SPopa977
- Mesaje scrise: 5
- Masina: Astra 2011 17dtr
- Cont inregistrat: 29 Apr 2019
KnX
- Mesaje scrise: 82
- Masina: Astra 2011 A17DTJ
- Cont inregistrat: 19 Oct 2015
criste
- Mesaje scrise: 79
- Cont inregistrat: 08 Oct 2016
ruk
- Mesaje scrise: 47
- Masina: Corsa 2002 z10xe
- Cont inregistrat: 11 Aug 2013
criste a scris:Atasez valorile din op-com dupa 55min de mers cu masina treapta 2 -2700ture 20min, treapta 3 - 2500ture 20min.
Measuring blocks information:
Sensor 1 Exhaust Gas Temperature 248 °C
Sensor 1 Exhaust Gas Temperature 1.39 V
Sensor 2 Exhaust Gas Temperature 259 °C
Sensor 2 Exhaust Gas Temperature 1.41 V
DPF Differential Pressure Sensor 6 kPa
DPF Differential Pressure Sensor 0.59 V
DPF Soot Accumulation 96%
DPF Regeneration Status 0%
HO2S 1 1.966 lambda
HO2S 1 0.686 V
Engine Speed 2.804 RPM
Desired Idle Speed 900 RPM
ECT Sensor 92 °C
IAT Sensor 1 25 °C
MAF Sensor 36.95 g/s
Engine Load 5.90%
Accelerator Pedal Position 0%
Intake Air Flow Valve Position 68%
Boost Pressure Sensor 105 kPa
BARO (Barometric Pressure) 99.0 kPa
System Voltage 12.2 V
Vehicle Speed 45 km/h
Engine Runtime 00:55:33
Valori injectoare la rece:
Fuel Heater Command Off
Fuel Temperature Sensor 1 17 °C
Fuel Temperature Sensor 2 16 °C
Fuel Temperature Sensor 2 3 V
Fuel Rail Pressure Regulator Command 35.70%
Fuel Rail Pressure Regulator Command 1.733 mA
Desired Fuel Rail Pressure 29.2 MPa
Fuel Rail Pressure Sensor 29.3 MPa
Fuel Rail Pressure Sensor 1.47 V
Engine Speed 849 RPM
Desired Idle Speed 850 RPM
ECT Sensor 18 °C
IAT Sensor 1 23 °C
MAF Sensor 13.13 g/s
Engine Load 42.40%
Intake Air Flow Valve Position 92%
Boost Pressure Sensor 98 kPa
Tank Sensor 1.53 V
System Voltage 14.6 V
Vehicle Speed 0 km/h
Cylinder 1 Balancing Rate -0.066 ms
Cylinder 2 Balancing Rate -0.078 ms
Cylinder 3 Balancing Rate 0.086 ms
Cylinder 4 Balancing Rate 0.038 ms
Engine Runtime 00:00:39
Mentionez ca am si led la oglinda care imi arata cand incepe regenerarea.
Ledul sta aprins 12-15min si se stinge, dar filtrul nu se regenereaza!
Poate isi da cineva seama de ce nu se regenereaza dpf-ul dupa ce vede aceste valori.
HO2S 1 1.966 lambda
HO2S 1 0.686 V
ECT Sensor 92 °C
IAT Sensor 1 25 °C
Engine Load 5.90%
ECT Sensor 18 °C
IAT Sensor 1 23 °C
Engine Load 42.40%
Tank Sensor 1.53 V
salut,
ce opcom ai?
intreb, ca am si eu unul 1.99 si nuse conecteaza la masina
in legatura cu dpful, iti este prea incarcat, trebuie sa il dai jos, trebuie curatat, poti face asta la odorheiu secuiesc sau la altii
lasa computerul de bord tot timpul pe consum instant, cand isi face regenerare creste consumul instant (cand stai pe loc ) de la 0.5 l/h la 1.5, 2 l/h
altau este prea incarcat si deaia dureaza atata
sau anulat, dar na, poluezi
orice masina cu dpf nu este indicata in oras
eu o folosesc 95 % in oras si asta nu ii place
spor
criste
- Mesaje scrise: 79
ruk
- Mesaje scrise: 47
criste a scris:Am verificat nivelul uleiului dupa regenerare si într-adevãr aveam motorina in ulei, cam 0,5l în plus. Evident ca l-am schimbat.
Astazi am mai avut o regenerare normalã fara mesaj in bord la 280km, mers mixt. Viata uleiului a scazut cu 3%.
O sa monitorizez sa vad cum decurg lucrurile.
de unde ai cumparat opcomul?
criste
- Mesaje scrise: 79
L-am cumpãrat din Craiova de pe un site.
Este Opcom 2015 Revision C - asa zic ei.
Dar softul nu imi permite sa fac activari de diferite optiuni' doar sa vad anumite chestii si sa sterg erori. Imi da eroare cand incerc sa programez ceva.
Pana mi l-au dat pe acesta am mai incercat 3-4 bucati dar nu a mers niciunul .
- Palade florin
- 1 mesaje
- din 20 Mai 2019
- Astra 2014 Y17DTC
- Teleorman
Palade florin
- Mesaje scrise: 1
- Masina: Astra 2014 Y17DTC
- Cont inregistrat: 20 Mai 2019
criste a scris:Salut,cel mai probabilpoate fi actuatorul de la turbina care nu face deschiderea turbinei complet și implicit nu evacueazã particulele complet. La ultimu comentariu pe care l-ai fãcut, unde arãtai cum a decurs regenerarea, se pare cã actuatorul a deschis complet clapeta turbinei și a permis ecacuarea completa a particulelor. Vezi ca actuatorul se decapsuleaza cu mare atenție, se curata cu sprey de contacte bine bine bine, se capzuleaza la loc și funcționeazã ca nou. Spun asta pt. ca mi sa intimpla și mie, mecanicul mia spus ca trebuie sã achiziționez actuatorul, care costa în jur de 1450-1500 roni și era și aftarmarket. Îți doresc succes.
Problema cu regenerarea lunga a inceput acum 600km cand regenerarea a durat o ora de mers la 2600-3000ture treapta 2.
Primul mesaj care a aparut in bord a fost
dupa 30min s-a schimbat in acesta
am mai mers inca 30min si a disparut de pe ecran mesajul.
Viata uleiului a scazut cu 20%.
De atunci am mai avut o regenerare scurta la 350km mers mixt, viata ulei a scazut cu 1% si inca o regenerare lunga la 250km, mers 80% urban, pe care nu am reusit sa o termin dupa o ora de mers si a oprit masina cu mesajul afisat in bord.
Credeti ca ar fi bine sa mai incerc inca o regenerare in mers sau sa o duc la un mecanic/service sa depisteze cauza regenerarii lungi?
Am fost la cativa mecanici cu aceasta problema, dar acestia mi-au propus sa anulez dpf-ul.
Alte probleme la masina:
Ocileaza la relanti cu motorul cald.
Se mai aude cateodata un tacanit de injectie cand accelerez
si in treapa a 3-a la mers constant, 2000-2200 ture se mai aude cateoadata tacanitul de injectie.
Masina: Astra J 2011 A17DTJ 80kw, 275000 km.
Va multumesc!
MODEL: Astra 2011
MOTOR: A17DTJ
Va multumesc!
MODEL: Astra 2011
MOTOR: A17DTJ
RRares
- Mesaje scrise: 4
- Cont inregistrat: 07 Mar 2019
Salutare,
O problema asemanatoare am avut si eu:
Martor: service vehicle soon in bord si putere limitata. Pe tester 77% grad incarcare si eroare pe senzorul DPF. Inlocuiesc senzorul, merge normal masina 20 de km dupa care iar se limiteaza. Am hotarat sa accept varianta sa mi se dea jos filtrul de particule si sa se curete manual, in cuptor etc.
Dupa 1000km de mers ok cu ea, mi-a aparut iar mesajul service vehicle soon, nu mai statea turata si dadea sa se inece. Pe teste eroare de EGR si DPF 98%. Merg la un mecanic vestit, curata EGR, regenerare DPF pe loc din tester si masina si-a revenit.
Dupa 5 zile aceeasi problema. Mesaj pe tester: EGR Excesive flow. Inlocuiesc EGR, garnitura EGR si epurator gaze cu furtun. A trecut o saptamana de atunci si masina merge normal acum. EGR-ul vechi era plin de funingine dupa 5 zile de la curatare.
A20DTH, 2010, 224.000km, 160 cai
Sper ca am fost de ajutor
- aaresis
- 239 mesaje
- din 01 Aug 2007
- Vectra 2005 1.9DTH
aaresis
- Mesaje scrise: 239
- Masina: Vectra 2005 1.9DTH
- Cont inregistrat: 01 Aug 2007
florin1z
- Mesaje scrise: 20
- Masina: Zafira 2009 A17DTR
- Cont inregistrat: 06 Sep 2018
- Paraschiv Marian
- 3 mesaje
- din 11 Oct 2019
- Astra 2014
- Dolj
Paraschiv Marian
- Mesaje scrise: 3
- Cont inregistrat: 11 Oct 2019
Buna ziua am si eu o problema imi scade viscozitatea la ulei si imi porneste regenerarea cu mult fum alb ca si cum ar fi consum de ulei fum alb inecator la miros.Masina imi indica caci trebuie sa schimb uleiul caci mai are trei la suta viscozitate si nu am parcurs cu acest ulei decit 6500 km .Mentionez caci am facut schimbul de ulei cu cel recomandat adica 5w30 am pus mobil one care este recomandat pentru filtru de particule.Care ar putea fi cauza de ii reduce viscozitatea asa de repede .Mentionez caci masina are 211 000 km.
MODEL: Astra J 2014
MOTOR: 1686 cm si 110 cp
MODEL: Astra J 2014
- deleted-30842
- 1,416 mesaje
- din 06 Mar 2009
deleted-30842
- Mesaje scrise: 1,416
- Cont inregistrat: 06 Mar 2009
Marian , ce vezi tu acolo in bord , nu e vascozitatea uleiului ,este doar ceva informativ cu viata uleiului si procentajul acela in regim de oras scade foarte repede , nu il lua in seama .Daca vrei sa vezi cum este uleiul , il verifici la joja si vezi cum se prezinta.
In legatura cu regenerarile si fumul alb , este normal sa scoata fum , pt. ca filtru de particule in momentul regenerarii se incinge undeva pe la 600 ....700 de grade , stai linistit asa este normal .Iesi cu masina in afara din cand in cand si mergi cu ea turata pe la 2000 .....3000 de ture cativa km sa se curete dpf-ul , probabil mergi mult in regim de oras subturat si incearca sa nu ratezi nici o regenerare , sa o lasi sa termine( in mers , nu pe loc) si dupa sa opresti motorul .Viata uleiului o poti reseta in bord iar la 100 %.
- Paraschiv Marian
- 3 mesaje
- din 11 Oct 2019
- Astra 2014
- Dolj
Paraschiv Marian
- Mesaje scrise: 3
- deleted-30842
- 1,416 mesaje
- din 06 Mar 2009
deleted-30842
- Paraschiv Marian
- 3 mesaje
- din 11 Oct 2019
- Astra 2014
- Dolj
Paraschiv Marian
- Mesaje scrise: 3
DMihai281
- Mesaje scrise: 30
- Masina: Insignia 2014 A20DTH
- Cont inregistrat: 18 Jul 2018
- dancuciureanu
- Moderator
- 16,465 mesaje
- Agila 2001 Z10XE + Z12XE
dancuciureanu
- Mesaje scrise: 16,465
LTamas
- Mesaje scrise: 3
- Cont inregistrat: 02 Dec 2019
Salutare gasca, am si eu un Opel astra h 1.9 cdti 150 cp din 2007,si am ajuns cu belele la filtru de particule care este îmbâcsit maxim, vreau sa ii fac o curãtare la un centru specializat, credeti ca merita?... Si 350 lei este scump o curãtare?.. Mam gândit si la anularea lui dar a o cunostintã care a fãcut asa ceva la un Logan din 2010 si a distrus masina!
Întrebarea mea este odatã fãcutã aceasta spãlare oare este un nr de km la care ar trebui fãcutã din nou spãlarea sau rãmâne la pãrerea mea când sau a unui mecanic ca trebuie sa nu fãcutã!
Dacã a fãcut cineva o spãlare a dpf-ului va rog sa îmi rãspundeti ca sunt curios cum se comporta masina!!
- paul2004
- 397 mesaje
- din 28 Aug 2013
- Astra 2010 A17DTR
paul2004
- Mesaje scrise: 397
- Masina: Astra 2010 A17DTR
- Cont inregistrat: 28 Aug 2013
Eu am facut o spalare a dpf.ului la un centru specializat in aprilie 2018.
Toata lucrarea a fost 800lei...demontat....spalat...remontat...invatare din tester.
Urban pana sa vina iarna isi facea regenerare la 280...300km....de cum a venit un pic frigul cam la 150km.asta dupa spalare....Inainte de spalare se regenera de 3...4 ori pe zi.....si imi disparea foarte greu martorul din bord,si mesajul cu filtru de particule full.
De atunci a devenit masina sotiei...si face cam 3000km pe an.
Dar.....
Am avut norocul ca cei de la service nu m.au anuntat ca la demontarea dpf.ului este posibil sa se duca senzorii de temperatura si cel de presiune montati pe dpf.
Pt ca cel de temperatura a fost stricat cand l.au demontat(in cap are un filament ca cel de bec).
Dar neanuntandu.ma...a trebuit sa suporte ei inlocuirea lui.
Deci pe langa cei 800 lei mai i.a in calcul inca vreo 500....600 lei contravaloarea senzorilor.
Acum gradul de infundare dupa regenerare este 20%.
La lucrare beneficiezi de garantie 1an.
Multa bafta.
Dar.....
Multa bafta.
