  2. Discuții generale
  • virgil
  • Mesaje scrise: 273
  • Masina: Astra 2002 Y17DT
  • Cont inregistrat: 12 Mar 2005
de cateva zile citesc si nu reusesc sa ajung la final....
se pare ca unii chiar au talent la povestiri... reale sau nu....
http://forum.oltcit.ro/view...r=asc&start=0
  • arthurro
  • Mesaje scrise: 832
  • Masina: Omega 1996 X20XEV
  • Cont inregistrat: 15 Aug 2004
😂 Da, tare intr-adevar!
  • maiandrei
  • Mesaje scrise: 4,710
😂 chiar merita citit!
  • Kappy
  • Mesaje scrise: 290
  • Masina: Vectra 1993 C20NE
  • Cont inregistrat: 23 Feb 2005
Da intradevar tari rau povestile 😃 ....chiar daca nu prea cred sa fie adevarate 😉 .
Oricum toate laudele pt ala ca a scris un post.....cat postu pastelui 😂
  • roBERT
  • Mesaje scrise: 1,724
  • Masina: Astra 2002 Z20LET
Merita sa le citesti 😊
  • Mircea KDT
  • Mesaje scrise: 336
  • Cont inregistrat: 11 Jan 2005
Bai nene nu am mai ras asa de cam multicel....
Are talent baiatu''
  • dragos_itd
  • Mesaje scrise: 70
  • Masina: Vectra 2003 Y20DTH
  • Cont inregistrat: 20 Oct 2004
daaa ... omu are vrajeala multa ... dar s-a gandit bine/ e destul de tare faza
  • rapiduletul
  • Mesaje scrise: 141
  • Masina: Vectra 2000
  • Cont inregistrat: 12 Jun 2005
Era un post gresit, scuze 😳 , pt cine are rabdare sa vada aici : http://www.level.ro/phpBB2/...r=asc&start=0
PS: merci @florinike
Ultima modificare făcută de rapiduletul la Mar 28 Jun, 2005 8:39 pm
  • rivo
  • Mesaje scrise: 81
  • Masina: Vectra 1994 C20NE
  • Cont inregistrat: 27 Mai 2004
O RECLAMA LA OPEL
http://www.rivo.as.ro/opel/bendy2.wmv
(nu am gresit locu de postare ...doar nu am cautat altu ) 😂
  • Slick
  • Mesaje scrise: 1,319
  • Masina: Astra 2004 Z20LET
Transportation
Romania's secondary export consists of a very peculiar vehicle (miraculously produced there, since the country has no economy) called the Dacia.
The Dacia is a very special form of transportation and might even become, in the future, an alternative to ecological engines powered by electricity or fuel cells, since it seems to be entirely propelled by curses. Curses are also required for maintenance, because changing oil or a faulty spare part has no effect on the functioning. On the contrary, saying to it rabla dracu, or, in extreme cases tutzi mortzii matii de fieratanie! would always work.
If, by any means, the above methods don't work, you can always push it.
If, by any means, the above methods don't work, you can always take a train. There are four types of trains in romania - the personal trains (very appreciated for the luxury they provide, also known as "cruise trains"), the accelerated trains (they ussualy provide the same luxury as the personal trains, but they are going faster), the rapid trains (theese trains are faster, but built for the ciobani to transport their sheep), and the intercity trains (they are the trains used by navetisti to travel across the country. the most filthy trains of all).
Mechanic
Romania's mechanics are mythical creatures which is said can produce gold/money without moving a muscle.
They can still be seen around the country lying in the sun all day talking/complaining about the weather, which is NEVER suited for work.
Still, they seem to possess strange hypnotic powers which make people pay them money for nothing. They are often associated with the term "gunoi" (nice person), or "jeg" (god).
😂 sursa si in +
http://uncyclopedia.org/wik..._of_Romania#Dacia
  • ktapet
  • Mesaje scrise: 483
  • Masina: Zafira 2007 Z19DT
  • Cont inregistrat: 13 Mai 2005
http://www.resursadefun.ro/...enta-excesiva.htm
  • dodo_13
  • Mesaje scrise: 4,544
  • Masina: Astra 2008 Z19DTH
http://uncyclopedia.org/wiki/Logan
  • maxone
  • Mesaje scrise: 42
  • Cont inregistrat: 09 Jul 2004
Bai nene ce caterinca cu Logan-ul!!!
  • King of the road
  • Mesaje scrise: 489
Hehe
Ia uitati ce am gasit eu pe net ... probabil ca multi stiti deja dar pentru ceilalti da-ti Right Click -> Save Target As ... : becaly.mp3 - 4.6 MB
  • malex
  • Mesaje scrise: 101
  • Masina: Astra 2004 Z16XE
  • Cont inregistrat: 22 Nov 2004
Kata, a fost publicat chiar pe "revistapresei.ro" ...
Si oricum, altceva decat sa facem publicitate creaturilor cu muci in loc de creier, nu putem?
Bafta
  • Jacks
  • Mesaje scrise: 175
  • Cont inregistrat: 21 Mai 2005
se pare ca genul astia de oameni ne conduc tara de mai bine de 15 ani si atunci ce pretentii mai putem avea. sloganul laasaaaneeee nu prea il inteleg astia
  • livcro
  • Mesaje scrise: 4,593
sa punem bancuri cu masini?
  • io
  • Mesaje scrise: 284
  • Cont inregistrat: 18 Jan 2005
http://www.endofworld.net/
  • livcro
din analele dacia club:
user 0:Nu se mai aprind luminile de frane. se aprind pozitiile, merge semnalizarea dar franele nu se mai aprind (nici becul de pe eleron). am schimbat siguranta, am desfacut stopurile , am curatat contactele si nimic. ce e de facut ? chiar trebuie sa ma duc in service pt chestia asta ?
Mersi.
user1 :La pedala de frana ai un intrerupator (cine credeai ca iti aprinde efectiv stopurile ? ) ... verifica-l pe ala ..
user 0:Unde se afla exact pozitionat intrerupatorul asta ? cum ajung la el ?
user 2:Deschizi usa la masina
Te lasi in genunchi in afara masinii
Bagi capul in masina rotindu-l usor spre stanga
Continui sa te apleci in fata intr-un unghi de cca 45 grade cu restul corpului
Cand ajungi la o distanta de cca 20 cm de pedala de frana aprinde o lanterna pe care in prealabil o tii in mana dreapta. e bun si un lampas de miner
Daca e lumina afara nu ai nevoie de lantena
Nici de lampas
te uiti bine la cele 3 pedale.
Numeri temeinic de la dreapta la stanga si de la stanga la dreapta pt a o identifica pe cea de-a doua.
Daca nu-ti iese numaratoarea ai un hint! E aia din mijloc!
TE uiti in partea de sus a pedalei.
Partea de sus e opusa alei de jos pe care apesi tu cu piciorul.
Partea de jos e aia mai lata si murdara!
o sa vezi intrerupatorul
Este divulgat de 2 fire care se infig in el!
Daca se infige doar 1 infige-l si pe celalalt
Celalalt e ala care atarna
Daca nu e nici un fir infipt infigele tu pe ambele!
Dar nu uita sa verifici daca s-a rezolvat problema!
Pentru asta>
Pornesti motorul
Apesi pedala de frana temeinic
Apoi fugi repede la spatele masinii sa vezi daca sunt aprinse stopurile!
Daca nu sunt aprinse e clar! E de la catalizator!
TE duci la service si insisti sa-ti schimbe catalizatorul ca nu ti se aprinde frana!
Orice ar spune tu insista!
user 0:ai uitat un lucru ! nu mi-ai zis pe care dintre usi trebuie sa o deschid: p-aia din stanga sau p-aia din dreapta ??? din fata sau din spate ? hai sarbane, inca putin efort, te rog...
user 2:Ma...uite..de 10 minute ma chinui sa-mi aduc aminte...
Da' recunosc ca am uitat!
Aaaa..gata!
LE deschizi pe toate ca sa se faca curent ca doar la tine asta e problema, nu vine curent la becurile de la stopurile de frana!
Asta era!
Toate deschise si mergi cu ele asa!
SI ca sa revenim!
Probabil ca ori ai agatat cu varful pantofului o mufa si ai scos-o ori..mai rau..ai rupt vreun fir!
Crezi ca e nevoie sa-ti explic si cum se lipeste un fir rupt?
Nu de alta da' tre sa fac o temeinica informare in prealabil
alta:
Citat genial dintr-un clasic in viata:
"-Merge prost la relanti, asa e facuta ea?"
"-Nu, ea e facuta sa mearga prost la orice turatie!"
(numele are mai putina importanta, ca de altfel si masina la care se refera)
alta
Na ca m-ati pus pe ganduri.
Acu vreo 2 zile m-am dus si eu cu Loganul cel nou sa alimentez la OMV ca am auzit ca e buna. M-am invartit pe acolo, la pompa aveau 95 fara pb si 95 premium cu nu stiu ce aditivi smecheri. Acu eu am gandit cu cat mai scumpa cu atat mai bine si am bagat vreo 12 l de aia premium dar m-am chinuit ca nu prea intra nici pistolul (era un plastic ceva la intrarea in rezervor) si tot scapa manerul. Stiam ca trebuie fara plumb dar nu mi-am imaginat ca premium o fi cu pb.
Si am mai mers cu ea de atunci, merge bine, n-am simtit diferente desi parca consuma ceva mai mult sau sunt eu care merg numai peste 3000 (hmmm).
Acu stie cineva, aia ECO Premium de la OMV e cu pb sau fara?
Si daca e cu, cat de tare am belit-o? (N-am nici 1000 km ( ).
Pls, help?
Ultima modificare făcută de livcro la Mar 16 Aug, 2005 1:31 am
  • kapix
  • Mesaje scrise: 681
  • Masina: Astra 2002 Z16XE
  • Cont inregistrat: 15 Jan 2005
e beton faza. Cel mai tare e finalul, cu catalizatorul. 😂 😂 😂
Imi aduce aminte de instructorul meu de la scoala de soferi. Nu gaseam a I-a si imi zice el pe un ton disperat - opreste repede motorul...scoate cheile incet din contact...trage repede capota...da-te jos si vezi sa nu fi cazut de de la loc, ca putem sa o pierdem pe drum.
Si vazand ca mi-era ciuda ca o muscasem original, imi povesteste o faza asemanatoare. Am s-o scurtez cat mai mult, ca e greu de povestit in scris.
Pregatea pe cineva pentru examenul de a doua zi. Si partea cea mai grea - parcarea laterala sau cu spatele, nu mai retin exact. Totul merge bine, mai putin maneta care nu vrea sa intre in marsarier (circumstante atenuante - maneta era modificata, ajungea pana la volan - pt cei care au mai pus mana pe masina inainte era un chin, dar nu era cazul...). Instructorul foarte serios - mai mult ca sigur s-a stricat iara marsarierul. Elevul sa nu taca il intreaba ce e de facut, ca el are maine examen...
In parcarea respectiva erau mai multe masini de scoala (de acolo se pleca cu Politia si multi exersau parcarile acolo). Instructorul ii arata o masina si il trimite pe cursant la celalalt instructor, cu rugamintea sa ii imprumute putin marsarierul, numai pana exerseaza niste parcari, ca al lor e defect si maine e examenul. Bineinteles ca celalalt nu putea sa vorbeasca de ras, iar elevul insista ca nu e deloc de ras, ca nu a mai facut parcari... ca daca il pune a doua zi politistul si el nu stie... ca il roaga frumos prientenul lui X (care radea in cealalta masina)...
Nu stiu cat haz are povestea scrisa aici, dar eu cand am auzit-o am uitat de tapa pe care am luat-o de jumatate si mi-o amintesc de cate ori aud cuvantul marsarier.
