  2. Opel Frontera
  • DUMITRASCU123
  • Mesaje scrise: 47
  • Masina: Frontera 2004 y22dth
  • Cont inregistrat: 23 Jul 2008
PLEC DIN PLOIESTI SPRE BUZAU PE UN CAROSABL ALUNECOS.TREBUIA SA MERG, NU PUTEAM RATA CONCURSUL DE SAH DE LA BUZAU.ROATA STINGA FATA SI SPATE MERGE PE ZAPADA BATATORITA IAR ROTILE DIN DREAPTA PE GHEATA.AM SAHIST IN MASINA LINGA MINE SI-MI SPUNE MAI PARCA TOT FUGE DE SPATE.EU OBSERVASEM DE MULT DAR SA NU-L BAG PE OM IN PANICA. ACUM INTREB SPECIALISTII?.ACTIONEAZA SINGUR ESP?. TREBUIE SA ACTIONEZ SI EU DIN VOLAN?.TREBUIE SA MERG NUMAI CU 4X4 CUPLAT?. TREBUIE SA DAU 4X4 NUMAI CIND PATINEAZA? 😠 TREBUIE SA NU INTRU IN PANICA FIINDCA ACTIONEAZA ESP-UL SI SA-MI VAD DE DRUM? 😂
VA RAPORTEZ CA ACEST LUCRU SE INTIMPLA NUMAI CIND INTERVINE GHEATA.DACA MERG PE USCAT SAU PE ZAPADA MERGE DE NU TE-AI MAI DA JOS DIN MASINA.ADICA CU 4X4 CU ABS CU ESP CU CAUCIUCURI DE IANA 245-70-R16 SA-MI FIE FRICA PE GHEATA???.CIRCULAM CU DACIA DIN 1978 PE GHEATA FARA NIMIC SI CU CAUCIUCURI DE VARA INTR-O VESELIE TOTALA. DIFERENTA ESTE CA ATUNCI TINERETEA I-MI DADEA INCREDERE.ACUM ORI CA PRECAUTIA ESTE PREA MARE ORI NU SUNT RECEPTIV LA NOU ORI AM UN DEFECT LA MASINA. DECI MERG LINISTIT CU MASINA EU FARA SA ACTIONEZ NIMIC SIMT CA DIN CIND IN CIND SE ASEAZA DIN SPATE.,SUDOAREA ALEARGA DIN AMBUNDENTA PE SIRA SPINARII CAPUL SUS SI TOT INNAINTE PE GHEATA SI ZAPADA.VA SALUT VOIOS.
  • bozo
  • Mesaje scrise: 127
  • Masina: Frontera 1996 x20se
  • Cont inregistrat: 20 Nov 2012
Dacia nu avea tractiunea pe spate...
Esp-ul poate sa nu functioneze. Ar trebui sa il simti cand intervine, si blocheaza roata care patineaza.
Si chiar daca functioneaza nu face minuni... Totul e sa nu bruschezi comenzile, si sa te dai putin pe gheata cu masina sa ii vezi limitele, cand intra in derapaj si cum poti sa o redresezi, in conditii sigure, ca sa stii ce ai de facut la nevoie.
  • Andrei_vl
  • Mesaje scrise: 753
  • Masina: Frontera 1995 23DTR
  • Cont inregistrat: 27 Mar 2011
Pe gheata nici mama ESPului nu te ajuta... masina grea de fata si usoara de spate+ anvelope umflate+ amvelope de calitate slaba+ propulsie= reteta perfecta... si daca mai si accelerezi fara sa simti limita la care patineste, imediat fuge... dar totusi nu cred ca e de speriat cu ea...
- LSD s-a pus si pe Frontera B?-
  • SUPERDRAGOS
  • Mesaje scrise: 2,655
In conditii de gheata/zapada se merge cu 4x4.Ca de asta e buton in bord.Cu Frontera sau cu orice alta masina cu tractiune spate esti mult sub orice masina cu tractiune fata.De asta transpiri...
PS-Cred ca TOATE au LSD,standard.
PS2-La concursul de sah nu trebuie sa te grabesti...Prin definitie..
  • cip077
  • Mesaje scrise: 1,239
In primul rand D-le DUMITRASCU, NU MAI TIPA LA NOI, ca intelegem de vorba buna(v-am mai spus mai demult)
Si la mine face la fel. E o aventura sa mergi cu viteza pe drum care alterneaza uscat-umed-zapada.
La mine stiu ca am directia dereglata, si ceva joc la pivoti, dar astept sa dea caldura, acum nu umblu la ei. Deci e total valabil cum au spus colegii mai sus, cu referire la tractiunea spate, dar e de verificat si unghiurile la directie. Am mers si cu alte B-uri si nu facea asa, deci NU trebuie sa 'fuga' de fata sau spate cand se schimba aderenta.
Nu e obligatoriu sa se mearga pe 4x4 permanent, chiar daca e zapada pe drum. De exemplu, eu cuplez doar cand fac vreo depasire sau cand am ceva viraj, in rest stau pe 4x2. Pentru siguranta, atunci cand drumul e acoperit total sau conditii meteo rele, se poate merge si cuplat, dar cand e sa derapeze..., se duce si cu 8x8.
ESP nu cred ca aveti in dotarea masini. E doar o parere, si faptul ca am vazut mai multe B-uri, nici una nu avea ESP.
@Dragos, nu toate B-urile au LSD. Sigur. Este o optiune ca oricare alta.
  • Andrei_vl
Eu sunt singuru care merge relaxat cu 4x2? ...
Daca are LSD si pe jos e gheata, iti mai trebe putina inclinatie ca sa ai iepurele cu tot cu gradinar in... torpedo... LSDu blocheaza brusc roata ce patineaza si in felu asta alterneaza patinaju cu aderenta si de aici senzatia ca " mai fuge de... spate"
( experienta proprie: gheata+ inclinare laterala+ LSD- cand a " intrat" in functiune LSDu, era sa dau cu masina in rapa...)
1.Las-o sa vezi cat se duce ( sa speram ca nu pana in sant, invata-te cu ea, si sigur va fi OK).
2.Pune-i niste gume de iarna bune si va fi si mai ok! ( nu vreau sa spun ce penibil e sa ramai de 4 ori in zapada intr-o luna, cu gume chinezesti...)
  • bozo
Asta e cu tractiunea spate... Se poate si mai rau, imagineaza-ti o masina puternica, cu ambreiaj sport, care bruscheaza destul de mult, gen BMW...
Oricum gheata e periculoasa, orice fel de trectiune ai avea.
  • Andrei_vl
Sau o masina de teren cu ambreiaj heavy- duty ( ex. cu disc de ambreiaj cu pastile ceramice...) 👽
  • bozo
E vorba mai mult de cursa ambreiajului. La alea sport cum ridici putin, cum cupleaza de tot.
  • stelea
  • Mesaje scrise: 1,721
Cu sau fara ESP, in conditiile in care sunt suprafete cu aderenta diferita, masina are tendinta sa fuga in lateral functie de suprafata.
E bine daca ai posibilitatea sa te "joci" cu masina sa vezi cum raspunde la derapaje si la masurile de redresare.
Ce am observat eu ... in 4x2 tractiune spate, daca fuge de spate redresez cu frana de motor; in 4x4 daca fuge de spate sau fata redresez prin accelerare. Foarte mult conteaza si cauciucurile.
  • cosmin machita
  • Masina: Frontera 2000 y2.2.dth
  • Cont inregistrat: 04 Feb 2018
salut.
gasesc si eu aici la cineva planetare fata de frontera b 2.2dth?
sau se potrivesc de la alta masina?
de isuzu troper am av la proba...nu se potrivesc.sunt mai mici cu 2 mm diam la nutele ext la roata
  2. Opel Frontera
