  3. Vectra C/Signum
  • rebotea
  • Mesaje scrise: 28
  • Masina: Vectra OPC 2003
  • Cont inregistrat: 14 Apr 2013
hi again
what do i have to do to make this massege go way :
IPC Environment Identification (Instrument) not progtamed
is it possible with opcom to make my odometer be with the same Milage like in the ICU ? Thank´s
Vectra C 2003 2.0 DTI
  • CristianTM
  • Mesaje scrise: 3,698
The mileage can be modified with op-com or Tech2 / MDI only if <500Km (new car), otherwise only with special tools, open IPC, desolder eeprom, read / modify / write ...put back.
"IPC Environment Identification (Instrument) not programed" = need to programm with your security code !
CristianTM.
  • rebotea
  • Mesaje scrise: 28
i have reseted the code a insert new code by i still have the same code and a general code that says:
invalid data from BCM and
No Environment Identification identifier learned
  3. Vectra C/Signum
