dre
- Mesaje scrise: 28
- Masina: Astra 2006 idh17
- Cont inregistrat: 28 Apr 2007
Dupa un accident masina a fost reparata si a venit din service cu niste erori , printre care si P1116 . Dupa ce celelalte au fost resetate , a mai ramas doar P1116 . Azi au mai aparut din senin ogramada alte erori .
Cod(uri) eroare:
P1116 Eng Coolant Temp Sig Unstable or Interm
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
ECN 023002 -> P0230 Fuel Pump Primary Circuit Malfunction / DTC P0230 Fuel Pump Relay Control Circuit
ECN 065070 -> P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction / DTC P0650 Malfunction Indicator Lamp (MIL) Control Circuit
ECN 111606 P1116 Eng Coolant Temp Sig Unstable or Interm
ECN 15505A -> P1550 PSPS Out Of Self Test Range
ECN 210300 - P2103 Throttle Actuator Ctrl Motor Circ High
ECN 210400 -> P2104 Throttle Actuator Control System - Forced Idle
ECN 210870 -> P2108 Throttle Actuator Control Module Performance
ECN 213970 -> P2139 Throttle/Pedal Position Sensor/Switch “D” /"F" Voltage Correlation
Model: Astra
An fabricatie: 2004
Cod motor: z16xep
Ce credeti ca poate fi ? Ce sa verific mai intai ?
big_electro61- Suspendat
- 4,492 mesaje
- din 24 Oct 2008
- Astra 2008 Z13DTH
big_electro61- Mesaje scrise: 4,492
- Masina: Astra 2008 Z13DTH
dre
- Mesaje scrise: 28
