  • CMarinLiviu
  • Mesaje scrise: 17
  • Masina: Astra 2006 Z18XER
  • Cont inregistrat: 29 Jan 2018
Buna seara.
Am un Astra H 2006 1.8 140cp cu CD 70 NAVI, se poate un auxiliar sau bluetooth fãrã sã schimb originalul?
Am incercat si cu cateva modulatoare dar este foarte enervant "gâjâitul" de pe fundal...
  • cutienoua
  • Mesaje scrise: 332
  • Masina: Astra 2009 Y17DT
  • Cont inregistrat: 28 Mar 2016
se poate,dar eu unul sunt fan aftermarket. am gasit niste instructiuni in engleza dar posibil sa le gasesti si traduse:
1. Update your CD70 to latest firmware, i.e. 10/10/2007. (15 minutes)
Addition information: To update the firmware you will need an update disc.
This disc can be acquired from Vx dealer (at about £5 ?) or borrow from your friend.
It's a job of once and for all and you will not need that ever.
2. Find A Tech2 or Vauxcom or similar product to activate your aux-in in the software.
A new "Aux" menu will be appeared just as shown in the picture after a successful activation.
Audio pass (carpass) is NOT required. (2 minute)
3. Open your CD70 and solder some components (which are included by this auction) to the mainboard (1-2 hour).
4. Insert 3 wires with cramp (included) to the quadlock connector (Car to CD70 connector), then connect these wires to a jack socket.
The jack socket can be purchased from everywhere(e.g. maplin, order code:FK03D), or you can buy a tray with auxin socket from dealer (part number is in the guide,
  • AlexDmi
  • Mesaje scrise: 522
  • Masina: Vectra 2007 Z20NET
Amandoua se pot rezolva. Instructiunile alea in engleza sunt instructiuni pentru montarea AUX, dar iti trebuie niste componente si o mana sigura, ca sa nu strici altceva p`acolo 😊 Bluetooth pentru apeluri este alta discutie. Costurile pentru ambele sunt undeva in jur de 7-800 de lei, aproximativ.
  • CMarinLiviu
  • Mesaje scrise: 17
Bluetooth pentru apeluri am separat... Așa am luat mașina, cu un sistem Nokia 616. Am incercat sa trag si de pe acolo un Aux dar nu merge. Singura soluție imi ramane sa fac treaba de mai sus 😃... Mulțumesc frumos bãieți. Toate cele bune.
  • alexx1402
  • Mesaje scrise: 1,751
  • Masina: Astra 2017 B16DTH
Daca te pricepri la electronica iti poti monta aux cu maxim 50 lei, cam atat costa piesele. Eu mi-am montat singur acum vreo 6 ani si merge perfect si in ziua de azi, Daca o faci la cineva care se ocupa cu asta, te costa vreo 50eur.
  • cutienoua
am gasit ceva si mai fain! ma tenteaza si pe mine desi am un alpine single din cu amplificatorul compact alpine.
Stream Music Through Your System Directly from Your Amplifier
Eliminate the Need of an Expensive Head
HOW BLUETOOTH AMPLIFIERS WORKS
A Bluetooth amplifier is actually a pretty basic piece of equipment. It functions and installs just like any other amplifier would (they can be connected to a source unit, but it isn’t required), it just has an integrated Bluetooth module installed in it allowing you to connect virtually any Bluetooth enabled device (smartphones, tablets, etc.) to it wirelessly. Bluetooth amps eliminate the need of a traditional head unit because they allow the amp to double as the receiver
un exemplu Planet Audio PSA4CB
Class-A/B FullRange 4-Ohm Stable 4-Channel Amplifier
RMS Power Rating:
4 ohms: 94 watts x 4 chan.
Total power output: 500 watts
Pulse Width Modulated MOSFET power supply
Inline Multi-Function Remote included
Weather resistant silicon button controller
Soft start turn-on
aptX Support
Bluetooth A2DP wireless audio streaming
3-way protection circuitry (thermal, overload, and speaker short protection)
Frequency Response: 20 - 20000 Hz
  • Mihaiepcs
  • Mesaje scrise: 17
  • Masina: Astra 2007 Z14XEP
  • Cont inregistrat: 27 Dec 2015
Salutare. E cineva din București care monteazã mufã AUX pe un Opel Astra H? Casetofon este cu 9 butoane la radio dar merge sigur și pe acesta ca am gãsit un bãiat tocmai în Craiova care monteazã și nu as vrea sa merg tocmai acolo
  • CristianTM
  • Mesaje scrise: 3,700
  • Masina: Vectra 2005 Z19DTH
Si eu te pot ajuta sa punem aux in la CD30 mp3 modelul cu 9 butoane.
CristianTM.
  • Mihaiepcs
  • Mesaje scrise: 17
Pai tu vad ca ești din Timișoara Cristian. Eu am nevoie aici în București.
  • bilzerian
  • Mesaje scrise: 24
  • Masina: Astra 2005 Z16XEP
  • Cont inregistrat: 07 Oct 2015
Imi cer scuze ca postez aici, insa nu am gasit discutii despre harti navigatie decat din 2008. Ma poate ajuta cineva cu hartile pentru un cd de navigatie pentru Astra H? Ma gandesc ca nu e asa de greu sa faci CD-ul. Poate imi oferiti si cum se face in cazul in care exista vreo procedura speciala, gen ISO nu stiu de care. Multumesc si im cer scuze daca nu am nimerit unde trebuie.
  • ASTRA-lul
  • Mesaje scrise: 8
  • Masina: Astra 2007 Y13DTH
  • Cont inregistrat: 18 Mar 2018
Daca ai drum la Bucuresti, si nu ai gasit...iti ofer eu unu', fara bani, am doua ,cele cu Romania. ...
  • RIvan426
  • Cont inregistrat: 13 Mar 2019
Salutare . Si eu as vrea sa imi montez un auxiliar pe un astra h. CD30.
Dacã stie cineva astept raspuns. In Bucuresti orice zonã
  • cristian_fanel
  • Masina: Zafira 2006
Buna ziua.
Detin si eu un opel zafira b echipat cu cd70 navi ecran color.
Ma poate ajuta si pe mine cineva cu un link sau imagine iso a cd-ului cu firmwere updata 2007 sau 2008 pt cd 70 navi.
Email: cristian_fanel@ymail.com
Multumesc mult.
Si scuze daca am postat unde nu trebuie
  • MPogar
  • Mesaje scrise: 10
  • Cont inregistrat: 31 Mai 2019
salutare ma intereseaza si pe mine montarea unui auxiliar pe un opel astra h CD 70.STIE CAREVA?
  • rinoantara
  • Mesaje scrise: 67
  • Masina: Antara 2015 z22dm1/LNQ
  • Cont inregistrat: 19 Jan 2016
cristian_fanel a scris:Buna ziua.
Multumesc mult.
Nu-ti recomand sa faci update cu cd copiat. Update doar cu cd original !
  • rinoantara
  • Mesaje scrise: 67
MPogar a scris:salutare ma intereseaza si pe mine montarea unui auxiliar pe un opel astra h CD 70.STIE CAREVA?
Din ce localitate esti ?
  • cristian_fanel
Bucuresti
  • cristian_fanel
rinoantara a scris:
Bucuresti
  • MPogar
  • Mesaje scrise: 10
rinoantara a scris:
MPogar a scris:
Bucuresti
  • rinoantara
  • Mesaje scrise: 67
MPogar ai mesaj privat.
