kikiroz
- Mesaje scrise: 7
- Cont inregistrat: 09 Aug 2005
multumesc anticipat
- elegance
- 3,073 mesaje
- din 31 Jul 2006
- Astra 2000 Y 17 DT
- Cluj
elegance
- Mesaje scrise: 3,073
- Masina: Astra 2000 Y 17 DT
Remove, Disconnect
Fan cover or hang fan shroud over air vane.
Visco fan-See corresponding operation.
V - belt for compressor - on vehicles with air conditioning.
V - belt for oil pump and alternator.
Chrankshaft pulley - counterhold ussing KM- 517.
Remove, Disconnect
M - 289, washer (A) and screw (B) of crankshaft pulley - to seal timing gear case.
Remove, Disconnect
Coolant hoses from watter pump and thermostat housing (arrows).
Remove, Disconnect
Watter pump from timing gear case.
Clean sealing surfaces.
Install, connect watter pump with new sealing ring.
Tighten (torque) Watter pump bolts - 15 Nm / 11 lbf ft.
Install, connect Coolant hoses.
Important! The layout of hose clamps shown in illustration must be followed exactly. Incorrectly mounted hose clamps can lead to serious engine damage.
Tighten (torque) Hose clamps - 4 Nm / 3 lbf ft.
Remove, disconnect
KM - 289, washer (A) and screw (B) from timing gear case.
Install, connect crankshaft pulley.
Tighten (torque) Crankshaft pulley bolt - 120 Nm / 89 lbf ft.
Install, connect
V - belts and tension - see corresponding operation.
Visco - fan - see corresponding operation.
Fan shroud above fan.
Fan cover.
Top up and bleed cooling system - see corresponding operation.
kikiroz
- Mesaje scrise: 7
