Leontin88
- Mesaje scrise: 17
- Masina: Astra 2017 A1.6bdte
- Cont inregistrat: 02 Mai 2015
Mentionez in momentul cand am ajuns acasa a inceput regenerarea filtrului de particule.
ok,
dupa ce si -a facut treaba, cam in 15 min ,usor ,usor galopeaza acul de la turometru.am facut testul cu pedalele si imi da :ecn 190 057
stie cineva care af fi problema?
Nu are probleme,trage bine,dar nu vreau martori aprinsi in bord
Ms si astept raspunsuri
Stima!
serban24
- Mesaje scrise: 68
- Masina: Astra 2006 z1.9dt
- Cont inregistrat: 31 Jul 2010
P190057Particulate Filter Regeneration Cycle Interrupted Several Times
You need to check you oil level and make sure its not above the max level. If it is get the oil and filter changed and take it for a good drive of about 30 minutes along a motorway. This should be enough to force it into a dynamic regneration.
DO NOT drive the car if its above the MAX until its been lowered and a oil and filter change is done or you risk damage to the engine as it runs uncontrollably on its own oil with NO way of stopping it. Seen this a few times now
Leontin88
- Mesaje scrise: 17
