  2. Opel Insignia
  3. Insignia A
  • cpx07
  • Mesaje scrise: 51
  • Masina: Insignia 2009 A20DTC
  • Cont inregistrat: 01 Sep 2013
Pe un forum din UK am gasit metoda asta, nu am incercat inca.
A verificat cineva? Masina reactioneaza ca acolo pt a-ti da codurile?
Tipul spune ca pe modele mai noi iti poate afisa chiar si in bord codul si ca a verificat pe Astra.
STEP 1:
Get inside your vehicle a firmly place yourself in your seat. Once in, press both the accelerate and brake pedal together
STEP 2:
With both pedals pressed, put your key in the ignition and turn it to position 2, which is the position that switches all auxilary heating on but not the engine
STEP 3:
Once done, the spanner light will start flashing
if it flashes 10 times it means the number is '0' and any other flashes corresponds to a number with a pause between each number
for example code P0110
the light will flash ten times then pause (2sec Or 1 not sure) flash once, (2sec pause) flash once, (2 sec pause) then flash ten times
if you have more than one code it will stop for a break between each code
however if you don’t have any code stored it will start Flashing and keeps on flashing until you release the pedals
If you follow the above steps you are certain to find codes without ever having to plug an OBD equipment
Link: http://www.corsa-c.co.uk/fo...-Fault-codes-mean
  • borsy
  • Mesaje scrise: 3,025
  • Masina: Insignia 2011 A20DT
tu ai incercat metoda?
  • catalinpav66
  • Mesaje scrise: 759
  • Masina: Vectra 2006 z30dt
  • Cont inregistrat: 29 Oct 2008
La Bentley e la fel, l-am vazut eu pe Columbeanu cum citea codurile cu metoda agrafa (la Bentley se numeste metoda acul de cravata de aur). Nici Columbeanu nu are bani de opcom( sau vagcom) si nici de diagnoza in service.
  • cpx
  • Mesaje scrise: 49
  • Masina: Astra 2007
  • Cont inregistrat: 31 Jul 2008
Chiar acum am venit de la masina, la mine nu merge 😊)...ps. am ras la agrafa lu columbeanu 😊 dar nu a fost rea intentie chiar am vazut postat pe un forum de uk si eram curios daca merge si la noi
  • nelutzul40
  • Mesaje scrise: 1,009
  • Masina: Astra 2001 Y17DT
  • Cont inregistrat: 24 Feb 2008
Uni colegi ,,este niste rai,, 😃 dar si butonul ,,cautare,, functioneaza..........
https://www.clubopel.com/viewtopic.php?t=24014
  2. Opel Insignia
  3. Insignia A
