slim_jim
- Mesaje scrise: 10
- Cont inregistrat: 11 Jan 2005
- sorin03aib
- 72 mesaje
- din 27 Oct 2007
- Signum 2006 z19dt
- Giurgiu
sorin03aib
- Mesaje scrise: 72
- Masina: Signum 2006 z19dt
- Cont inregistrat: 27 Oct 2007
- marian_sro
- 3,791 mesaje
- din 08 Apr 2007
- Vectra 1999 x20xev
- piatra neamt
marian_sro
- Mesaje scrise: 3,791
- Masina: Vectra 1999 x20xev
dot 4 este recomandat si la vectra mea si eu nu am abs.
nici eu nu stiu diferentele intre ele, dar daca tot m-ai facut curios, uite ce am gasit
D.O.T ratings
All brake fluids are DOT rated. Your owners handbook for your car or motorbike probably tells you to use DOT3 or DOT4 from a sealed container. The DOT ratings are a set of minimum standards the fluid must adhere to in order to get the rating, and thus work in your braking system. The following table shows the various properties of DOT ratings. Remember that the values here are the minimum values. Most manufacturers make sure their product far exceeds minimum ratings.
Boiling Point DOT 3 DOT 4 DOT 5 (silicone-based) DOT 5.1 (non-silicone based)
Dry 401°F 446°F 500°F 500°F
Wet 284°F 311°F 365°F 365°F
The "dry" and "wet" boiling points in the table above are for brake fluid which is fresh from the bottle (dry) and which has a 10% water content (wet). A DOT study in 2000 discovered that on average, the brake fluid in a vehicle absorbs about 2% water every 12 months.
The two types of brake fluids shown in the table are DOT3/DOT4/DOT5.1 which are glycol (Polyalkylene Glycol Ether) based, and DOT5 which is silicone based. DOT3 and DOT4 fluids are interchangeable* - the only real difference is their boiling point. Theoretically you could interchange DOT4 and DOT5.1 fluids too but I wouldn't recommend it. DOT3/4/5.1 and DOT5 fluids cannot be mixed or interchanged under any circumstances. They mix like oil and water (ie. they don't) and the silicon based fluids can destroy the seals in brake systems which rely on the moisturiser additives that are present in DOT3/4/5.1 fluids.
Other things you ought to know about silicone based fluids:
- they are resistant to absorbing water, which is why their wet boiling points are so high. Problem is that any water content eventually pools in the low spots of the brake system and causes rust.
- they don't strip paint.
- they are not compatible with most ABS system because they doesn't lubricate the ABS pump like a glycol based fluid.
- putting this fluid in systems which have had DOT3/4 fluid in will cause the seals in the caliper and master cylinders to malfunction. Which means they need replacing. Which is expensive.
Oh, and don't ask me why DOT5.1 is glycol and DOT5 is silicon based. It doesn't make and sense to me either.
* There has been some discussion as to the use of DOT4 fluid in Toyotas that recommend DOT3 fluid - apparently something in the Toyota braking system doesn't play well with DOT4 fluid, particularly the master brake cylinder seals. The discussion about this can be found in the archives at the UK Pruis yahoo group.
sursa: http://www.carbibles.com/brake_bible.html
D.O.T ratings
- mihdoi
- 720 mesaje
- din 30 Mai 2006
- Meriva 2016 B14NEL 77kW
mihdoi
- Mesaje scrise: 720
- Masina: Meriva 2016 B14NEL 77kW
- Cont inregistrat: 30 Mai 2006
- marian_sro
- 3,791 mesaje
- din 08 Apr 2007
- piatra neamt
marian_sro
- Avram Adrian
- 647 mesaje
- din 15 Sep 2007
- Insignia 2010
Avram Adrian
- Mesaje scrise: 647
- Masina: Insignia 2010
- Cont inregistrat: 15 Sep 2007
biela-manivela- Suspendat
- 2,900 mesaje
- din 25 Nov 2007
- Vectra 2003 Z18XE
- Ialomita
biela-manivela- Mesaje scrise: 2,900
- Masina: Vectra 2003 Z18XE
- Cont inregistrat: 25 Nov 2007
- dancuciureanu
- Moderator
- 16,465 mesaje
- Agila 2001 Z10XE + Z12XE
dancuciureanu
- Mesaje scrise: 16,465
- SorinXP
- 590 mesaje
- din 27 Aug 2007
- Astra 2006 z19dt
SorinXP
- Mesaje scrise: 590
- Masina: Astra 2006 z19dt
- Cont inregistrat: 27 Aug 2007
- 2,900 mesaje
- din 25 Nov 2007
- Vectra 2003 Z18XE
- Ialomita
- zafira 2.0 automatic
- 1,031 mesaje
- din 15 Nov 2005
- Zafira 2003 y20dth
- Mesaje scrise: 1,031
- Masina: Zafira 2003 y20dth
- Cont inregistrat: 15 Nov 2005
Desigur ca se mareste procentul de apa din lichid pe masura ce trece timpul. Din acest motiv si nu numai se modifica caracteristicile tehnice ale substantei si nu mai are aceiasi eficacitate franarea.
Cred ca numai daca se adauga apa in amestec deja vorbim de alt punct de firbere si puterea masinilor noastre nu mai poate fi stapanita.....
