  2. Opel Grandland X
  • bazate
  • Mesaje scrise: 509
  • Masina: Grandland X 2018 B12xht
  • Cont inregistrat: 26 Sep 2016
Stie cineva procedura de reset idle learn?
Am gasit ceva dar de regula se cere scanner care sa dea comanda de resetare.
• The engine coolant temperature must be below 30°C
• The air conditioning must be set to
1. Switch the ignition off then on.
2. Scan tool sends the command to reset.
3. Switch the ignition off then on again.
4. Wait for 10 seconds.
5. Start the engine.
6. Run the engine at idle until the fans cut-in (Air conditioning must be off).
7. Switch off the ignition to store the new values.
8. Wait for 12 minutes while the CM powers down.
9. Switch on the ignition.
10. Wait for 15 seconds
11. Start the engine.
12. Before returning the vehicle to the customer a test drive should be undertaken
during which time an injection cut-off should be triggered. This is achieved by
driving the vehicle in 3rd, 4th or 5th gear and sharply releasing the accelerator
Model: Grandland X
An fabricatie: 2018
Cod motor: B12xht
  • dcrst75
  • Mesaje scrise: 137
  • Cont inregistrat: 30 Mai 2018
Daca ne spui si ce e aia, ne-am lumina si noi
  • bazate
Motoarele care su ECU tind sa auto învețe si sa se optimizeze permanent insa acest proces poate impune compotamente nedorite...gen trepidat relanti...lipsa putere etc. GM a avut mereu o astfel de procedura....din text reiese ca exista asa ceva si la PSA...sa vedem dacã exista si nevoia pt asa ceva
  • vladspaniolul
  • Mesaje scrise: 72
  • Masina: Grandland X 2018 B16DTH
  • Cont inregistrat: 07 Aug 2007
Este vorba de resetarea sistemului de injectie. Da cu siguranta exista si la PSA, au la fel ca la Opel pompe de injectie variabile si vor optimiza consumul de combustibil functie de anumiti parametri si consumul de curent.
  • bazate
Problema e de procedura. In cele din urma eu am fost la Peugeot si s-a facut cu testerul lor..pe cel de Opel functia nu e activa. Eu am avut nevoie pt ca am pus gaz si vroiam sa ma asigur ca parametrii sunt ok. Raman in continuare curios de existenta unei proceduri manuale pt asa ceva.
  • vladspaniolul
  • Mesaje scrise: 72
Resetarea sistemului de injectie si invatarea lui din nou nu se poate face decat cu testere adecvate. Iti spun din experienta ca am facut acest lucrul de mai multe ori pe masinile mele. Fara tester nu faci nimic.
  2. Opel Grandland X
