- valyd11
- 388 mesaje
- din 17 Dec 2009
- Corsa 2017 B14XER
valyd11
- Mesaje scrise: 388
- Masina: Corsa 2017 B14XER
- Cont inregistrat: 17 Dec 2009
Salutare la toata lumea. Vreau sa adresez o intrebare cunoscatorilor. Nu stiu ce sa aleg intre Motul specific dexos2 5w30 si Ravenol LSG 5W30(la fel cu specificatie dexos2).
Aici avem datele tehnice pentru Motul:
PROPERTIES
Viscosity grade SAE J 300 5W-30
Density at 20°C (68°F) ASTM D1298 0.850
Viscosity at 40°C (104°F) ASTM D445 69.6 mm²/s
Viscosity at 100°C (212°F) ASTM D445 12.0 mm²/s
Viscosity HTHS at 150°C (302°F) ASTM D4741 3.5 mPa.s
Viscosity Index ASTM D2270 170
Pour point ASTM D97 -36°C / -32.8°F
Flash point ASTM D92 232°C / 449.6°F
Sulfated ash ASTM D874 0.78% weight
TBN ASTM D2896 7.4 mg KOH/g
si aici le avem pentru Ravenol:
Characteristics Unit Data Audit
Density at 20°C kg/m³ 847,0 EN ISO 12185
Colour brown visual
Viscosity at 100°C mm²/s 12,6 DIN 51 562
Viscosity at 40°C mm²/s 73,1 DIN 51 562
Viscosity index VI 166 DIN ISO 2909
HTHS at 150°C mPа*s 3,51 ASTM D5481
CCS Viscosity at -30°C mPa*s 5440 ASTM D5293
Low Temp. Pumping viscosity (MRV) at -35°C mPa*s 20.300 ASTM D 4684
Pourpoint °C -39 DIN ISO 3016
Noack Volatility % 8,5 ASTM D5800/b
Flash point °C 234 DIN ISO 2592
TBN mg KOH/g 8,0 ASTM D2896
Sulphated ash %wt. 0,8 DIN 51 575
Ce sa aleg?
Si o poza cu masina
MODEL: Corsa 2017
MOTOR: B14XER
PROPERTIES
Colour brown visual
Ce sa aleg?
Si o poza cu masina
MODEL: Corsa 2017
MOTOR: B14XER
- Marius Popescu
- 700 mesaje
- din 27 Jun 2012
- Astra 2001 z16se
Marius Popescu
- Mesaje scrise: 700
- Masina: Astra 2001 z16se
- Status: Online
- Cont inregistrat: 27 Jun 2012
Salut !
Observam ca metodele de testare sunt diferite pt majoritatea parametrilor . Deci nu poti face comparatie directa , doar sa cauti pt fiecare metoda de testare ce presupune ( poate sunt echivalente ), dar inseamna un efort prea mare si nu merita . Vezi daca gasesti safety datasheet pt ambele( MSDS) si poate te prinzi care e "mai sintetic " ca celalalt .
Bafta !
Bafta !
- ovicsb
- 141 mesaje
- din 05 Apr 2013
- Astra 2013 A16xer
ovicsb
- Mesaje scrise: 141
- Masina: Astra 2013 A16xer
- Cont inregistrat: 05 Apr 2013
Alege pe cel cu TBN mai mare (Numãrul total de bazã indicã gradul de oxidare a uleiului de motor , cu cât este mai mic TBN, cu atât este mai scãzutã capacitatea acestuia de a neutraliza compuºii acizi ºi este mai probabil sã fie coroziv), ideal ar fi peste 10 , insa se pare ca trebuie sa te multumesti cu 8,5 al Ravenol-ului.Aici ambele sunt testate dupa acelasi standard. Strict dintre cele 2 as lua Ravenol.
Din punctul meu de vedere personal nu as alege pe niciunul, ma tem ca sunt hidrocracate ambele.
