  2. Opel Calibra
  • sergyu
  • Mesaje scrise: 324
  • Masina: Astra 2005 Z20LER
http://www.youtube.com/watch?v=KNSV-BHDouE Ce parere aveti ?
Ultima modificare făcută de sergyu la Vin 27 Oct, 2006 3:45 pm
  • Calibra-Turbo
  • Mesaje scrise: 128
  • Cont inregistrat: 01 Jun 2005
You have to delete the . at the end of your URL.Then it will work.
I like that MID more 😊
  • alias
  • Mesaje scrise: 206
  • Masina: Calibra 1997 C 20 LET
  • Cont inregistrat: 04 Jan 2006
sti si de unde se poate cumpara sistemul asta?
  • Calibra-Turbo
nowhere.it is selfmade.
  • sergyu
Oricum ma gindesc sa imi pun si eu un MID in masina 😶 .
  • botosu
  • Mesaje scrise: 1,287
  • Masina: Astra z14xep
  • Cont inregistrat: 17 Mai 2006
good job.
can you give more details about this nice project Question
  • Calibra-Turbo
Two LCDs with CPU 8 bit A/D converter and 8 analog inputs.Temperaturesensors PT 100 with 3 conductortechnic with 1/8" thread.Lambda value is taken from car ECU.Exhaust temperature with thermal element type K.
On the left LCD it can be switched between batterievoltage,boostair temperature,oil temperature,water temperature or the current power stage with its programmed boost and power.
On the right side you can see boost pressure graphical,lambda value,boost pressure in numbers,exhaust temperature.
Front black metal cover was cut with a laser.
  • Vinti
  • Mesaje scrise: 886
  • Cont inregistrat: 13 Nov 2005
poate sa-mi zica si mie cineva in romana cum se pune asa ceva
  • BUBU87CALIBRA
  • Mesaje scrise: 180
  • Masina: Calibra 1993 C20LET
  • Cont inregistrat: 04 Dec 2006
Eu am ramas socat cand am vazut la cat il ducea consumu cand o accelereaza mai tare, sa zicem 4000-4.500 ture si daca vazui bine scria 59l 😶 😶 😶 😶
  2. Opel Calibra
