florinike- Suspendat
- 1,582 mesaje
- din 22 Feb 2005
- Astra 2001 Z20LET
florinike- Mesaje scrise: 1,582
- Masina: Astra 2001 Z20LET
- Cont inregistrat: 22 Feb 2005
Corsa 1.4
Number of seats 5
Engine
Engine code Z14XE
Engine type Otto, Front transversal
Number of cylinders 4, In-line
Engine capacity 1364 cm3
Number of valves 16 DOHC
Fuel Petrol, Injection by cylinder
Supercharging None
Bore 73.4 mm
Stroke 80.6 mm
Compression ratio 10.5
Max Power 66 kW (ECE) 5600 rpm
Max torque 125 Nm (rpm) 4000 rpm
Transmission & Drive
Drive front-wheel drive
GearBox 5 Auto
Steering type Electric power
Brakes & Tyres
Wheels 5.5Jx14
Front tyres 175/65R 14
Rear tyres 175/65R 14
Front brakes Ventillated disc
Rear brakes Drum
Suspensions
Front Suspension MacPherson strut, Coil spring, Trailing-arm, Stabilizer bar
Rear Suspension Coil spring, Stabilizer bar, trailing arm, twist axle suspension
Dimensions
Wheelbase 2491 mm
Length 3839 mm
Width 1646 mm
Height 1440 mm
Track (front) 1435 mm
Track (rear) 1426 mm
Curb weight 1053 kg
Max. weight 1505 kg
Trunk 260 l - 1060 l
Fuel tank 44 liter
Performance
Top speed 177 km/h
Acceleration 0-100 km/h 12.5 s
Consumption
In the city 7.7 l/100 km
Out of city 4.5 l/100 km
Average consumption 5.7 l/100 km (EU)
Astra 1.4
Number of seats 5
Engine
Engine code Z14XE
Engine capacity 1389 cm3
Supercharging None
Bore 77.6 mm
Stroke 73.4 mm
Max Power 66 kW (ECE) 6000 rpm
GearBox 5 Manual
Steering type Hydraulic power, Electric power
Brakes & Tyres
Wheels 5.5Jx14
Front tyres 175/70R 14
Rear tyres 175/70R 14
Rear brakes Disc
Suspensions
Dimensions
Wheelbase 2606 mm
Length 4252 mm
Width 1709 mm
Height 1425 mm
Track (front) 1464 mm
Track (rear) 1452 mm
Curb weight 1090 kg
Max. weight 1620 kg
Trunk 460 l - 1230 l
Fuel tank 52 liter
Performance
Top speed 180 km/h
Acceleration 0-100 km/h 12 s
Consumption
In the city 9.7 l/100 km
Out of city 5.8 l/100 km
Average consumption 7.2 l/100 km (EU)
Number of seats 5
Engine
Engine code Z14XE
Supercharging None
Bore 73.4 mm
Stroke 80.6 mm
GearBox 5 Auto
Brakes & Tyres
Wheels 5.5Jx14
Rear brakes Drum
Suspensions
Dimensions
Wheelbase 2491 mm
Length 3839 mm
Width 1646 mm
Height 1440 mm
Curb weight 1053 kg
Max. weight 1505 kg
Fuel tank 44 liter
Performance
Top speed 177 km/h
Consumption
Astra 1.4
Number of seats 5
Engine
Engine code Z14XE
Supercharging None
Bore 77.6 mm
Stroke 73.4 mm
GearBox 5 Manual
Brakes & Tyres
Wheels 5.5Jx14
Rear brakes Disc
Suspensions
Dimensions
Wheelbase 2606 mm
Length 4252 mm
Width 1709 mm
Height 1425 mm
Curb weight 1090 kg
Max. weight 1620 kg
Fuel tank 52 liter
Performance
Top speed 180 km/h
Consumption
- pascaru_val
- 1,430 mesaje
- din 07 Jun 2005
- Astra 2006 Z17DTL
pascaru_val
- Mesaje scrise: 1,430
- Masina: Astra 2006 Z17DTL
- Cont inregistrat: 07 Jun 2005
@kristen69 Tin sa precizez ca NU sunt "chitit" pe una din masini, cum zic @pescaru_val si @16V ci am descris impresiile mele in urma conducerii pentru PRIMA data
Stiti cum se zice ca DETALIILE fac diferenta:
Dupa cum spui tu mai sus detaliile conteaza, In primul rind ca nu sunt pescaru_val ci sunt pascaru_val, oricum m-am obisnuit cu asta, am mai spus-o intr-un post, iar in al doilea rind ar trebui sa stii ca Astra Caravan inseamna break din moment ce studiezi piatza si brek-ul nu are 3 usi, are 5.
Si sa iti raspund la alt subpunct: da Astra are suspensiile tari, cel putin a mea asa le are si e destul de naspa la gropi.
kristen69
- Mesaje scrise: 16
- Cont inregistrat: 11 Jun 2006
Va multumesc tuturor pentru opinii.
S-a cantarit cu MARE atentie fiecare argument. In continuare cred ca detaliile fac diferenta (in orice abordare, inclusiv profesionala). Cu scuzele de rigoare pentru numele incorect al lui pascaru_val si... privind la alte fotografii am concluzionat GRESIT ca are un hatchback... cu 3 usi
din nou scuze...
Oricum sper sa fiti ingaduitori cu un viitor Opelist care este un incepator absolut si pe acest forum si cu Opelul pe care-l voi achizitiona. Ca idee eu trec de la Oltcit la Opel
Concluzia finala este surprinzatoare si pentru mine... A fost luata DUPA drivetest in paralel cu cele doua masini.
The winner is:
Opel Astra Classic Optima cu motor 1.7 CDTI.
Optionale suplimentar:
-vopsea metalizata
-scut si garda marita
Nu am mai trecut cele care sunt in oferta (aer cond etc)
Total DDP=12970
Argumente
+ Consum mic
+ Fiabilitate clara a motorului Isuzu-Japan (din disc. pe forum)
+ Spatiu mai mare in interior
+ Airbag si la pasager (corsa nu are decat ca optiune)
- Design bord si interior RIGUROS fara elemente care sa-ti bucure ochiul...
- Lipsa computer de bord in standard (disponibil doar ca obtiune)
- Asamblata in Polonia (asta e relativa ca minus...)
- Distributie pe curea
Cam asta e. Miercuri mergem la GTT sa facem contractul. Cei de acolo foarte amabili si PROFESIONISTI. Intrebarile, cu raspunsurile de pe forum, au avut aceleasi raspunsuri si la ei. Asa...ca verificare.
Salutare tuturor si...cat de curand voi pune poze.
![Embarassed](http://www.clubopel.com/images/2013/blank.gif)
![Laughing](http://www.clubopel.com/images/2013/blank.gif)
The winner is:
-vopsea metalizata
Total DDP=12970
Argumente
+ Consum mic
![Smile](http://www.clubopel.com/images/2013/blank.gif)
gpascanu
- Mesaje scrise: 68
- Cont inregistrat: 05 Mai 2006
- pascaru_val
- 1,430 mesaje
- din 07 Jun 2005
- Astra 2006 Z17DTL
pascaru_val
kristen69
- Mesaje scrise: 16
Salutari tuturor.
Cum am promis, am pus poza cu noul Opel Astra 1.7CDTI, chiar in ziua in care am luat-o de la dealer. Stiu ca este offtopic DAR am considerat normal ca postul sa aiba o finalitate si cei ce s-au implicat in a ma sfatui sa aiba o satisfactie. Multumiri inca o data TUTUROR.
IIIIIUUUUPPPIIIII!!
IIIIIUUUUPPPIIIII!!
- pascaru_val
- 1,430 mesaje
- din 07 Jun 2005
- Astra 2006 Z17DTL
pascaru_val
kristen69 a scris:Salutari tuturor.
IIIIIUUUUPPPIIIII!!
IIIIIUUUUPPPIIIII!!
Arata marfa! n ce tara e fabricata?
kristen69
- Mesaje scrise: 16
- VectraDriver
- 50 mesaje
- din 21 Jul 2006
- Vectra 1997 1.6 16V 101 HP
VectraDriver
- Mesaje scrise: 50
- Masina: Vectra 1997 1.6 16V 101 HP
- Cont inregistrat: 21 Jul 2006
