  2. Discuții generale
  • air2003
  • Mesaje scrise: 15
  • Masina: Astra 2003 1.7DTI
  • Cont inregistrat: 12 Dec 2006
salutare oameni buni
stiu ca pare greu de crezut dar nu gasesc filtrul de ulei la un opel astra caravane 1.7dti din 2003 (pozitia lui pe motor). 😳
am innebunit de frig cautand pe motorul asta inghesuit (fost posesor de tico)
Am innebunit cautand si pe forum inainte sa va deranjez. Mii de scuze daca am incalcat ceva reguli postand. E prima data nu va suparati.
  • love4cars
  • Mesaje scrise: 1,437
  • Masina: Astra Z14XEP
  • Cont inregistrat: 24 Sep 2005
Nu se poate scoate filtrul decat pe dedesubtul masnii!
Este pe latura motorului dinspre spatele masinii.
  • elegance
  • Mesaje scrise: 3,073
  • Masina: Astra 2000 Y 17 DT
😶 Cum sa nu se poata scoate decat de sub masina? E foarte usor de schimbat...
Engine Oil with Oil Filter Change
Remove
Open service aperture in lower engine compartment cover. Remove oil drain bolt – collect escaping engine oil.
When oil drain plug is open, remove cover from oil filter housing and remove oil filter insert (1).
Install
Install new seal rings (2) and (3). Install new oil filter insert in cover and attach to oil filter housing – tightening torque 25 Nm / 18.5 lbf. ft.
Attach oil drain bolt to oil pan with new seal ring – tightening torque 78.4 Nm / 57.8 lbf. ft. Close service opening. Charge with specified volume of engine oil.
Inspect
Start engine and allow it to run until oil pressure telltale extinguishes. Check engine oil level; correct if necessary.
  • BV-31STE
  • Mesaje scrise: 523
  • Cont inregistrat: 22 Feb 2006
Exact
e in spatele motorului
iti trebe ceva cheia franceza sau fixa mai mare ca sa desfaci capacul ala de plastic
