  2. Opel Zafira
  3. Zafira A
  • ionutdanica
  • Mesaje scrise: 295
  • Masina: Astra 2006 Z19DTH
  • Cont inregistrat: 24 Aug 2014
Salutare am un prieten care are o zafira a motor y20dth a oprit motorul in parcare si nu a mai vrut sa porneasca.
Simptome in momentul in care da la automat porneste si termocupla lucru ciudat.
OP-COM 100219a - PC based diagnostic tool
OP-COM - KW2000 Communication Window> 2001 (1)|Zafira|Engine|Y 20 DTH
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L0TGF7532110227
vehicleManufacturerECUHardwareNumber 09202063 KC
systemSupplierECUHardwareNumber: BOSCH010000001401
systemSupplierECUHardwareVersionNumber: 0000
systemSupplierECUSoftwareNumber: 6MAM1040_S
systemSupplierECUSoftwareVersionNumber: 06A9
exhaustRegulationOrTypeApprovalNumber: B02005
systemNameOrEngineType: Y20DTH
RepairShopCodeOrTesterSerialNumber: Not programmed
ProgrammingDate: FFFFFFFF
Identifier: 1410
VehicleManufacturerSpecific: 0470504203
Total number of fault codes: 7
P1540 - Air Condition PWM-Signal invalid
(0D) - Not present
P1630 - Fuel-Injection Quantity Malfunction
(0B) - Present
P0606 - Electronic Control Unit (ECU) - Malfunction
(0D) - Present
P0100 - Mass Air Flow Sensor Voltage Supply Circuit Low Input
(0C) - Not present
U2103 - <Unknown DTC>
(07) - Present
P0400 - Exhaust Gas Recirculation Circuit Open
(04) - Not present
P1612 - Immobiliser No Or Wrong Signal
(00) - Not present
Astea sunt eroarile citite cu opcom.
Eu cred ca are probleme la ecu.
  • ionutdanica
Ce ziceti ca poate fii se poate sa fie pompa de injectie sau ecu de pe pompa de injectie?
  • ionutdanica
Revin cu o informatie daca dau la automat vine motorina la injectoare dar nu porneste...
  • Mesaje scrise: 7,053
ECU defect.
Ai P1630 prezent.
  • T.ion
  • Mesaje scrise: 3,454
  • Masina: Zafira 2001 Z16XE
Vezi si tu in ce stare este ECU poate a intrat la apa.
Numai locuri unde se sa strice il pune Opel - Ba pe motor Ba sub aripa.
https://www.clubopel.com/viewtopic.php?p=1900923
  • ionutdanica
Salut ecu de pe pompa de injectie sau celalat?
Are un singur calculator. Pe pompa.
  • ionutdanica
Am inteles iulian o sa il sun pe baiat sa ii spun, eu credeam ca sunt 2 unul pe pompa si unul sub aripa.
Inca o intrebare daca cumpara alta pompa sh cu acelasi cod mai trebuie programata?
Sau poate cumpara doar unitatea ecu si montata pe aceasta pompa?
Multumesc mult.
E pompa PSG16, de-asta are doar un calculator.
Poate cumpara doar ECU, dar daca nu are scule pt. resetare-programare si codurile masinilor, a lui si al celei de pe care e luat ECU, sa caute kitul complet. ECU, imobilizator si 1-2 cipuri cheie.
ECU poate fi luat doar de pe Zafira A sau Astra G, PSG16.
  2. Opel Zafira
  3. Zafira A
