  • A.Alex85
  • Masina: Astra 2005
  • Cont inregistrat: 14 Oct 2016
Detin un opel astra h 1.9 120 cp din 2005 electromotorul se invarte doar ca nu mai porneste, baterie noua schimbata doar de 2 zile..
Imi apar urmatoarele coduri
62101
7071
34028
210870
5007f
50074
19007
  • Mesaje scrise: 7,049
Bine ai venit.
P0340 Camshaft Position Sensor Circuit Open - senzor ax came;
P1900 Exhaust Gas Temperature Sensor (Bank 1 Sensor 1) not plausible with Intake Air Temperature
P1900 Exhaust Gas Temperature Sensor (Bank 1 Sensor 2) not plausible with Intake Air Temperature
P1900 Particulate Filter Regeneration Cycle Interrupted Several Times
P1900 Exhaust Gas Temperature Sensor High Temperature (Bank 1 Sensor 1)
P1900 Exhaust Gas Temperature Sensor Low Temperature (Bank 1 Sensor 1)
P1900 Exhaust Gas Temperature Sensor High Temperature (Bank 1 Sensor 2)
P1900 Exhaust Gas Temperature Sensor Low Temperature (Bank 1 Sensor 2)
P0500 Vehicle Speed Signal Range/Performance
P0621 Generator Lamp "L" Control Circuit Malfunction - alternator defect:
U2108 CAN-Bus no Communication with ABS/TC - lipsa comunicare cu modul ABS.
P0070 Ambient Air Temperature Sensor Malfunction
Fa o diagnoza ca lumea si vezi ce erori sunt prezente.
Cred ca ai DPF-ul infundat si de-asta nu mai porneste. Daca porneste cu EGR scos, DPF-ul e PA.
