V-am dat mura in gura si degeaba
Ati citit sau ma maninca degetelele ?
If your car is cold, like it has sat unused overnight, you can check the oil level right away. The oil will have had time to settle back into the sump. Just make sure the car is level before you do. If the engine is warm or hot, like you've just been driving, then you should wait for 30 minutes or so to let as much oil as possible drain back into the sump. Ideally, checking it first thing the next morning is ideal.
Si asta nu a scris-o un fraier !
Nici nu stiu de ce imi mai bat capul, care vrea citeste si pricepe, care nu sa faca dupa cum zice Nea Gica, ca el le stie pe toate.
