  2. Opel Zafira
  3. Zafira A
  • deleted-13334
  • Mesaje scrise: 123
  • Cont inregistrat: 29 Dec 2007
imi poate spune cineva valorile injectoarelor ?am adaugat 2 imagini cu ce a iesit la test
  • suspended-9452
  • Mesaje scrise: 2,449
  • Masina: Astra 2016 B14XER
ce ai postat tu nu reprezinta valorile injectoarelor.
valorile din poze sunt corecte, inclusiv corectiile facute.
  • mirel_ch
  • Mesaje scrise: 129
  • Masina: Vectra 2004 y22dtr
cum trebuiesc facute aceste corectii? in functie de ce anume? la mine calculatorul de bord indica cu 1l/100km mai mult decat in realitate
la mine sunt urmatoarele valori:
System Voltage 14.1 V
Accelerator Position Sensor Signal 0.00%
Idle Switch Active
Mass Air Flow Sensor 349 mg/strk
Barometer Sensor 1.0 bar
Boost Pressure Command 1.1 bar
Boost Pressure 1.0 bar
Intake Air Temperature 38 °C
Coolant Temperature 96 °C
Engine Oil Temperature 90 °C
Fuel Temperature 38 °C
Brake Switch 1 Inactive
Brake Switch 2 Inactive
Clutch Switch Inactive
A/C Information Switch (Air Conditioning) Inactive 0V
Fuel Cutoff Valve Active
Start of Delivery 22.7 °CA
Desired Injection Start 4.8 °CA
Actual Injection Start 4.7 °CA
Desired Injection Quantity 5.9 mg/strk
Injection Quantity 5.7 mg/strk
Pulse Ratio Boost Pressure Solenoid Valve 45.00%
EGR Command (Exhaust-Gas Recirculation Command) 354 mg/strk
EGR Pulse Ratio (Exhaust Gas Recirculation) 25%
Swirl Level Control Solenoid Valve Pulse Ratio 65.00%
Desired Engine Idle Speed 840 RPM
Engine Speed 838 RPM
Pump Speed 419 RPM
Diagnosis Glow Time Relay Active
Glow Time Relay Inactive 12V
Key (I) (Set/Accelerate) Inactive
Key (R) (Set/Decelerate) Inactive
Key (O) (Switch Off) Inactive
Vehicle Speed 0 km/h
Vehicle Speed Command 0 km/h
A/C Relay (Air Conditioning) Inactive 12V
Telltale (Check Light) Off 12V
Glow Time Telltale Off 12V
High Pressure Diagnosis 1 0 Counts
High Pressure Diagnosis 2 0 Counts
  • mikyboy
  • Mesaje scrise: 5,734
ce cauciucuri ai pe masina si mai ales cum ai calculat ca indica mai mult?...
  • mirel_ch
am 195/65r15. am fost pe la munte si am facut in total 708 km cu 55L(asa arata pe BC) iar in rezervor mai era un sfert(cam 14-15L arata pe tester) ori tot rezervorul are 60L.
bc-ul imi arata un comsum mediu de 7.8.
Consumul mediu real, cu ce mai era in rezervor e de 6.4, conform calculelor mele
  • florin220791
  • Mesaje scrise: 11
  • Masina: Zafira 2002 2.0 dti
  • Cont inregistrat: 09 Oct 2009
salut am facut astazi un test la injectoare la un y20 dth si in 25 de minute a dat foarte putina motorina pe retur acum ce sa inteleg ?
  2. Opel Zafira
  3. Zafira A
