cosminus
- Mesaje scrise: 10
- Masina: Vectra 2004 y/z19dth
- Cont inregistrat: 18 Jun 2007
SALUTARE TUTUROR POSESORILOR DE OPEL. AS VREA SA STIU SI EU , DACA POATE CINEVA SA MA LAMUREASCA, CE FEL DE TRANSMISIE ARE MODELUL VECTRA C , FABRICATIE 2004, MOTOR 1910 CMC CDTI .150CP(110KW). STIAM CA DISTRIBUTIA ESTE PE LANT, LUCRU PE CARE L-AM AUZIT DE LA UN TIP ,MECANIC LA OPEL IN CRAIOVA, DE UNDE SUNT EU, DAR ASA MI-A ZIS SI UNUL CARE ERA SAMSAR DE MASINI SI STIA MODELUL FOARTE BINE. AZI M-AM CONTRAZIS CU CINEVA CARE ZICEA CA TRANSMISIA E PE CUREA. MI-A ZIS CA DACA E TRANSMISIE PE LANT NU AVEA CUM SA FIE DIN PLASTIC MASCA DE LA TRANSMISIE, CI DIN METAL. TOTUSI I-AM ARATAT CA LA MASINA MEA TREBUIE SCHIMBATA TRANSMISIA LA 150000KM SAU 10 ANI!, SCRIE CLAR IN CARTEA TEHNICA A MASINI, DECI NU-MI VINE SA CRED CA E PE CUREA NORMALA, CI PE LANT! VA ROG , LAMURITI-MA CARE DIN NOI ARE DREPTATE !
- gevolleyball
- 105 mesaje
- din 10 Jul 2007
- Vectra 2002 Y22DTR
- Maramures
gevolleyball
- Mesaje scrise: 105
- Masina: Vectra 2002 Y22DTR
- Cont inregistrat: 10 Jul 2007
- mariani
- 769 mesaje
- din 26 Dec 2007
- Mokka 2014
mariani
- Mesaje scrise: 769
- Masina: Mokka 2014
- Cont inregistrat: 26 Dec 2007
- murzick
- 1,007 mesaje
- din 10 Dec 2006
- Vectra 2001 Z18XE
murzick
- Mesaje scrise: 1,007
- Masina: Vectra 2001 Z18XE
- Cont inregistrat: 10 Dec 2006
cosminus, nu ma scrie cu majuscule, este echivalent cu a tipa.
Pe Vectra C 2004 s-au pus 2 tipuri de motor diesel de 1900 cmc - Z19DT si Z19DTH. Ambele sint pe curea. Intervalele de schimbare a curelei conform ultimei versiuni de TIS sint asa:
Z19DT - maxim 6 ani sau 120.000 km.
Z19DTH - maxim 10 ani sau 150.000 km.
lox
- Mesaje scrise: 8
- Masina: Vectra 2005 1.9cdti
- Cont inregistrat: 27 Feb 2008
cosminus a scris:SALUTARE TUTUROR POSESORILOR DE OPEL. AS VREA SA STIU SI EU , DACA POATE CINEVA SA MA LAMUREASCA, CE FEL DE TRANSMISIE ARE MODELUL VECTRA C , FABRICATIE 2004, MOTOR 1910 CMC CDTI .150CP(110KW). STIAM CA DISTRIBUTIA ESTE PE LANT, LUCRU PE CARE L-AM AUZIT DE LA UN TIP ,MECANIC LA OPEL IN CRAIOVA, DE UNDE SUNT EU, DAR ASA MI-A ZIS SI UNUL CARE ERA SAMSAR DE MASINI SI STIA MODELUL FOARTE BINE. AZI M-AM CONTRAZIS CU CINEVA CARE ZICEA CA TRANSMISIA E PE CUREA. MI-A ZIS CA DACA E TRANSMISIE PE LANT NU AVEA CUM SA FIE DIN PLASTIC MASCA DE LA TRANSMISIE, CI DIN METAL. TOTUSI I-AM ARATAT CA LA MASINA MEA TREBUIE SCHIMBATA TRANSMISIA LA 150000KM SAU 10 ANI!, SCRIE CLAR IN CARTEA TEHNICA A MASINI, DECI NU-MI VINE SA CRED CA E PE CUREA NORMALA, CI PE LANT! VA ROG , LAMURITI-MA CARE DIN NOI ARE DREPTATE !
cosminus
- Mesaje scrise: 10
Ok ! Am inteles, e pe curea transmisia, dar intervalul de timp 10 ani sau 150000km ! mi se pare enorm si d- asta eram convins ca motorul masinii are transmisie pe lant . Oricum, bag seama ca in discutii ca asta parerile sunt impartite, am mai gasit pe forum care sustineau ca modelul asta de Vectra are lant.Urmeaza o intrebare fireasca: inseamna ca daca am acum 70000km reali nu tre sa schimb transmisia pana la 150000km ? Precizez ca masina am luat-o la second din Germania de la Bockel in mai 2007, are carte de service, in care am observat ca nu i s-a schimbat transmisia (lucru normal la 44000km cand a fost bagata in service ), doar i s-au facut niste verificari sumare si i s-a schimbat uleiul . Pe tester am pus-o de 2 ori si a primit 10+ de fiecare data.
- DB77AAA
- 6,677 mesaje
- din 19 Jan 2007
- Vectra 2005 Z19DTH 200CP
- Dambovita
DB77AAA
- Mesaje scrise: 6,677
cosminus
- Mesaje scrise: 10
As mai avea o intrebare. De ceva timp mi se aprinde din cand in cand in bord,in casuta de sub vitezometru, un martor luminos care reprezinta o 'lampa', m-am uitat in cartea tehnica si am vazut ca e vorba de martorul care arata ca masinii ii mai trebuie ulei, desi eu i-am schimbat uleiul si filtrele in iunie anul trecut. Care ar fi cauza? Sa fie oare senzorul de presiune a uleiului cam naspa plasat sub masina, care ar putea sa se fi deranjat, sa fie de vina uleiul (desi i-am pus ulei bun MObil 1 0W40) sau altceva? Mentionez ca martorul sta aprins pana cand opresc motorul , la o noua pornire nu se mai aprinde. Trebuie sa scriu si ca nu se intampla decat rar sa se aprinda acel martor in bord. La joja m-am uitat si am verificat nivelul si totul e OK.
