peeter595
- Mesaje scrise: 10
- Masina: Vectra 1997
- Cont inregistrat: 08 Feb 2017
OP-COM 100219a - PC based diagnostic tool
Date and time>,07/02/2017. 21:2744
Workshop information:
Selected model>,1997 (V),Vectra-B,Engine,X 16 XEL
Control Unit:
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L000038V5101843
RepairShopCodeOrTesterSerialNumber: Not programmed
ProgrammingDate: FFFFFFFF
systemSupplierECUHardwareNumber: 16202280
vehicleManufacturerECUHardwareNumber 16202319 NL
systemSupplierECUSoftwareNumber: BZKU
systemSupplierECUSoftwareVersionNumber: 0004
exhaustRegulationOrTypeApprovalNumber: D96003
systemNameOrEngineType: X16XEL
Identifier: 0102
Measuring blocks information:
System Voltage,14.4 V
Immobiliser,Active
Immobiliser Signal,Received
Fuel Pump Relay,Active 0V
TPS Signal (Throttle Position Sensor),0 %
TPS Signal (Throttle Position Sensor),0.57 V
MAP Sensor (Manifold Absolute Pressure),0.36 bar
MAP Sensor (Manifold Absolute Pressure),1.73 V
Coolant Temperature,84 °C
Coolant Temperature,2.20 V
Intake Air Temperature,-40 °C
Intake Air Temperature,4.97 V
Transmission Coding,Manual Transmission
Park/Neutral Switch,R-D-3-2-1 12V
A/C Information Switch,Inactive 0V
A/C Load Signal (Air Conditioning),Inactive 0V
Injection Pulse,6.3 ms
Clear Flood Mode,Inactive
Spark Angle before TDC (Top Dead Centre),10 °CA
Knock Cell Number,10
Cyl.1 Knock Retard,0 °CA
Cyl.2 Knock Retard,0 °CA
Cyl.3 Knock Retard,5 °CA
Cyl.4 Knock Retard,0 °CA
Secondary Air Pump Relay,Inactive
Air Control Solenoid,Inactive
EGR Position Command (Exhaust- Gas Recirculation),0 %
EGR Position Feedback (Exhaust Gas Recirculation),0 %
Fuel Tank Ventilation Valve,0 %
O2 Sensor,119 mV
Air/Fuel Ratio,14.6
O2 Sensor Loop,Open
Air/Fuel Status,Lean
O2 Integrator,180 Steps
O2-Loop BLM Enable (Block Learn Map),Active
O2 BLM Cell Number (Block Learn Multiplier),18
O2 BLM Cell Content (Block Learn Multiplier),150
Engine Speed,850 RPM
IAC Control Enable (Idle Air Control),Active
Idle Air Control,44 Steps
Desired Idle P-N,900 RPM
Idle Adjust P-N,Not Modified
Desired Idle Drive (R-D-3-2-1),850 RPM
Idle Adjust Drive (R-D-3-2-1),Not Modified
Desired Engine Idle Speed,850 RPM
Idle Adjust,Not Modified
Engine Load,9 %
Torque Control,Inactive
A/C Relay (Air Conditioning),Inactive 12V
Air Conditioning,Not Present
Vehicle Speed Pulse,Not Received
Vehicle Speed,0 km/h
Telltale (Check Light),On 0V
Blink Code Request,Inactive 12V
Dec. Fuel Cutoff (Deceleration),Inactive
Full Load Enrichment,Inactive
peeter595
- Mesaje scrise: 10
- voicu petre
- 3 mesaje
- din 13 Aug 2015
- Vectra 1997
voicu petre
- Mesaje scrise: 3
- Cont inregistrat: 13 Aug 2015
- corsa.timis
- 490 mesaje
- din 29 Dec 2014
- Corsa 2001 Z12XE
- Timis
corsa.timis
- Mesaje scrise: 490
- Masina: Corsa 2001 Z12XE
- Cont inregistrat: 29 Dec 2014
raz40
- Mesaje scrise: 71
- Masina: Vectra 2001 Z16XE
- Cont inregistrat: 14 Nov 2016
