- MStanescu829
- 6 mesaje
- din 16 Jun 2022
- Astra 2002 Y17dt
- Braila
MStanescu829
- Mesaje scrise: 6
- Masina: Astra 2002 Y17dt
- Cont inregistrat: 16 Jun 2022
Acesta este codul intreg primit de la tester. p1125 critical system malfunction 2 (refer to checking procedure: trouble code description)
MODEL: Astra 2002
MOTOR: Y17dt
- DRosiuoru
- 382 mesaje
- din 08 Mar 2022
- Insignia 2010 A20DTH
- Arad
DRosiuoru
- Mesaje scrise: 382
- Cont inregistrat: 08 Mar 2022
- iulian1971
- 7,053 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
- Mesaje scrise: 7,053
- MStanescu829
- 6 mesaje
- din 16 Jun 2022
- Astra 2002 Y17dt
- Braila
MStanescu829
- Mesaje scrise: 6
- DRosiuoru
- 382 mesaje
- din 08 Mar 2022
- Arad
DRosiuoru
Y17DT Y17DTL 1.7DTi
Opel Astra G
Vauxhall Astra MK4
Vacuum lines
EGR valve
MAP sensor / manifold absolute pressure
BAR sensor / barometric pressure
Crankshaft sensor / Crank
EDU
Fault codes:
P0400 (5)
P1125
P0370
- MStanescu829
- 6 mesaje
- din 16 Jun 2022
- Astra 2002 Y17dt
- Braila
MStanescu829
- Mesaje scrise: 6
Keyword #1: EF
Keyword #2: 8F
Setare timpi de parametri normali
Numãr ºasiu VIN: W0L0TGF35Y8132464
CodAtelierSauNumarTester: S001000998
Data de programare: 20010817
systemSupplierECUHardwareNumber: DEL 0113363020
vehicleManufacturerECUHardwareNumber 97231405 DG
systemSupplierECUSoftwareNumber: DHCR
systemSupplierECUSoftwareVersionNumber: 0004
exhaustRegulationOrTypeApprovalNumber: D00021
NumeSistemSauTipMotor: Y17DIT
Identificare: 1301
Data de fabricatie: HDRC17RL
Valori reale:
Stare aprindere,Conectat 12V
Tensiune baterie,13.8 V
Releu principal,Activ
Releu pentru dozator injecþie,Activ
Semnal senzor poziþie pedalã,0.0 %
Senzor 1 pedalã acceleraþie,0.64 V
Senzor 2 pedalã acceleraþie,0.32 V
Contact virtual de ralanti,Activ
Contact virtual clapetã complet deschisã,Inactiv
Senzor masã aer,1.88 V
Senzor masã aer,30.3 kg/h
Presiune turbo,2.33 V
Presiune turbo,102 kPa
Comandã -Presiune turbo,100 kPa
Presiune barometricã,4.82 V
Presiune barometricã,101 kPa
Temperatura aer admisie,2.78 V
Temperatura aer admisie,36 °C
Temperaturã lichid rãcire,1.00 V
Temperaturã lichid rãcire,89 °C
Temperatura combustibil,42 °C
Contact 1 fârnã,Inactiv
Contact 2 frânã,12V inactiv
Contact ambreiaj,Inactiv
Presiune ulei,Normal
Comutator info climã,Activ
Presiune sistem climã,720 kPa
Codare climã,Clima a fost detectatã
Inceput de injecþie real,17.0 grade
Cantitate injectatã,5 mg/cursã
Factor de umplere la ventil de reglaj pres. turbo,0.0 %
Factor de umplere AGR,75.0 %
Turaþie pompã,449 RPM
Turaþie motor,900 RPM
Turaþie prescrisã,900
Releu preâncãlzire,Inactiv
Releu climã,Inactiv
Impuls vitezã vehicul,Nu primeºte
Vitezã vehicul,0 km/h
Martor(Check Light),Deconectat
Martor timp de preâncãlzire,Decon.12V
Diagnostic releu preâncãlzire,Inactiv
Temperatura externã,-35 °C
- MStanescu829
- 6 mesaje
- din 16 Jun 2022
- Astra 2002 Y17dt
- Braila
MStanescu829
- Mesaje scrise: 6
- DRosiuoru
- 382 mesaje
- din 08 Mar 2022
- Arad
DRosiuoru
A doua : mi se pare cam mare valoarea aici - Senzor masã aer,30.3 kg/h ( masina nefiind in sarcina ) . Posibil din cauza primei probleme .
Rezolva problema cu senzorul de temperatura exterioara si vezi dupa .
- MStanescu829
- 6 mesaje
- din 16 Jun 2022
- Astra 2002 Y17dt
- Braila
MStanescu829
- Mesaje scrise: 6
DCalota
- Mesaje scrise: 5
- Masina: Astra 2000 Y17DT
- Cont inregistrat: 03 Dec 2022
