Hyperion9
- Mesaje scrise: 3
- Masina: Astra Z14XE
- Cont inregistrat: 07 Jun 2018
Am un Opel Astra G combi, 1.4, 16v benzina, cod motor: Z14XE. De ceva timp am o problema cu pornirea, cand motorul este rece porneste din prima cheie, am undeva la 900 de rotatii, daca las pornita masina rpm scad undeva la 700-750 (nu stiu daca este normal). Cand motorul este cald, nu mai porneste din prima cheie, trebuie sa tin contactul mai mult si sa o ajut cu acceleratia. Bujiile au fost schimbate, nu imi pot da seama care ar fi problema.
Multumesc!
- tomariscom
- 155 mesaje
- din 16 Apr 2013
- Astra 2004 Z16XE
tomariscom
- Mesaje scrise: 155
- Masina: Astra 2004 Z16XE
- Cont inregistrat: 16 Apr 2013
Hyperion9
- Mesaje scrise: 3
- bibu16v
- 7,138 mesaje
- din 25 Jan 2016
- Astra 1995 X16XEL
bibu16v
- Mesaje scrise: 7,138
- Masina: Astra 1995 X16XEL
Hyperion9
- Mesaje scrise: 3
- alexandru_2487
- 10 mesaje
- din 11 Sep 2012
- Astra 2008 Z14XEP
- Dambovita
alexandru_2487
- Mesaje scrise: 10
- Masina: Astra 2008 Z14XEP
- Cont inregistrat: 11 Sep 2012
Azi am pus tester pe ea, nicio eroare aparuta.
Rezultate teste:
systemNameOrEngineType: Z14XEP
Battery Voltage 14.4 V
Main Relay Active
Fuel Pump Relay Active
APP Sensor 1 (Accelerator Pedal Position) 0.97 V
APP Sensor 2 (Accelerator Pedal Position) 0.49 V
Calculated Pedal Position 0%
APP at Idle Position (Accelerator Pedal Position) Active
TP Sensor 1 (Throttle Position) 0.88 V
TP Sensor 2 (Throttle Position) 4.14 V
Calculated Throttle Position 4%
Throttle Position Idle
Engine Speed 787 RPM
Desired Idle Speed 780 RPM
Mass Air Flow Sensor 1.25 V
Mass Air Flow Sensor 5 kg/h
Coolant Temperature 0.90 V
Coolant Temperature 94 °C
Intake Air Temperature 1.78 V
Intake Air Temperature 63
Port Deactivation Position Sensor 4.5 V
A/C Information Switch (Air Conditioning) Inactive
A/C Pressure (Air Conditioning) 1.96 V
A/C Pressure (Air Conditioning) 1340 kPa
Tank Sensor 3.24 V
Tank Sensor 3 L
Brake Switch 1 Inactive
Brake Switch 2 Inactive
Clutch Switch Inactive
Vehicle Speed 0 km/h
EGR Valve (Exhaust-Gas Recirculation) Inactive
EGR Position Feedback (Exhaust Gas Recirculation) 0.88 V
Fuel Tank Ventilation Valve Active
Knock Control Inactive
B1S1 O2 Sensor Heater (Bank 1 Sensor 1) Active
B1S1 O2 Sensor (Bank 1 Sensor 1) 723 mV
B1S1 Air/Fuel Ratio (Bank 1 Sensor 1) Rich
B1S2 O2 Sensor Heater (Bank 1 Sensor 2) Inactive
B1S2 O2 Sensor (Bank 1 Sensor 2) 451 mV
B1S2 Air/Fuel Ratio (Bank 1 Sensor 2) Rich
B1 Long Term Fuel Trim (Bank 1) 1%
B1 Short Term Fuel Trim (Bank 1) -1%
O2 Sensor Loop Closed
A/C Relay (Air Conditioning) Active
A/C Cutoff Mode (Air Conditioning) High Pressure
Cruise Control Not Programmed
Cruise Control Tip Switch Not Programmed
Vehicle Speed in Cruise Control Range Not Programmed
Malfunction Indicator (MI) Off
Service Vehicle Soon (SVS) Indicator Off
Ignition Status On 12V
Throttle Position PWM Servo Signal 14%
TP Sensor 1 Learned Lower Position (Throttle Position) 0.75 V
Engine Speed 1573 RPM
Injector Time 2.5 ms
Ignition Dwell Angle 1.6 ms
Ignition Spark Angle 9.2 °CA
B1 Knock Sensor Signal (Bank 1) 1.1 mV
Knock Retard Cylinder 1 0 °CA
Knock Retard Cylinder 2 0 °CA
Knock Retard Cylinder 3 0 °CA
Knock Retard Cylinder 4 0 °CA
Normal Engine Operating Temperature Active
Fan Relay 1 Inactive
Fan Relay 2 Inactive
Fan Relay 3 Inactive
Deceleration Fuel Cutoff Inactive
Vehicle Acceleration 0 m/s2
Full Load Enrichment Inactive
Catalyst Protection Enrichment (Bank 1) Inactive
ETC Limp Home Mode (Electronic Throttle Control) Inactive
Electronic Throttle Control Learn Counter 0
In plus, pe autostrada, la viteze mari, volanul vibreaza. Mentionez ca am schimbat recent discurile,placutele, amortizoare,flanse, bielete antiruliu, insa nu stiu daca s-a facut geometria rotiilor, nu a aparut pe devizul de lucrari, si nici eu nu am intrebat.
Intrebarile mele sunt:
1. De ce nu porneste dupa ce o las nepornita o perioada mai mare de timp?
2. De ce vibreaza volanul?Din cauza neefectuarii geometriei?
mersi anticipat
- tomariscom
- 155 mesaje
- din 16 Apr 2013
- Astra 2004 Z16XE
tomariscom
2. cauciuc cu bataie ,neumflat, janta neechilibrata sau daca este echilibrata a cazut plumbul .
te sfatuiesc sa verifici furtunul de benzina care intra in clapeta de acceleratie sa fie bine strans
mergi cu masina si fa echilibrare la rotile din fata si da o tura cu viteza la care ai vazut ca trepideaza
daca nu si nu mergi si faci bracajul cu tot cu geometrie. o zi buna si drumuri placute. STIMA
