  3. Motoare diesel
  • grikrbon19
  • Masina: Astra 2005 Z19DT
  • Cont inregistrat: 02 Mai 2016
Simptome: Cateodata cand pornesc se aprinde ESP-ul si acceleratia ramane blocata la ~1500 nu raspunde , daca o pornesc si opresc de cateva ori isi revine.
Cod(uri) eroare:
---- 019012 , 04005A ,112252, 112052
Model: Astra
An fabricatie: 2005
Cod motor: Z19DTH
  • adibaiacos2003
  • Mesaje scrise: 298
  • Masina: Astra 2007 1.9 cdti
  • Cont inregistrat: 05 Aug 2009
P0190 Rail Pressure Sensor High Voltage C-020
P0190 Rail Pressure Sensor Low Voltage C-020
P0190 Rail Pressure Range/Performance C-020
P0400 Exhaust Gas Recirculation Circuit High Voltage C-017
P0400 Exhaust Gas Recirculation Circuit Low Voltage B-023
P0400 Exhaust Gas Recirculation Circuit Open B-023
P0400 Exhaust Gas Recirculation Valve Powerstage High Temperature C-017
P0400 Exhaust Gas Recirculation Flow Excessive Detected B-044
P0400 Exhaust Gas Recirculation Flow Insufficient Detected B-036
P1122 Accelerator Pedal Position Sensor 2 High Input C-008
P1122 Accelerator Pedal Position Sensor 2 Low Input C-008
P1122 Accelerator Pedal Position Sensor 2 Range/Performance C-008
P1122 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio
Desi nu sunt specialist, cam pe aici trebuie sa cauti problema...
  • Mesaje scrise: 7,053
Senzor presiune rampa injectoare, EGR blocat, UEC murdar/contact imperfect.
  3. Motoare diesel
