- aditz6
- 169 mesaje
- din 25 Mai 2010
- Astra 2002 Z16SE
- Olt
aditz6
- Mesaje scrise: 169
- Masina: Astra 2002 Z16SE
- Cont inregistrat: 25 Mai 2010
Am facut testul din pedale si mi-a dat eroarea 0300. Motorul merge la fel ca in prima zi, are doar momente cand caraie la pornire, dar nu face mereu lucrul asta.
E problema grava sau?
snicola
- Mesaje scrise: 92
- Masina: Astra 2001 Z16SE
- Cont inregistrat: 01 Oct 2012
- aditz6
- 169 mesaje
- din 25 Mai 2010
- Astra 2002 Z16SE
- Olt
aditz6
- DB77AAA
- 6,605 mesaje
- din 19 Jan 2007
- Vectra 2005 Z19DTH 200CP
- Dambovita
DB77AAA
- Mesaje scrise: 6,605
- iuly,iuly,iuly
- 97 mesaje
- din 05 Nov 2013
- Astra 2001 Z16SE
- Vrancea
iuly,iuly,iuly
- Mesaje scrise: 97
- Cont inregistrat: 05 Nov 2013
big_electro61- Suspendat
- 4,492 mesaje
- din 24 Oct 2008
- Astra 2008 Z13DTH
big_electro61- Mesaje scrise: 4,492
- Masina: Astra 2008 Z13DTH
OBD Code P0300refers to
Basically this means that the the car's computer has detected that not all of the engine's cylinders are firing properly. A P0300 diagnostic code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
Symptoms
Possible sumptoms of OBD code P0300
the engine may be harder to start the engine may stumble / stumble, and/or hesitate other symptoms may also be present
Causes
Possible causes of OBD code P0300
A code P0300 may mean that one or more of the following has happened: Faulty spark plugs or wires Faulty coil (pack) Faulty oxygen sensor(s) Faulty fuel injector(s) Burned exhaust valve Faulty catalytic converter(s) Stuck/blocked EGR valve / passages Faulty camshaft position sensor Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back. If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors. Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open. Traducerea o poti face cu Google...!
- slav_valentin84
- 71 mesaje
- din 23 Jun 2009
- Astra 2003 16zse
- Calarasi
slav_valentin84
- Mesaje scrise: 71
- Masina: Astra 2003 16zse
- Cont inregistrat: 23 Jun 2009
liviu2004- Suspendat
- 2,282 mesaje
- din 28 Sep 2005
liviu2004- Mesaje scrise: 2,282
- iuly,iuly,iuly
- 97 mesaje
- din 05 Nov 2013
- Astra 2001 Z16SE
- Vrancea
iuly,iuly,iuly
- Mesaje scrise: 97
- slav_valentin84
- 71 mesaje
- din 23 Jun 2009
- Astra 2003 16zse
- Calarasi
slav_valentin84
- Mesaje scrise: 71
Masina.merge perfect nu am nici o problema cu ea ( dimineata porneste putin mai greu )dar in rest nu are nimic. Am crezut ca am eu vreo problema cu masina de consuma asa mult 😊) . Ma gandeam ca este de la bujii de consuma asa mult si de la termostat+pompa de apa ca nu am apucat inca sa le achimb
- iuly,iuly,iuly
- 97 mesaje
- din 05 Nov 2013
- Astra 2001 Z16SE
- Vrancea
iuly,iuly,iuly
- Mesaje scrise: 97
- slav_valentin84
- 71 mesaje
- din 23 Jun 2009
- Astra 2003 16zse
- Calarasi
slav_valentin84
- Mesaje scrise: 71
- iuly,iuly,iuly
- 97 mesaje
- din 05 Nov 2013
- Astra 2001 Z16SE
- Vrancea
iuly,iuly,iuly
- Mesaje scrise: 97
- DB77AAA
- 6,605 mesaje
- din 19 Jan 2007
- Dambovita
DB77AAA
- slav_valentin84
- 71 mesaje
- din 23 Jun 2009
- Astra 2003 16zse
- Calarasi
slav_valentin84
- Mesaje scrise: 71
- DB77AAA
- 6,605 mesaje
- din 19 Jan 2007
- Dambovita
DB77AAA
- jE
- 8,410 mesaje
- din 04 Jun 2006
jE
- Mesaje scrise: 8,410
- slav_valentin84
- 71 mesaje
- din 23 Jun 2009
- Astra 2003 16zse
- Calarasi
slav_valentin84
- Mesaje scrise: 71
- jE
- 8,410 mesaje
- din 04 Jun 2006
jE
- slav_valentin84
- 71 mesaje
- din 23 Jun 2009
- Astra 2003 16zse
- Calarasi
slav_valentin84
- Mesaje scrise: 71
