with extended oil change intervals and in
engines with very low oil consumption. Suitable
for almost all four-stroke gasoline and diesel
engines (incl. turbo-charged engines).
Specifications/Certifications:
• ACEA A3, B3, B4
• API SJ/CF
• VW Norm 502 00 and 505 00 (01/97)
• MB Service Bulletin 229.3
• Porsche
• BMW (Longlife Oil List)
• Opel GM-LL-B-025"
Faptul ca are certificarea GM pentru diesel, nu inseamna ca uleiul este numai pentru diesel.
- gabriel88_vl
- 152 mesaje
- din 21 Sep 2008
- Agila 2004 z12xe
- Valcea
gabriel88_vl
- gabriel88_vl
- 152 mesaje
- din 21 Sep 2008
- Agila 2004 z12xe
- Valcea
gabriel88_vl
Ma pregatesc pentru revizia de 15.oookm(desi mai am 4.500km) si am sa ma orientez spre noul Castrol EDGE 0w30 - API:SM/CF , filtru de ulei de la FRAM fara supapa suplimentara de bypass sau in caz ca nu gasesc merg pe varianta de filtu de la Purolator . Nu recomand filtre de la Mahle , Mann , Champion deoarece au supapa suplimentara de bypass care nu lasa bypassul "original" sa'si faca treaba .
P.S. Dane pune si Z14XEP in titlu sa vada mai rapid cei interesati .
Dar la o vectra B din 1996 ( cea din semnatura ) ce filtru de ulei e recomandat? CU sau FARA supapa suplimentara de bypass ?
aurick86
- Mesaje scrise: 16
- Masina: Vectra 1997
- Cont inregistrat: 15 Oct 2008
nu stiu daca am voie cu link-uri .. ?!?! (rog sa ma anuntzati daca nu am voie)
oricum uite ce scrie aici : The Engine Oil Bible
asta e partea importanta : "to ensure that you do not over clean your engine and lose compression for example. Generally speaking, an SAE 15W/40 diesel engine oil for about 500 miles"
daca zici ca ai facut deja 6000 km.. cred ca e nasol...
sa anunti ce ai rezolvat
- gabriel88_vl
- 152 mesaje
- din 21 Sep 2008
- Agila 2004 z12xe
- Valcea
gabriel88_vl
Vechiul ulei Aral High Tronic SAE 5W-40 nu este de disel neaparat doar ca nu avea specificatia benzina la opel.
Pentru sezonul cald(vara) ce ulei sa bag cu specificatie de opel benzina? Vara as vrea mai gros ceva dar nu este nici unul cu specificatie opel benzina si o sa vad daca il papa pe asta de acuma ca daca nu il papa merg cu el si vara.
- gabriel88_vl
- 152 mesaje
- din 21 Sep 2008
- Agila 2004 z12xe
- Valcea
gabriel88_vl
- gxg_tm
- 1,174 mesaje
- din 07 Jan 2008
- Agila 2002 ARY
gxg_tm
- Mesaje scrise: 1,174
- Masina: Agila 2002 ARY
- Cont inregistrat: 07 Jan 2008
crazy
- Mesaje scrise: 61
- Masina: Vectra 1998 x18xe
- Cont inregistrat: 24 Jun 2010
Ultima modificare făcută de crazy la Lun 01 Nov, 2010 11:00 pm
- gxg_tm
- 1,174 mesaje
- din 07 Jan 2008
- Agila 2002 ARY
gxg_tm
crazy
- Mesaje scrise: 61
- genutzu
- 164 mesaje
- din 09 Nov 2010
- Vectra 1996 x16xel
- Vaslui
genutzu
- Mesaje scrise: 164
- Masina: Vectra 1996 x16xel
- Cont inregistrat: 09 Nov 2010
- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
- Mesaje scrise: 885
- Masina: Omega 2001 Y22DTH
- Cont inregistrat: 13 Mar 2007
- gxg_tm
- 1,174 mesaje
- din 07 Jan 2008
- Agila 2002 ARY
gxg_tm
- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
