lac6
- Mesaje scrise: 14
- Masina: Astra 2006 Z13DTH
- Cont inregistrat: 03 Nov 2013
- catastefan
- 5,918 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- Mesaje scrise: 5,918
- Masina: Corsa 2001 Z12XE
P0243 Boost Pressure Control Circuit Negative Deviation
Boost Pressure Control Circuit Positive Deviation
Boost Pressure Valve Circuit Open
Boost Pressure Valve High Voltage
Boost Pressure Valve Low Voltage
P0400 Exhaust Gas Recirculation Valve Malfunction
Exhaust Gas Recirculation Valve Stuck
P0621 Generator Lamp "L" Control Circuit Malfunction
P1614 Immobiliser Wrong Signal Received
Wrong Transponder Key
P2264 "Water In Fuel" Sensor Circuit Malfunction
U2108 Invalid Data from ABS (Anti-Lock Brake System)
Posibil valva EGR blocata.
In timp ce cineva da la automat bate cu ceva de lemn sau plastic in valva EGR .
Masina cu cheita clipeste incontinuu?
lac6
- Mesaje scrise: 14
- ionutdanica
- 295 mesaje
- din 24 Aug 2014
- Astra 2006 Z19DTH
- Italia
ionutdanica
- Mesaje scrise: 295
- Masina: Astra 2006 Z19DTH
- Cont inregistrat: 24 Aug 2014
lac6
- Mesaje scrise: 14
- ionutdanica
- 295 mesaje
- din 24 Aug 2014
- Astra 2006 Z19DTH
- Italia
ionutdanica
lac6
- Mesaje scrise: 14
