- iulian1971
- 7,066 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- Mesaje scrise: 7,066
- Masina: Astra 2008 Z19DTH
goahead
- Mesaje scrise: 52
- Masina: Insignia 2012 a20dtr
- Cont inregistrat: 04 Mai 2008
salut
opel astra g 2003 motor y20dth. Dupa inlocuire filtru de motorina a pornit 2 sec si a scos fum alb si mult.
nu a mai pornit si avem urmatoarele erori:
e posibil sa se fi ars ecu?
Car Scanner ELM OBD2
DTC report
Selected brand: Opel
============1==============
P0606(ED)
Raw code: 0606ED
ECU: 11
Status: Test failed, Test not completed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested
Engine control module (ECM)/powertrain control module (PCM) - processor fault
Control Module Processor Performance Supervision Software Malfunction; Control Module Processor Performance Incorrect Component Installed; Control Module Processor Performance Internal Communication Malfunction
============2==============
P1630(2B)
Raw code: 16302B
ECU: 11
Internal Vref Malfunction
Theft Deterrent Learn Mode Active; Injection timing control - circuit malfunction
============3==============
P1630(00)
Raw code: 163000
ECU: 11
Status: Test failed, Test not completed during this operation cycle
============4==============
P0380(2B)
Raw code: 03802B
ECU: 11
Glow plugs, circuit A - malfunction
============5==============
P0606
Raw code: 0606
ECU: 11
Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request, Validated fault has been present during this drive cycle
============6==============
P1630
Raw code: 1630
ECU: 11
Status: Pending fault present, Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory
DTC report
P0606(ED)
Raw code: 0606ED
ECU: 11
P1630(2B)
Raw code: 16302B
ECU: 11
P1630(00)
Raw code: 163000
ECU: 11
P0380(2B)
Raw code: 03802B
ECU: 11
P0606
Raw code: 0606
ECU: 11
P1630
Raw code: 1630
ECU: 11
- iulian1971
- 7,066 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
goahead
- Mesaje scrise: 52
- bruttus
- 239 mesaje
- din 29 Jan 2013
- Astra 2001 y20dth
bruttus
- Mesaje scrise: 239
- Masina: Astra 2001 y20dth
- Cont inregistrat: 29 Jan 2013
goahead
- Mesaje scrise: 52
- bruttus
- 239 mesaje
- din 29 Jan 2013
- Astra 2001 y20dth
bruttus
Calculatorul de la pompa asta,este in acelasi timp si ECU-ul masinii,asta este si motivul pentru care nu se poate repara aceasta pompa,sau cel putin nu la nivel profesional,ai 2 in 1.
De cite ori se schimba pompa asta,trebuie sa faci si operatia de codificare ca si cind ai fi schimbat ECU la un alt tip de masina.
