  2. Tutoriale
  • florin_bv
  • Mesaje scrise: 155
  • Masina: Vectra 1997 x17dt
  • Cont inregistrat: 05 Jun 2006
In cautarile mele fara de rost pe net am gasit asta merita pentru ce-i pasionati
http://plaza.umin.ac.jp/~satoshi/mod152en.html
Angel eyes is a name of headlight feature like BMW 5 Series, which is a pair of circular-shape light rings.
I have now succeeded in making perfect angel eyes on celica in the point of brightness, color, and lighting pattern.
This page shows how I made angel eyes, but the procedure is very time-consuming, needs patience, and some experiences.
BMW used a round glass rod, but we couldn't make it. So I decided to use a clear acrlyic rod.
I used on with the 5mm diameter.
First step is to bend the rod into the round shape to fit into our car.
Heat it until be soften. Be careful not to make a fire on i
I found the aluminum bottle which has the same diameter as the projector light lens.
After heating, you could bend it into the round shape by hands.
Dont forget to wear the gloves.
Cut the rod by sanding machine.
[imghttp://plaza.umin.ac.jp/~satoshi/pic2832.jpg[/img]
To refract the light and make the light ring, scratch (half-cut in other words) behind the ring.
Don't do it at one time. Check the light effect, and repeat the procedures.
I made a test machine to examine how it will light up.
Now, many bright LEDs are available.
But the white is the only one legal color.
Red is the brightest.
From the back side, you can see the scratches directly :
but from the front side, scratch will make a clear straight liken because of the lens effect.
BMW used halogen light, but I chose LED for several reasons instead.
Color, quick response, long life is the reason. In addition, LED produce little heat which might damage the rod.
White bright LEDs with the diameter of 5mm.
Cut the long and short foot of a pair of LEDs.
Make it into a pair by soldering the cutten foot.
LEDs are sensitive to heat, so you must check it after soldering.
Connect the resistor, and the power. Appropriate ohm depends on the type of LEDs.
Small clear rubber caps for flat connector was used to connect between LEDs and ring.
These will hidden the LEDs and soldering.
Looks great! Time to install into the head light.
By sanding the back side lightly, you can make whitish rings
Separate the light housing. Please refer to this page
Angel eyes for low beam projector.
Drill the two small holes.
Insert the foot of LED into the holes.
Fix the ring by sticking clear adhesive tapes behind the ring.
Don't use bond. It would make rings cloudy and darker.
Angel eyes for high beam was also installed. Drill the two small holes.
Put LED foots into the holes, and fix the ring using small bit of plastic bond in the bottom of the ring.
Make the wirings from back side. Use the black (which means invisible) wirings.
Test shot. Don't forget to use the resistor.
Put back the light housing, and make the power wirings from position bulb.
  • florin_bv
se apuca cineva ?
  • adibose
  • Masina: Astra 2002 Z20LET
  • Cont inregistrat: 20 Jul 2006
nu cred 😊 desi sunt unii kr n-au ce face... 😊
  • jonny
  • Mesaje scrise: 483
  • Masina: Astra 2001 Z16SE
  • Cont inregistrat: 24 Apr 2005
oricum e interesant tutorialul 😃, poate se baga cineva 😃
  • botosu
  • Mesaje scrise: 1,287
  • Masina: Astra z14xep
  • Cont inregistrat: 17 Mai 2006
Super tare.
Prima intrebare:
De unde iau bara aia de plastic?
A 2-a intrebare:
Omu a pus o rez de 680 ohm in serie cu 2 led-uri de 3,6 V si 20mA. Din schema lui prin led-urile alea trece un curent de:
(12 - 2*3,6) / 680 = 7mA
Unde e greseala ?
PS:
daca led-urile sunt de 3V si cum tens in inst el poate sa ajunga la 14,4 , atunci am avea un curent de ~13 mA.
  • CORBU
  • Mesaje scrise: 1,669
sal si LA MULTI ANI!!! Gata mi s-a pus pata!! eu caut bara transparenta si cel tarziu in primavara o sa am pe masina mea ( astra g caravan) Sa i dea D-zeu sanatate cui o pus adresa aia acolo!! 😂
  • AdamOpel
  • Mesaje scrise: 1,011
  • Cont inregistrat: 07 Nov 2006
tare de tot dar din ce sunt tuburile si de unde se pot procura?
  • claudiu-cld
  • Mesaje scrise: 6,498
  • Masina: Astra 2000 y17dt
e chiar interesant si nu e greu deloc dar numai sa faci rost de acea bara care nu stiu unde o gasesti,in rest e simplu
ideea e dak poti sa pui asa ceva pe farurile stok ale uni opel astra ,nu stiu dk iti permite farul asta
dar cine vrea sa incerce e sustinut moral de mine
SUCCES DEPLIN
  • emmanuel
  • Mesaje scrise: 235
  • Cont inregistrat: 10 Feb 2005
Mi s-a parut mai misto aia cu banda electroluminiscenta !
  • MindToAsk
  • Mesaje scrise: 123
  • Masina: Kadett 1978 12N
  • Cont inregistrat: 04 Jan 2007
Si eu m-as apuca... dar mi-e sa nu fie de neam prost pe masina mea 😂
Ce credeti, ar arata bine?
si btw. nu s-ar ingalbeni plasticul ala la foc?
  • flavius1611
  • Mesaje scrise: 1,037
  • Masina: Astra 2015
  • Cont inregistrat: 12 Jun 2006
dupa cum spune si titlul,am dovezi ca se pot monta angel eyes pe farurile de astr g
ce parere aveti??
kitul costa 250 ron + montajul
mentionez ca nu intermediez nimik am gasit pe net
  • MindToAsk
Stim ca se pot monta... pe orice se pot monta (si pe farul de bicicleta 😂 ). Ideea era ca sa le facem cu manuta noastra si sa mai scutim un banut 🙄
  • Visse
  • Mesaje scrise: 1,464
  • Cont inregistrat: 06 Jun 2005
[quote="flavius1611"]dupa cum spune si titlul,am dovezi ca se pot monta angel eyes pe farurile de astr g
ce parere aveti??
Kitul cine il produce ? si o adresa daca se poate
  • Visse
Da cat timp trebuie sa treaca ptr un raspuns ?
  • love4cars
  • Mesaje scrise: 1,437
  • Masina: Astra Z14XEP
  • Cont inregistrat: 24 Sep 2005
Visse a scris:Da cat timp trebuie sa treaca ptr un raspuns ?
Vad ca ai ramas fara raspuns... uite aici: http://www.proxenon.ro/angeleyes.php
Chiar daca nu apare in lista model pentru masina ta, se poate adapta de la alta 😉
  • dandobre
  • Mesaje scrise: 724
  • Masina: Astra 2003 Y20DTH
Am incercat...nu merge...pentru astra g trebuiesc cercurile prea mari, iar ledurile nu prea au putere sa lumineze ca lumea oglinda creeaza nishte imagini ciudate, mai ales la crestaturile alea.ma las pagubas. oricum, daca vrea cineva sa incerce am gasit bara din aia in bricostore, ca vergea pentru jaluzele.
  • soulfly
  • Mesaje scrise: 294
  • Masina: Vectra 1992 c18nz
a cumparat cineva bara transparenta?
asta ca sa ne spuna si noua de unde s-ar putea procura...
  • dandobre
Am scris mai sus ca se gaseste bara la bricostore ca vergea pentru jaluzele.. 🙄
  • soulfly
sorry
m-am oprit din citit la partea cu "ma las pagubas"
acum am vazut ,mersi! 😊
problema e ca eu sunt din galati,deci o sa caut p'aici ceva asemanator la magazinele care au si jaluzele... k?
  • sebi_glumetu
  • Mesaje scrise: 25
  • Masina: Vectra 2004 Y22DTR
  • Cont inregistrat: 12 Mar 2007
trebuie sa fac si eu. am sa fac un experiment sa vad in lungime c-am cat ar merge pus, poate fac ceva si pt portbagaj( ma gandeam un liminat pe contur. oricum e ceva grozav care trebuie incercat. bafta
  2. Tutoriale
