Fog headlight key re-tool
Who new switch unit to buy would not like and thus to live that does not know the fog headlight key a symbol has can its Orginal switch changes. In addition the following is needed:
- The original switches
- Two small feathers/springs
- Microtaster e.g. from an old mouse preferably with 4 connections as the existing
- Piece of plastics at least 4cm long
- Soldering irons
- Hot adhesives or similarly
- Dremel
- little time
Switches develop and take apart, switches must in addition on zero, at the back on the left and on the right the sides something lever off and to upper section take off, right down see one then the existing Microtaster for the fog tail light and left that up to now still empty place for the fog headlight tracer, the plate from the housing removing, whereupon that the contact springs respect more untendrunter do not rausfallen, tracers solder that are from top to bottom connected through in such a way, since there are different tracers must it already measure as rum he purely must, now can one the plate already again into the housing insert, now must the blind cover to the key be only converted, cover and key be rausdrücken from the inside, Cover up to the red line (picture) reciprocally saw off to it the same measures has as the existing key, now only a piece of plastics in the suitable length (probably most complicated of everything) in the correct place bond thereby at the original key to orient, which feathers/springs use, keys to clean-press, switches assemble, function test between pin 30 and 1 measure switches thereby on 1 and the key to naturally press at least, finished
If it everything did not make correct should of an original switch with fog headlight key to be differentiated have up to the non-existent symbol evenly.
poze:
