- alecsionut
- 71 mesaje
- din 09 Mai 2015
- Vectra 2001 Z18XE
- Dolj
alecsionut
- Mesaje scrise: 71
- Masina: Vectra 2001 Z18XE
- Cont inregistrat: 09 Mai 2015
Cod(uri) eroare: Total number of fault codes: 9
P0135 - O2 Sensor Heater Circuit Open (Bank 1 Sensor 1)
(04) - Present
P0170 - Rich Exhaust
(01) - Present
P0030 - O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1)
(0😎 - Present
P0140 - O2 Sensor 2 Incorrect Signal
(0😎 - Not present
P0130 - O2 Sensor 1 Open Circuit
(04) - Not present
P0650 - Malfunction Indicator (MI) Control Circuit Open
(04) - Present
P0130 - O2 Sensor 1 Incorrect Signal
(0😎 - Not present
P0304 - Cylinder 4 Misfire Detected
(01) - Not present
P0115 - Engine Coolant Temperature Circuit High Input
(01) - Not present
Model: Vectra
An fabricatie: 2001
Cod motor: Z18XE
big_electro61- Suspendat
- 4,492 mesaje
- din 24 Oct 2008
- Astra 2008 Z13DTH
- Masina: Astra 2008 Z13DTH
- alecsionut
- 71 mesaje
- din 09 Mai 2015
- Vectra 2001 Z18XE
- Dolj
alecsionut
- Mesaje scrise: 71
- 4,492 mesaje
- din 24 Oct 2008
- Astra 2008 Z13DTH
- Razvan_RSM
- 9 mesaje
- din 04 Oct 2018
- Vectra 2001 Z18XE
- Hunedoara
Razvan_RSM
- Mesaje scrise: 9
- Cont inregistrat: 04 Oct 2018
(04) - Present
(01) - Present
(0😎 - Present
(0😎 - Not present
(04) - Not present
(04) - Present
(0😎 - Not present
(01) - Not present
(01) - Not present
Model: Vectra
An fabricatie: 2001
Cod motor: Z18XE
Si eu am in mare parte erorile care le ai tu ai rezolvat ceva?tine-ma la curent cu ce rezolvi
Cred ca am gasid denumirile ok..
0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
0170 Fuel Trim Malfunction (Bank 1)
0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
1613 Interactive Codes
0301 Cylinder 1 Misfire Detected
0302 Cylinder 2 Misfire Detected
Din ce va pot povesti este ca la prima cheie am o turatie a motorului dar in scurt timp isi revine si merge relantiul si motorul in parametri normali si un lag scurt la calcarea pedalei de acceleratie
Miros de gaz pe evacuare si in momentul cand trece de pe benzina pe gaz o vibratie mare a motorului
Ce sfaturi aveti?
Masina este Vectra B 2001 Benzina +GPL
- iulian1971
- 7,047 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
- Mesaje scrise: 7,047
- 4,492 mesaje
- din 24 Oct 2008
- Astra 2008 Z13DTH
