criste
- Mesaje scrise: 79
- Masina: Astra 2011 A17DTJ
- Cont inregistrat: 08 Oct 2016
Am o Zafira A 2001, 1.6 16v Z16XE care imi da urmatoarele coduri de eroare pe tester:
P1120 - Accelerator Pedal Position Sensor 1 Voltage Low
(02) - Not present
P1550 - Limp Home - Electronic Throttle Control Limited Performance
(0A) - Not present
P1120 - Accelerator Pedal Position Sensor 1-2 Correlation
(0😎 - Not present
Am sters codurile, dar dupa ce merg cu ea 10-20min imi apare in bord check engine si codurile reapar.
Simptome:
Cand o pornesc la rece se tureaza pana la 1200-1300 rotatii cateva sec si apoi revine la 1000-950.
Va multumesc!
MODEL: Zafira A 2001 Benzina
MOTOR: Z16XE
CODURI EROARE: P1120, P1550
