- AC.Cristian
- 17 mesaje
- din 31 Jan 2019
AC.Cristian
- Mesaje scrise: 17
- Cont inregistrat: 31 Jan 2019
Cod(uri) eroare: p0703
Model: Opel Astra H
An fabricatie: 2005
Cod motor: Z19DTH
big_electro61- Suspendat
- 4,492 mesaje
- din 24 Oct 2008
- Astra 2008 Z13DTH
big_electro61- Mesaje scrise: 4,492
- Masina: Astra 2008 Z13DTH
- AC.Cristian
- 17 mesaje
- din 31 Jan 2019
AC.Cristian
- Mesaje scrise: 17
- AC.Cristian
- 17 mesaje
- din 31 Jan 2019
AC.Cristian
- Mesaje scrise: 17
Si daca ar fi cum spui tu..cum ar trebui sa remediez aceastã problemã?
- 4,492 mesaje
- din 24 Oct 2008
- Astra 2008 Z13DTH
- AC.Cristian
- 17 mesaje
- din 31 Jan 2019
AC.Cristian
- Mesaje scrise: 17
- gabimilo1
- 2,268 mesaje
- din 11 Jan 2010
- Zafira 2002 y20dth
gabimilo1
- Mesaje scrise: 2,268
- Masina: Zafira 2002 y20dth
poti sa ne spui cum a aparut defectul?
poate intelegem mai bine.
ai umblat cumva la triple, ai gaurit ceva pe la masina, ti-ai pus cirlig cu priza de remorcuta etc? Ai schimbat becuri?
sau a mers bine si deodata a inceput sa faca figuri?
am mai gasit si asta pe net:
A good starting point is always to check for technical service bulletins (TSB) for your particular vehicle. Your issue may be a known issue with a known fix put out by the manufacturer and can save you time and money during diagnosis. Gain access to a scanner, a digital volt/ohmmeter, and a service manual (or All Data) for your vehicle. These tools will be necessary to diagnose a code P0703. Begin with a visual inspection of brake lamp wiring and a general inspection of underhood wiring. Test stop lamp system fuses and replace blown fuses as required. Connect the scanner to the diagnostic connector and retrieve all stored codes and freeze frame data. Make a note of this information as it may serve you in further diagnosis. Clear the codes and test drive the vehicle to see if it immediately resets. If it does: Check for battery voltage at the input circuit of the brake switch, using the DVOM. Some vehicles are equipped with multiple brake switches because, when the brake pedal is depressed, the stop lamps must be activated and the torque converter lockup must be deactivated. Consult your vehicle service manual to determine how your brake switch is configured. If there is battery voltage on the input circuit, depress the brake pedal and check for battery voltage on the output circuit. If there is no voltage on the output circuit, suspect a defective or misadjusted brake switch.
Read more at: https://www.obd-codes.com/p0703
Copyright OBD-Codes.com
- AC.Cristian
- 17 mesaje
- din 31 Jan 2019
AC.Cristian
- Mesaje scrise: 17
- gabimilo1
- 2,268 mesaje
- din 11 Jan 2010
gabimilo1
- 4,492 mesaje
- din 24 Oct 2008
- Astra 2008 Z13DTH
- AC.Cristian
- 17 mesaje
- din 31 Jan 2019
AC.Cristian
- Mesaje scrise: 17
