pappy69ro
- Mesaje scrise: 11
- Masina: Vectra 2006 Z19DT-88
- Cont inregistrat: 14 Sep 2009
Am o Vectra C Z19DT 88kw
P0621 - Generator Lamp "L" Control Circuit Malfunction
(01) - Not present
U2108 - CAN-Bus no Communication with ABS/TC
(70) - Not present
P1811 - Torque Signal Malfunction (CAN)
(71) - Not present
P0500 - Vehicle Speed Signal Range/Performance
(7E) - Not present
U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
(00) - Not present
B2955 - Anti Theft Warning System Sensor Datalink no Communication
(0F) - Present
B2652 - Instrument Dimming Bulb Output Circuit Open or High Voltage
(05) - Present
U2174 - <Unknown DTC>
(00) - Present
(01) - Not present
(70) - Not present
(71) - Not present
(7E) - Not present
(00) - Not present
(0F) - Present
(05) - Present
(00) - Present
- iulian1971
- 7,083 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- Mesaje scrise: 7,083
- Masina: Astra 2008 Z19DTH
U2174 CAN-Bus No Communication with EHS (Electrical Heater System)
B2955 - modul BCM defect sau fara alimentare;
Check the following fuses for proper operation:
FE30, FR22 Fuse
If fuse FE30 is defective:
Refer to Power Supply and Communication Table C-072 Fuse FE30 Circuit
If fuse FR22 is defective:
Refer to Power Supply and Communication Table C-117 Fuse FR22 Circuit
FE30, FR22 Fuse
